The following partition can't be recovered
laurajordana
#1 Post by laurajordana »
Hi, I have WD Passport Ultra that is showing up as RAW in Windows Disk Management and I'm prompted to format the drive.
I ran TestDisk Quick Search and Deeper Search and it says "The following partition can't be recovered" and "The harddisk seems to small!"
When I click Continue after the Deeper Search it shows me a list of partitions (Capture3.JPG) but I'm not sure what to do at this point.
I've attached the screenshots, and the log file at the end of this post.
Thank you,
Laura
Log file:
Mon Oct 31 08:37:36 2016
OS: Windows Vista (6002) SP2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=484337047040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=15728640000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=31457280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000364240896
Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 484 GB / 451 GiB - CHS 58883 255 63, sector size=512
Drive D: - 15 GB / 14 GiB - CHS 1912 255 63, sector size=512
Drive G: - 31 MB / 30 MiB - CHS 7 64 32, sector size=2048
Drive H: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Analyse Drive H: - 2000 GB / 1862 GiB - CHS 243197 255 63
BAD_RS LBA=3244862697 13102830
FAT12 201983 92 7 317291 215 4 1852430767
This partition ends after the disk limits. (start=3244862697, size=1852430767, end=5097293463, disk end=3906961408)
BAD_RS LBA=830146137 7968289
FAT12 51674 52 52 68724 12 43 273905722
The harddisk (2000 GB / 1862 GiB) seems too small! (< 2609 GB / 2430 GiB)
L FAT12 51674 52 52 68724 12 43 273905722
add_ext_part_i386: max
add_ext_part_i386: min
1 E extended LBA 51674 0 1 68724 254 63 273924315
5 L FAT12 51674 52 52 68724 12 43 273905722
Re: The following partition can't be recovered
"None" was the correct partition table type for H:, PC/Intel is correct for the PhysicalDrive.
It's useless to search partitions inside the partition H:
Download https://www.cgsecurity.org/testdisk.pdf and read "Repairing filesystem".
Please post the output of chkdsk and the new testdisk.log file content if you have problems.
laurajordana
#3 Post by laurajordana »
Running chkdsk showed:
"The type of the file system is RAW.
CHKDSK is not available for RAW drives."
i ran testdisk again using None as the partition table type. This time it took several days and seemed to detect it as NTFS but still said "Partition cannot be recovered".
The log file was unusually short:
Wed Nov 2 23:04:45 2016
Partition table type: None
P Unknown 0 0 1 243197 25 28 3906961408
Change partition type:
