Lost partitions after installing Linux
Niranjan
#1 Post by Niranjan »
There used be four partitions on windows c d e f .
Installed Linux, I was expecting only c drive to be removed which contained windows. Now after installing Linux entire hard disc is shown as a single unit of 626GB. So I believe I have lost the partitions. I ran test disc and following are the results. Please check the screenshot I am looking forward to recover those three NTFC partitions at the bottom of the table. Do I have a chance to recover the lost files in those partitions. I used a live cd to run test disc. Didn't disturb anything on the hard drive. I would be glad if someone can help me with that.
Re: Lost partitions after installing Linux
Use the arrow keys to switch the 4 NTFS partitions from D(eleted) to P(rimary).
On next screen, choose Write, confirm, Quit and restart your computer.
Niranjan
#3 Post by Niranjan »
Wow, thanks for the reply. I feel alive again. After restart and logging into the installed Linux would I be able to see the lost ntfc partitions or do I need to recover those contents onto an external drive.
Niranjan
#4 Post by Niranjan »
Could someone please help me
I have restored the drives I require using testdisk. Was Happy that most of my data is intact but a lot is not visible. I was hoping to retrieve the lost files and using a live OS without disturbing the hard drive. All of a sudden all the recovered drives are lost and when the tried to open the drive. It says can't mount file. Tried to perform testdisk again but whe I analysed I couldn't find the ntfc drives recovered earlier. Any solutions please.
#5 Post by cgrenier »
Please post the testdisk.log file content (not a screenshot)
Niranjan
#6 Post by Niranjan »
Hai thanks for the reply. I have performed testdisk with the options you gave and recovered the partitions again this time. I am happy for the recovery but still a lof of data is lost . I see empty folders, do I get to recover the lost files, I did not overwrite with any data.
SyncroScales
#7 Post by SyncroScales »
If the physical drive is recognized and the partition is visible and mounted again, wouldn't Niranjan use a program such as Piriform's - Recuva or cgsecurity.org's - PhotoREC? Then do the deep scans and place the folder(s) onto a large empty external or internal hard-drive so all the contents can be found and not over-write each other?
