Lost Partition, unable to restore, no result with second scan
maro
#1 Post by maro »
i got a corrupted hdd without any data.
With a deep search the preview showed some files and folders from the lost partition.
I tried to recover the partition and boot sector, but after the reboot the hdd was shown in windows as CD/DVD-drive without any data.
I did a deep search again and did not find anything anymore.
Can I recreate the partition table with the information of the logfile below? Is the information useful at all? What did I wrong for the recovery?
Thanks and regards
-- First Scan
Sun Oct 16 23:18:56 2016
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249557607936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=500693504
filewin32_getfilesize(\\.\H:) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Unzulässige Funktion.
Disk \\.\PhysicalDrive0 - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 249 GB / 232 GiB - CHS 30340 255 63, sector size=512
Drive G: - 500 MB / 477 MiB - CHS 60 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB - CHS 60801 255 63
BAD_RS LBA=1 16450559
 1 P EFI GPT                  0   0  2 60801  80 63  976773167
Bad relative sector.
NTFS at 60800/254/63
filesystem size           976766017
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              0  32 33 60800 254 63  976766017
     NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
mftmirr_lcn               2
NTFS: Can't read MFT
     HPFS - NTFS          60800 254 63 121601 222 30  976766017
This partition ends after the disk limits. (start=976768064, size=976766017, end=1953534080, disk end=976773168)
The harddisk (500 GB / 465 GiB) seems too small! (< 1000 GB / 931 GiB)
   * HPFS - NTFS              0  32 33 60801  15 14  976766976
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 17-Aug-2016 13:39 .
       5 dr-xr-xr-x     0      0         0 17-Aug-2016 13:39 ..
  121303 dr-xr-xr-x     0      0         0 24-Dec-2015 23:44 Foobar File
   54663 dr-xr-xr-x     0      0         0 15-Jun-2015 15:51 Foobar File
  155000 dr-xr-xr-x     0      0         0  2-Nov-2015 12:31 Foobar File
  170675 dr-xr-xr-x     0      0         0 22-Dec-2015 14:17 Foobar File
   68210 dr-xr-xr-x     0      0         0 10-Jul-2016 12:06 Foobar File
  149855 dr-xr-xr-x     0      0         0 27-Apr-2016 14:39 Foobar File
  124661 dr-xr-xr-x     0      0         0 27-Apr-2016 14:31 Foobar File
  120995 dr-xr-xr-x     0      0         0  2-Sep-2013 18:57 Foobar File
  124658 dr-xr-xr-x     0      0         0  4-Dec-2013 11:53 Foobar File
  139193 dr-xr-xr-x     0      0         0  4-Jul-2014 09:18 Foobar File
   68023 dr-xr-xr-x     0      0         0 12-Nov-2013 16:10 Foobar File
   22376 dr-xr-xr-x     0      0         0 16-Sep-2011 16:25 Foobar File
   68234 dr-xr-xr-x     0      0         0  3-Dec-2012 14:51 Foobar File
   26869 dr-xr-xr-x     0      0         0  2-Sep-2013 18:33 Foobar File
  150060 dr-xr-xr-x     0      0         0  3-Jul-2015 12:17 Foobar File
   46920 dr-xr-xr-x     0      0         0  6-Jun-2012 12:15 Foobar File
   86745 dr-xr-xr-x     0      0         0 26-May-2013 12:16 Foobar File
   68022 dr-xr-xr-x     0      0         0  2-Sep-2013 18:33 Foobar File
  172554 dr-xr-xr-x     0      0         0 10-Jul-2016 12:17 Foobar File
      41 dr-xr-xr-x     0      0         0 10-May-2014 12:29 Foobar File
  157259 dr-xr-xr-x     0      0         0  9-Dec-2015 23:18 Foobar File
   26863 dr-xr-xr-x     0      0         0  9-Jan-2012 14:35 Foobar File
  139215 dr-xr-xr-x     0      0         0 28-Aug-2014 20:45 Foobar File
      36 dr-xr-xr-x     0      0         0 21-Aug-2016 20:14 Foobar File
  139214 dr-xr-xr-x     0      0         0 15-Jul-2015 13:56 Foobar File
  172661 dr-xr-xr-x     0      0         0 17-Aug-2016 14:01 Foobar File
  150973 dr-xr-xr-x     0      0         0 31-May-2015 22:33 Foobar File
  172660 dr-xr-xr-x     0      0         0 10-Aug-2016 11:14 Foobar File
   22371 -r--r--r--     0      0   5506400 20-Jun-2014 11:25 Foobar File
   22372 -r--r--r--     0      0    813408 20-Jun-2014 11:25 Foobar File
      35 -r--r--r--     0      0   6726910  2-Sep-2011 09:29 Foobar File
  170670 -r--r--r--     0      0 880878828 10-Dec-2015 14:45 Foobar File
  170674 -r--r--r--     0      0 962730957 14-Dec-2015 23:57 Foobar File
  120992 -r--r--r--     0      0      6144  2-Sep-2013 18:33 Foobar File
  120992 -r--r--r--     0      0         0  2-Sep-2013 18:33 Foobar File
 1 * HPFS - NTFS              0  32 33 60801  15 14  976766976
write!
ntfs_boot_sector
filesystem size           1 0
sectors_per_cluster       0 255
mft_lcn                   0 4294967295
mftmirr_lcn               0 4294967295
clusters_per_mft_record   0 -1
clusters_per_index_record 0 -1
Status: Bad
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 6291456
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         2
ntfs_find_mft: mft_record_size     1024
ntfs_find_mft: index_block_size    4096
             New / Current boot sector
filesystem size           976766976 1
sectors_per_cluster       8 0
mft_lcn                   786432 0
mftmirr_lcn               2 0
clusters_per_mft_record   -10 0
clusters_per_index_record 1 0
mft_lcn                   786432 0
mftmirr_lcn               2 0
  121303 dr-xr-xr-x     0      0         0 24-Dec-2015 23:44 Foobar file
   54663 dr-xr-xr-x     0      0         0 15-Jun-2015 15:51 Foobar file
  155000 dr-xr-xr-x     0      0         0  2-Nov-2015 12:31 Foobar file
  170675 dr-xr-xr-x     0      0         0 22-Dec-2015 14:17 Foobar file
   68210 dr-xr-xr-x     0      0         0 10-Jul-2016 12:06 Foobar file
  149855 dr-xr-xr-x     0      0         0 27-Apr-2016 14:39 Foobar file
  124661 dr-xr-xr-x     0      0         0 27-Apr-2016 14:31 Foobar file
  120995 dr-xr-xr-x     0      0         0  2-Sep-2013 18:57 Foobar file
  124658 dr-xr-xr-x     0      0         0  4-Dec-2013 11:53 Foobar file
  139193 dr-xr-xr-x     0      0         0  4-Jul-2014 09:18 Foobar file
   68023 dr-xr-xr-x     0      0         0 12-Nov-2013 16:10 Foobar file
   22376 dr-xr-xr-x     0      0         0 16-Sep-2011 16:25 Foobar file
   68234 dr-xr-xr-x     0      0         0  3-Dec-2012 14:51 Foobar file
   26869 dr-xr-xr-x     0      0         0  2-Sep-2013 18:33 Foobar file
  150060 dr-xr-xr-x     0      0         0  3-Jul-2015 12:17 Foobar file
   46920 dr-xr-xr-x     0      0         0  6-Jun-2012 12:15 Foobar file
   86745 dr-xr-xr-x     0      0         0 26-May-2013 12:16 Foobar file
   68022 dr-xr-xr-x     0      0         0  2-Sep-2013 18:33 Foobar file
  172554 dr-xr-xr-x     0      0         0 10-Jul-2016 12:17 Foobar file
      41 dr-xr-xr-x     0      0         0 10-May-2014 12:29 Foobar file
  157259 dr-xr-xr-x     0      0         0  9-Dec-2015 23:18 Foobar file
   26863 dr-xr-xr-x     0      0         0  9-Jan-2012 14:35 Foobar file
  139215 dr-xr-xr-x     0      0         0 28-Aug-2014 20:45 Foobar file
      36 dr-xr-xr-x     0      0         0 21-Aug-2016 20:14 Foobar file
  139214 dr-xr-xr-x     0      0         0 15-Jul-2015 13:56 Foobar file
  172661 dr-xr-xr-x     0      0         0 17-Aug-2016 14:01 Foobar file
  150973 dr-xr-xr-x     0      0         0 31-May-2015 22:33 Foobar file
  172660 dr-xr-xr-x     0      0         0 10-Aug-2016 11:14 Foobar file
   22371 -r--r--r--     0      0   5506400 20-Jun-2014 11:25 Foobar file
   22372 -r--r--r--     0      0    813408 20-Jun-2014 11:25 Foobar file
      35 -r--r--r--     0      0   6726910  2-Sep-2011 09:29 Foobar file
  170670 -r--r--r--     0      0 880878828 10-Dec-2015 14:45 Foobar file
  170674 -r--r--r--     0      0 962730957 14-Dec-2015 23:57 Foobar file
  120992 -r--r--r--     0      0      6144  2-Sep-2013 18:33 Foobar file
  120992 -r--r--r--     0      0         0  2-Sep-2013 18:33 Foobar file
mft_lcn                   786432 0
mftmirr_lcn               2 0
Write new boot!
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
Status: OK
Status: OK
Sectors are identical.
-- Second Scan
Mon Oct 17 06:13:00 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500104691712
Drive F: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Analyse Drive F: - 500 GB / 465 GiB - CHS 60800 255 63
NTFS at 60800/237/45
mftmirr_lcn               2
     HPFS - NTFS              0   0  1 60800 237 45  976766976
Partition not added.
interface_load
mftmirr_lcn               2
interface_load
Re: Lost Partition, unable to restore, no result with second scan
Run TestDisk, select Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB and choose Partition table type EFI GPT.
Please post the new results of the scan.
maro
#3 Post by maro »
Thanks for the reply. Should I do it also, even if I know that the external disk was used with windows?
maro
#4 Post by maro »
thank you for the hint with the EFI GPT.
With this setting I was able to recover at least the files.
But if I go to write, the partition is not accessible via windows.
I still have two questions:
1. Can I recover the partition?
2. If not, can I delete the hdd and copy the files back? I didnt want to try it.
Thank you very much
Wed Oct 19 21:29:53 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=500104691712
Disk \\.\PhysicalDrive3 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive I: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive3 - 500 GB / 465 GiB - CHS 60801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976773167 (expected 976773167)
hdr_lba_start=34
hdr_lba_end=976773134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Data                     2048  976769023  976766976
NTFS at 0/32/33
mftmirr_lcn               2
NTFS part_offset=1048576, part_size=500104691712, sector_size=512
NTFS at 0/32/33
mftmirr_lcn               2
file_win32_pread(96,11,buffer,976773162(60801/80/58)) read err: read after end of file
file_win32_pread(96,8,buffer,976773165(60801/80/61)) read err: read after end of file
file_win32_pread(96,14,buffer,976773156(60801/80/52)) read err: read after end of file
file_win32_pread(96,14,buffer,976773157(60801/80/53)) read err: read after end of file
file_win32_pread(96,14,buffer,976773158(60801/80/54)) read err: read after end of file
file_win32_pread(96,14,buffer,976773159(60801/80/55)) read err: read after end of file
file_win32_pread(96,14,buffer,976773160(60801/80/56)) read err: read after end of file
file_win32_pread(96,14,buffer,976773162(60801/80/58)) read err: read after end of file
file_win32_pread(96,14,buffer,976773164(60801/80/60)) read err: read after end of file
file_win32_pread(96,14,buffer,976773166(60801/80/62)) read err: read after end of file
write!
New options :
 Dump : No
 Align partition: Yes
 Expert mode : Yes
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Wed Oct 19 21:37:51 2016
maro
#5 Post by maro »
any idea?
