QPhotoRec blocked
cpighin
QPhotoRec blocked
#1 Post by cpighin »
Hi Christophe,
I have to update the previous message. Unexpectedly, after a couple of hours, the application has resumed to verify the disk sectors and ended the process by recovering 12 files: not what I was looking for!
I rebooted QPhotoRec in Whole mode and see what happens (formerly I started in Free mode)!
Re: QPhotoRec blocked
It's better to use TestDisk 7.1-WIP than 6.14.
If necessary, read https://www.cgsecurity.org/testdisk.pdf for explanations on how to install the latest version.
cpighin
#3 Post by cpighin »
Thanks,
for information, the new session started in Whole mode, stopped at exactly the same point of the previous one, i.e. reading sector 569870272. After ten minutes of inactivity, I decided to unmount and mount again the origin partition, and after few seconds, I saw the application starting again and ending the job in forty minutes. Unfortunately were recovered only the same 12 files saved with the Free mode session: not the ones I was looking for!
I will take your suggestion to use TestDisk 7.1-WIP than 6.14 and I will let you know something about.
Claudio :)
cpighin
#4 Post by cpighin »
I am anable to istall the package following your instruction.
I downloaded (into folder /home/claudio/Scaricati) package testdisk-7.1-WIP.linux26.tar.bz2 and executed command
tar xjf /home/claudio/Scaricati/testdisk-7.1-WIP.linux26.tar.bz2
with no results.
Is the command correct?
Should I give other commands to install testdisk-7.1-WIP?
As you can see, I am not expert ;)
Claudio :)
#5 Post by cgrenier »
The command tar doesn't display messages by default.
List your files, a directory named testdisk-7.1-WIP should has been created.
cpighin
#6 Post by cpighin »
cgrenier wrote:The command tar doesn't display messages by default.
Thanks,
I found the folder and executed TestDisk 7.1WIP by command
sudo /home/claudio/testdisk-7.1-WIP/testdisk_static
Claudio :)
