I was going to delete a partition from an external drive and reformat... Unfortunately I did this to an internal 2TB drive I use for storage.
Using Gparted from Linux, I deleted a NTFS partition and created an ext4 partition. I have not written anything new to the drive/partition.
Am I doomed? What tests do I need to run to see if I can restore the NTFS partition? Or at least recover data?
Any and all help is greatly appreciated!
Help with deleted partition recovery
Re: Help with deleted partition recovery
Run TestDisk, Analyze, Quick Search, Deeper Search, use the arrow keys to switch the NTFS partition to *(bootable). On next screen, choose Write, confirm, BackupBS, confirm, Quit and restart your computer.
LividDwarf
Fantastic, thank you.
Two quick questions. Should I leave the ext4 partition in place? And is there any benefit/downside from running test disk through my Linux install vs a live usb?
