.log File Hilfe !!!!
hellrider
#1 Post by hellrider »
Hallo community,
vielleicht hat jemand kurz mal Zeit sich dieses log file näher anzusehen.
Probiere seit geraumer Zeit eine externe Festplatte ( PROWORX 500GB,2.5'',USB 3.0) zum laufen zu bringen.
Folgendes .log file wird bei testdisk "ausgespuckt".
greets hellrider
Fri Oct 14 11:33:47 2016
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=159462195200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=471859200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=500105740288
Disk /dev/sda - 160 GB / 149 GiB - CHS 20673 240 63, sector size=512
Drive C: - 159 GB / 148 GiB - CHS 20598 240 63, sector size=512
Drive G: - 471 MB / 450 MiB - CHS 60 240 63, sector size=512
Drive X: - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Analyse Drive X: - 500 GB / 465 GiB - CHS 60801 255 63
Geometry from i386 MBR: head=106 sector=52
BAD_RS LBA=1380404564 216152
check_part_i386 1 type 0A: no test
BAD_RS LBA=1309281536 5870947
check_part_i386 2 type 69: no test
BAD_RS LBA=1735554131 4633953
check_part_i386 3 type 6D: no test
BAD_RS LBA=2978742282 5980572
check_part_i386 4 type 66: no test
 1 * OS/2 Boot Manager    85926  53 36 200213  18 49 1836018464
 2 * Novell               81499   1 39 203112 174 43 1953723749
Bad relative sector.
 3 * Sys=6D               108033  63 18 229617 137 22 1953251627
 4 * Sys=66               185418  33 34 185421 145 15      55233
file_win32_pread(536,16,buffer,706860(44/0/1)) read err: read after end of file
file_win32_pread(536,1,buffer,706872(44/0/13)) read err: read after end of file
file_win32_pread(536,3,buffer,706873(44/0/14)) read err: read after end of file
file_win32_pread(536,3,buffer,706876(44/0/17)) read err: read after end of file
NTFS at 60801/15/14
filesystem size           976769024
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              0   0  1 60801  15 14  976769024
     NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
Partition not added.
Re: .log File Hilfe !!!!
Don't search partitions inside a partition, it's useless.
You should read https://www.cgsecurity.org/testdisk.pdf
