disk is not recognized
Nubber
#1 Post by Nubber »
Hello there,
I tried to repair a partition from second harddisk:
2016-11-04 15_29_28.png (34.5 KiB) Viewed 3793 times
I have the problem, that testdisk does not recognise the second harddisk in general.
>Disk /dev/sda - 1000 GB / 931 GiB - ST1000DM 003-9YN162
>[Proceed ] [ Quit ]
If a disk listed above has an incorrect size, check HD jumper settings and BIOS
Fri Nov 4 15:23:15 2016
Compiler: GCC 5.4, Cygwin 2005.2
filewin32_getfilesize(/dev/sdb) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(/dev/sdb) SetFilePointer err Unzulässige Funktion.
Warning: can't get size for Disk /dev/sdb - 0 B - 0 sectors, sector size=512 - ST1000DM 003-9YN162
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Unzulässige Funktion.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=268435456000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=731661729792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=128849018880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=871248166912
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM 003-9YN162, S/N:S1D8KNQF, FW:CC62
Could you please help what to do that testdisk will recognize the harddisk?
Regards
Marcel
Re: disk is not recognized
Your 2 harddisk are the same model ST1000DM 003-9YN162 but TestDisk failed to get the size of the second one
"filewin32_getfilesize(/dev/sdb) GetFileSize err Unzulässige Funktion.
filewin32_setfilepointer(/dev/sdb) SetFilePointer err Unzulässige Funktion."
I don't know why the 2 functions are listed as illegal.
As a workaround, you can boot from a LinuxLiveUSB and run testdisk from it.
You can also run "cmd" (right click run as administrator) and "chkdsk /f G:", "chkdsk /f I:"
Nubber
#3 Post by Nubber »
Ok, using LinuxLiveUSB sounds like a plan. Thank you. I will try that at first.
