Pendrive says I have no access and filesystem is bad, how to fix? I used testdisk before, but not for the same problem
Nicogalan
#1 Post by Nicogalan »
Hello, my pendrive was working fine, until I plugged to my cel and otg cable, then unplugged, and now, pc cant open it anymore, it says there is no access, and file or directory damaged, or unreadable.
I tried testdisk before, to recover files, repairing boot, but this time, it does not work.
I tried to list files, but it says filesystem is damaged, so I tried to repair MFT, but it says, mft and mirror is damaged, so, I tried to rebuild boot, and it does not finish, testdisk closes at some point.
I made an image from disk before to touch anything, inside, using hex editor, I can see my files, but I can not extract.... I mean, as raw filesystem, files are extracted, but with strange names.
so, I would need to recovery my filesystem heheheheh is it possible??
log and stackdump file attached.
thanks for your help, I am more than willing to donate, 100 or 200 usd if I can recover my files :)
Escritorio.rar
(2 KiB) Downloaded 533 times
Re: Pendrive says I have no access and filesystem is bad, how to fix? I used testdisk before, but not for the same probl
Try to repair the MFT using TestDisk 7.1-WIP instead of 7.0.
If it doesn't work, run PhotoRec, Search, [Whole].
Nicogalan
#3 Post by Nicogalan »
Thanks, sadly, the same result...
app closes itself....
is there another way to repair MFT?
I have experience with hex edition.
thanks
