Hi Guys,
Not sure posting in the right place, so plz let me know in case.
I wanted to create a bootable USB key to test kali-linux from Ubuntu 16.04 (In french in the second part of this tuto:http://fr.docs.kali.org/installation-fr ... ux-sur-usb)
I used the dd command but did not correctly specified the path to the usb stick (MEA CULPA)
I typed
dd if=kali.iso of=/dev/sdb bs=512k
As a result, my 500go DD used as Data was somehow formated to :
/dev/sdb1 : HPFS / NTFS cachée (Amorçable) : 2.9Go
/dev/sdb2 : FAT12 : FAT (version 16 bit) — Monté sur /media/z...e/Kali Live : 93 MB
/dev/sdb : not allocated (about 497 Go)
ran a testdisk and had following:
As u can imagine, with such a newbie mystake, it makes no sense for me.
Any help welcome
Thank you
Sun Oct 9 20:13:32 2016
OS: Linux, kernel 4.4.0-41-generic (#61-Ubuntu SMP Tue Sep 27 17:30:08 UTC 2016) i686
Compiler: GCC 5.3
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sda: dco 976773168 sectors
/dev/sdb: size 976773168 sectors
/dev/sdb: user_max 976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco 976773168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKX-001CA0, S/N:WD-WCAYU7639641, FW:15.01H15
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500630A, S/N:9QG21A8F, FW:3.AAE
Disk /dev/sdb - 500 GB / 465 GiB - ST3500630A
Geometry from i386 MBR: head=170 sector=32
BAD_RS LBA=64 126
check_part_i386 failed for partition type 17
BAD_RS LBA=5570560 16445173
FAT16 at 346/191/38
Info: size boot_sector 182336, partition 182336
FAT1 : 1-180
FAT2 : 181-360
start_rootdir : 361
Data : 393-182332
sectors : 182336
cluster_size : 4
no_of_cluster : 45485 (2 - 45486)
fat_length 180 calculated 178
heads/cylinder 64 (FAT) != 255 (HD)
Invalid NTFS or EXFAT boot
1 * hid. HPFS/NTFS 0 1 2 346 191 37 5570496
Bad relative sector.
Warning: number of heads/cylinder mismatches 64 (FAT) != 255 (HD)
2 P FAT12 346 191 38 358 25 51 182336 [NO NAME]
FAT16 at 346/191/38
FAT1 : 1-180
FAT2 : 181-360
start_rootdir : 361
Data : 393-182332
sectors : 182336
cluster_size : 4
FAT16 at 346/191/38
FAT16 >32M 346 191 38 358 25 51 182336 [NO NAME]
FAT16, blocksize=2048, 93 MB / 89 MiB
file_pread(5,16,buffer,525006864(32680/42/19)) read err: Partial read
NTFS at 60800/254/63
filesystem size 976768002
mftmirr_lcn 61048000
HPFS - NTFS 0 1 1 60800 254 63 976768002
NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
NTFS: Can't read MFT
HPFS - NTFS 60800 254 63 121601 253 62 976768002
This partition ends after the disk limits. (start=976768064, size=976768002, end=1953536065, disk end=976773168)
The harddisk (500 GB / 465 GiB) seems too small! (< 1000 GB / 931 GiB)
FAT16 >32M 346 191 38 358 57 19 184320 [NO NAME]
FAT16, blocksize=2048, 94 MB / 90 MiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 976768002 linear /dev/sdb 63" | dmsetup create test0
echo "0 184320 linear /dev/sdb 5570560" | dmsetup create test1
FAT16 at 346/191/38
FAT1 : 1-180
FAT2 : 181-360
start_rootdir : 361
Data : 393-182332
sectors : 182336
cluster_size : 4
FAT16 at 346/191/38
merci
Data partition formatted to mbr
Re: Data partition formatted to mbr
If you had a single NTFS partition, use the arrow keys to switch the NTFS partition to *(bootable). On next screen, choose Write, confirm, BackupBS, confirm, Quit and restart your computer.
maxlamenace75
Thank you
my DD reappeared in nautilus.
however, here is what happens when clicking on it:
Error mounting system-managed device /dev/sdb1: Command-line `mount "/mnt/D0C80CC1C80CA7B4"' exited with non-zero exit status 13: ntfs_mst_post_read_fixup_warn: magic: 0x371fc018 size: 4096 usa_ofs: 28544 usa_count: 32815: Argument invalide
Actual VCN (0x641f0f4fcdcf00) of index buffer is different from expected VCN (0x5).
Failed to mount '/dev/sdb1': Erreur d'entrée/sortie
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
for more details.
maxlamenace75
I kept searching and here is what I have
sudo ntfsfix /dev/sdb1
Mounting volume... ntfs_mst_post_read_fixup_warn: magic: 0x371fc018 size: 4096 usa_ofs: 28544 usa_count: 32815: Invalid argument
FAILED
Attempting to correct errors...
Processing $MFT and $MFTMirr...
Reading $MFT... OK
Reading $MFTMirr... OK
Comparing $MFTMirr to $MFT... OK
Processing of $MFT and $MFTMirr completed successfully.
Setting required flags on partition... OK
Going to empty the journal ($LogFile)... OK
Remount failed: Input/output error
Any help welcome....
Thx
FAILED
Reading $MFT... OK
Thx
