I have an external disk ADATA Superior SH93 which suddenly stopped working and Windows 7 asks me to format it.
Once it is listed under "Computer" an error like this appears:
F:\ is not accessible.
The file or directory is corrupted and unreadable.
I found testDisk in my attempt to recover my info but I'm not sure on how to proceed.
I have run it a couple times now trying to recover the disk, but I haven't been able to do it by myself even though I have read on the forums and some of the wiki.
The only thing I am certain is that I haven't written anything from testDisk.
I would appreciate any advice anyone could give me to try and recover my files.
Thank you very much in advance.
- Capture.JPG (46.09 KiB) Viewed 19126 times
Re: The file or directory is corrupted and unreadable.
mmh... anyone?
After Deeper Search did you check your partitions and pressed p to have a try to list your files?
I'd need some infos from Analyse also, to check your current partition table.
Hallo Fiona,
Thank you very much for helping me out here. I'm attaching the steps I've taken using testDisk(zip file) as well as the log file I've been appending to.
EDIT:
I don't think it is in the attachment, but when I try to list the files in the partition the following message appears:
EDIT:
LOG:Cant't open file system. Filesystem seems damaged.
Thu Jun 7 16:43:24 2012
Compilation date: 2012-05-21T08:46:51
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=157181542400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=162783035392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500105217024
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200AAJS-60Z0A0, S/N:2020202057202d444d5756414132344339393038, FW:03.03E03
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ADATA HDD SH93
Disk /dev/sdb - 500 GB / 465 GiB - ADATA HDD SH93
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 60800 254 63 976768002
Ask the user for vista mode
search_vista_part: 1
NTFS at 0/1/1
filesystem size 976768002
mftmirr_lcn 2
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,7,buffer,976773184(60801/81/17)) lseek err Invalid argument
file_pread(5,8,buffer,976773311(60801/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,976773439(60801/85/20)) lseek err Invalid argument
file_pread(5,8,buffer,976773567(60801/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,976773695(60801/89/24)) lseek err Invalid argument
file_pread(5,8,buffer,976773823(60801/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,976773951(60801/93/28)) lseek err Invalid argument
file_pread(5,8,buffer,976774079(60801/95/30)) lseek err Invalid argument
file_pread(5,8,buffer,976774207(60801/97/32)) lseek err Invalid argument
file_pread(5,8,buffer,976774335(60801/99/34)) lseek err Invalid argument
file_pread(5,8,buffer,976774463(60801/101/36)) lseek err Invalid argument
file_pread(5,8,buffer,976774591(60801/103/38)) lseek err Invalid argument
file_pread(5,8,buffer,976774719(60801/105/40)) lseek err Invalid argument
file_pread(5,8,buffer,976774847(60801/107/42)) lseek err Invalid argument
file_pread(5,8,buffer,976774975(60801/109/44)) lseek err Invalid argument
file_pread(5,8,buffer,976775103(60801/111/46)) lseek err Invalid argument
file_pread(5,8,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775176(60801/112/56)) lseek err Invalid argument
file_pread(5,3,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(5,3,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775247(60801/114/1)) lseek err Invalid argument
file_pread(5,11,buffer,976775294(60801/114/48)) lseek err Invalid argument
file_pread(5,2,buffer,976777216(60801/145/17)) lseek err Invalid argument
NTFS at 0/1/1
mftmirr_lcn 2
NTFS at 51721/199/62
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
HPFS - NTFS 51721 101 63 51721 199 62 6174
NTFS at 60800/254/63
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 500 GB / 465 GiB
file_pread(5,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(5,1,buffer,976775168(60801/112/48)) lseek err Invalid argument
Invalid partition structure.
New geometry
Disk /dev/sdb - 500 GB / 465 GiB - CHS 30524162 16 2 sector_size=512
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/sdb - 500 GB / 465 GiB - CHS 30524162 16 2
BAD_RS LBA=63 2
NTFS at 1/15/2
heads/cylinder 255 (NTFS) != 16 (HD)
sect/track 63 (NTFS) != 2 (HD)
Warning: number of heads/cylinder mismatches 255 (NTFS) != 16 (HD)
Warning: number of sectors per track mismatches 63 (NTFS) != 2 (HD)
1 * HPFS - NTFS 1 15 2 30524002 0 1 976768002
Thu Jun 7 19:27:48 2012
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn 2
NTFS at 0/1/1
mftmirr_lcn 2
Fri Jun 8 13:42:57 2012
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn 2
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/1/1
mftmirr_lcn 2
mft_lcn 2058
mftmirr_lcn 5162
mftmirr_lcn 2
Not an exFAT boot sector.
Wed Jun 13 14:21:38 2012
NTFS at 0/1/1
search_vista_part: 0
NTFS at 0/1/1
mftmirr_lcn 2
file_pread(5,8,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775359(60801/115/50)) lseek err Invalid argument
file_pread(5,8,buffer,976775487(60801/117/52)) lseek err Invalid argument
file_pread(5,8,buffer,976775615(60801/119/54)) lseek err Invalid argument
file_pread(5,8,buffer,976775743(60801/121/56)) lseek err Invalid argument
file_pread(5,8,buffer,976775871(60801/123/58)) lseek err Invalid argument
file_pread(5,8,buffer,976775999(60801/125/60)) lseek err Invalid argument
file_pread(5,8,buffer,976776127(60801/127/62)) lseek err Invalid argument
file_pread(5,8,buffer,976776255(60801/130/1)) lseek err Invalid argument
file_pread(5,8,buffer,976776383(60801/132/3)) lseek err Invalid argument
file_pread(5,8,buffer,976776511(60801/134/5)) lseek err Invalid argument
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn 2
- testdisk.zip
- (223.86 KiB) Downloaded 1454 times
I have installed a trial version of Recover My Files and it has apparently found everything on my disk (after more than 36hours of searching), and I can see some previews of my files. But I would really like to know if there is any chance I can repair my drive instead of just extracting the files and putting them back onto the disk.
Thank you in advance to all.
(Fiona, if you had any chance to reply to this again I would be very very grateful).
Looks like that your file system is faulty.1 * HPFS - NTFS 0 1 1 60800 254 63 976768002
So it looks like that you don't get around extracting your files to another intact disk/partition.
There might be one try to make your files visible in TestDisk.
You could make a diagnose of your boot sector.
Same procedure like in this case;
It only works if the current boot sector is different to the extrapoated boot sector.
Please, only have a try to list your files.
Don't write or change anything to your disk.
Thank you very much for replying Fiona, it is greatly appreciated.
I'm attaching some captures as well as the log file again.
This message is the one that has been displayed every time I try to list the files.
LOG:
I'm getting nervous now.Can't open filesystem. Filesystem seems damaged.
LOG:
Tue Jun 19 17:01:46 2012
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 126283360, seq=1, main=0 res=1
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 5241648
mft at 173376982, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 2058
ntfs_find_mft: mftmirr_lcn 5162
mft at 173380086, seq=1, main=0 res=1
mft at 179671026, seq=1, main=0 res=1
mft at 179674130, seq=1, main=0 res=1
mft at 320038296, seq=1, main=0 res=1
mft at 353461570, seq=1, main=0 res=1
mft at 353464674, seq=1, main=0 res=1
mft at 486938210, seq=1, main=0 res=1
mft at 486941314, seq=1, main=0 res=1
mft at 585003802, seq=1, main=0 res=1
mft at 585006906, seq=1, main=0 res=1
mft at 589894486, seq=1, main=0 res=1
mft at 589897590, seq=1, main=0 res=1
mft at 773273790, seq=1, main=0 res=1
mft at 773276894, seq=1, main=0 res=1
mft at 830912458, seq=1, main=0 res=1
mft at 830915562, seq=1, main=0 res=1
mft at 837398602, seq=1, main=0 res=1
mft at 837401706, seq=1, main=0 res=1
mft at 843880574, seq=1, main=0 res=1
mft at 843883678, seq=1, main=0 res=1
mft at 883973240, seq=1, main=0 res=1
ntfs_find_mft: mftmirr_lcn 2
mft at 884104680, seq=1, main=0 res=1
mft at 886320562, seq=1, main=0 res=1
mft at 886322786, seq=1, main=0 res=1
mft at 886327890, seq=1, main=0 res=1
mft at 886330898, seq=1, main=0 res=1
mft at 886334082, seq=1, main=0 res=1
mft at 886336050, seq=1, main=0 res=1
mft at 898433890, seq=1, main=0 res=1
mft at 898436994, seq=1, main=0 res=1
mft at 898778952, seq=1, main=0 res=1
mft at 898826168, seq=1, main=0 res=1
mft at 900121080, seq=1, main=0 res=1
mft at 900123176, seq=1, main=0 res=1
mft at 901006920, seq=1, main=0 res=1
mft at 901212248, seq=1, main=0 res=1
mft at 903305200, seq=1, main=0 res=1
mft at 903305936, seq=1, main=0 res=1
mft at 906634272, seq=1, main=0 res=1
mft at 911765792, seq=1, main=0 res=1
mft at 916612010, seq=1, main=0 res=1
mft at 916615114, seq=1, main=0 res=1
mft at 920517496, seq=1, main=0 res=1
mft at 920648936, seq=1, main=0 res=1
mft at 927456194, seq=1, main=0 res=1
mft at 927461474, seq=1, main=0 res=1
mft at 927462386, seq=1, main=0 res=1
mft at 927465490, seq=1, main=0 res=1
mft at 927468578, seq=1, main=0 res=1
mft at 927471810, seq=1, main=0 res=1
mft at 934272376, seq=1, main=0 res=1
mft at 934403816, seq=1, main=0 res=1
mft at 941210194, seq=1, main=0 res=1
mft at 941212290, seq=1, main=0 res=1
mft at 941216434, seq=1, main=0 res=1
mft at 941221714, seq=1, main=0 res=1
mft at 941223666, seq=1, main=0 res=1
mft at 941225762, seq=1, main=0 res=1
mft at 948546994, seq=1, main=0 res=1
mft at 948550098, seq=1, main=0 res=1
mft at 949995168, seq=1, main=0 res=1
mft at 949995296, seq=1, main=0 res=1
Potential partition:
1 * HPFS - NTFS 10792 23 59 71593 22 58 976768002
1 * HPFS - NTFS 11183 224 25 71984 223 24 976768002
1 * HPFS - NTFS 22001 214 29 82802 213 28 976768002
1 * HPFS - NTFS 30310 96 18 91111 95 17 976768002
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn 2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn 2
Status: OK
Status: OK
- Capture.JPG (44.44 KiB) Viewed 18978 times
Unfortunately it looks like that your file system is damaged.
You can have a try to use PhotoRec.
But it doesn't keep your file names and directories.
Otherwise you'll need commercial datarecovery software.
That stinks.
Thank you anyways for the help. And the time you take to help people out.
