INTEL Raid 10 Partition Lost After Drive Failure and BSOD
PlantPoweredPro
#1 Post by PlantPoweredPro »
I am in a nightmare right now. On Tuesday of this week one of my 4 disks failed. No worries, I immediately disconnected the array to stop any additional issues and then I purchased a new drive with 2 day shipping. It arrived yesterday and I popped it in. I added it in using intels bios tool and started the system up. The problem was that after that, the computer got a BSOD at startup. I remembered that when the drive failed, the BSOD hit also.
I was not too concerned, I restarted and then foun that the array was not in failure mode because one of the drives was now failed instead of good. I read online and it was recommended to reset the array so I could use TestDisk when I restarted it. Well, instead it seems that the BSOD was caused by the INTEL software completely screwing up. I just spent the past 12 hours working on the system to get the computer to run without BSOD and also have INTEL raid functioning.
So I thought I was smooth sailing but now I am having a tough time getting TEstDisk to work. I keep getting the error of no ntfs marker found. Image
I spent probably 1-2 hours going over the drive configuration to make sure it matched the previous layout. I have now lost 2 days of work and that drive has 5 years of work on it. I have a lot of stuff backed up to a 4tb raid array but not everything and a lot of my recent work is not backed up :(
Please avise.
Re: INTEL Raid 10 Partition Lost After Drive Failure and BSOD
The partition table looks ok. You should be able to access the data from the Windows LDM.
What is the output of Windows Disk Manager ?
