Healthy, Active...
KDMcMullan
Healthy, Active...
#1 Post by KDMcMullan »
I've used TestDisk a few times to dig me out of a hole. This one has me stumped.
A system has two hard drives. One is used for the OS and apps. The other for user files. I've pulled the OS drive out and replaced it with an SSD. I've installed Windows 7.
Now, the "user" drive (a 250Gb drive, partitioned as a single Primary partition) doesn't work. Windows Disk Management reports it as "232.89GB RAW Healthy (Active, Primary Partition)". When I click the drive (it's mapped as F: in Explorer), I'm told "f:\ is not accessible. The parameter is incorrect." This smells to me like the disk has been partitioned, but not formatted. But I know that it contains a truckload of photos and user data.
TestDisk reports (after a deep search) "No partition found or selected for recovery."
I know this disk is FULL of data. Is there enough information here, or what other digging can I do?
Thanks.
PS - on exiting TestDisk, I've observed that it says "Invalid NTFS or EXFAT boot". I hadn't noticed that when I ran the tool.
Do you have any suggestions, please?
Thanks,.
Re: Healthy, Active...
Run "cmd" (right click Run As Administrator) and "chkdsk /f f:". What is the result ?
If it doesn't work, please post the testdisk.log file content. It will be easier to help you with the information it contains.
KDMcMullan
#3 Post by KDMcMullan »
CHKDSK /F returns:
The type of the file system is RAW.
CHKDSK is not available for RAW drives.
If I do a scan and a deep scan for partition tables, it looks like this:
Thu Oct 20 22:12:07 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=250058268160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=250058268160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=240055746560
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=249135473664
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=250064930304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=103087395328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=16861829120
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512
Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive C: - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512
Drive E: - 249 GB / 232 GiB - CHS 30288 255 63, sector size=512
Drive F: - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive G: - 103 GB / 96 GiB - CHS 12532 255 63, sector size=512
Drive H: - 16 GB / 15 GiB - CHS 2050 255 63, sector size=512
Analyse Disk /dev/sdc - 250 GB / 232 GiB - CHS 30401 255 63
1 * HPFS - NTFS 0 1 1 30401 254 63 488408067
file_pread(6,2,buffer,488396800(30401/75/11)) lseek err Invalid argument
file_pread(6,1,buffer,488396800(30401/75/11)) lseek err Invalid argument
file_pread(6,1,buffer,488396799(30401/75/10)) lseek err Invalid argument
file_pread(6,14,buffer,488396801(30401/75/12)) lseek err Invalid argument
file_pread(6,3,buffer,488396815(30401/75/26)) lseek err Invalid argument
file_pread(6,3,buffer,488396862(30401/76/10)) lseek err Invalid argument
file_pread(6,8,buffer,488396878(30401/76/26)) lseek err Invalid argument
file_pread(6,11,buffer,488396925(30401/77/10)) lseek err Invalid argument
file_pread(6,2,buffer,488398847(30401/107/42)) lseek err Invalid argument
KDMcMullan
#4 Post by KDMcMullan »
I can't quite decipher it, but I think I'm being told that there's no evidence of ever being a partition on that disk.
Can you help, please with a recovery suggestion? I know the disk is physically healthy and that it's virtually full of files.
Thanks.
#5 Post by cgrenier »
Run TestDisk, go in the Advanced menu, select the NTFS partition, choose RebuildBS, List.
If you can see your files, choose Write, confirm, Quit and restart your computer.
If you can't see your files, please copy/paste the new testdisk.log file content.
KDMcMullan
#6 Post by KDMcMullan »
That yielded up no files (other than . and ..)
It's possible that this was a FAT32 drive. I can't remember if it should be FAT32 or FAT32LBA. I will be out now for a few days, but here's the logfile. I tried both FAT32 and FAT32LBA as well as NTFS (as NTFS only showed . and ..)
I stopped one of the searches partway as I ran out of time. I edited for brevity. I hope my edits are appropriate.
Would appreciate any more insight, please.
Sun Oct 23 09:42:13 2016
Not an exFAT boot sector.
ntfs_boot_sector
file_pread(6,1,buffer,488408129(30401/254/63)) lseek err Invalid argument
filesystem size 1 1
sectors_per_cluster 0 0
mft_lcn 0 0
mftmirr_lcn 0 0
clusters_per_mft_record 0 0
clusters_per_index_record 0 0
Status: Bad
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 16
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
New / Current boot sector
filesystem size 488408067 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 2 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
mft_lcn 786432 0
mftmirr_lcn 2 0
5 dr-xr-xr-x 0 0 0 17-Oct-2016 05:20 .
5 dr-xr-xr-x 0 0 0 17-Oct-2016 05:20 ..
mft_lcn 786432 0
mftmirr_lcn 2 0
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
Change partition type:
1 * FAT32 LBA 0 1 1 30401 254 63 488408067
fat32_boot_sector
Bad
Bad
First sectors (Boot code and partition information) are not identical.
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=3815752, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
FAT32 at 369104(22/249/51), nbr=1
FAT32 at 417689(26/0/63), nbr=1
FAT32 at 417691(26/1/2), nbr=1
[etc]
FAT32 at 3643523(226/204/45), nbr=1
FAT differs, FAT sectors=0-16/48585
first_fat 369104, second_fat 417689
FAT : 32, reserved=0, fat_length=0
find_sectors_per_cluster skip_sectors=22356 (skip_offset=11446272)
Can't find cluster size
fat32_boot_sector
Bad
Bad
1 * FAT32 0 1 1 30401 254 63 488408067
fat32_boot_sector
Bad
Bad
[etc]
file_pread(6,1,buffer,488395055(30401/47/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,488395056(30401/47/31)) lseek err Invalid argument
file_pread(6,1,buffer,488395057(30401/47/32)) lseek err Invalid argument
file_pread(6,1,buffer,488395058(30401/47/33)) lseek err Invalid argument
file_pread(6,1,buffer,488395059(30401/47/34)) lseek err Invalid argument
[etc]
fat32_boot_sector
Bad
Bad
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
mft at 16
mft_lcn 786432 0
mftmirr_lcn 2 0
mft_lcn 786432 0
mftmirr_lcn 2 0
mft_lcn 786432 0
mftmirr_lcn 2 0
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
KDMcMullan
#7 Post by KDMcMullan »
Yeah, as I thought. The partition tables don't exist. (Neither for FAT32 nor NTFS.) AND The backup date seems to differ from the primary.
What are my options now, please?
Thanks.
Wed Oct 26 21:43:18 2016
fat32_boot_sector
Bad
Bad
ETC
FAT32 at 2480875(154/109/62), nbr=1
FAT32 at 2481001(154/111/62), nbr=1
ETC
file_pread(6,1,buffer,488408127(30401/254/61)) lseek err Invalid argument
file_pread(6,1,buffer,488408128(30401/254/62)) lseek err Invalid argument
fat32_boot_sector
Bad
Bad
FAT: Can't list files, bad cluster size.
fat32_boot_sector
Bad
Bad
ETC
ETC
fat32_boot_sector
Bad
Bad
KDMcMullan
#8 Post by KDMcMullan »
Can anyone help me recreate the partition on this drive, please? I'm really struggling. Thanks.
KDMcMullan
#9 Post by KDMcMullan »
Am I right in thinking the contents of the drive are lost?
