First of all, thank you for this awesome utility - TestDisk. I will make a contribution. I've read TestDisk step-by-step and I'm very grateful for the documentation provided and the support of this forum. Here's my story.
I planned to use a mythbuntu live disk to install mythbuntu onto a HDD using a DVD in my laptop's (Dell Vostro 1520) DVD drive via a USB dock attached to my laptop. Before I knew what happened I apparently corrupted the laptop's GRUB and/or boot sector. The OS on my laptop is AVLinux, an audo-optimized Debian system. I think it is the "6" version, a 32-bit system.
Before working with TestDisk I dd'd the problem ("Source") disk (340GB) to a USB-connected ("Rescue") disk (2TB). Should I first try to get the Rescue disk to boot rather than the Source disk? How do I reinstall/repair GRUB on a USB-connected HDD? I suppose launch the LiveCD from the laptop's DVD drive, but then how do I make sure the attempted repair is done to the USB-attached drive and not to the laptop's onboard drive? I see this but it seems like my dd image might somehow "get in the way" of the replacement GRUB installation. Maybe not. Probably just overthinking the problem.
I think there were two partitions installed -- a swap and an ext4. I believe I can see both and can browse the files in the ext4. I suspect the partitions are Primary (swap) and Extended (ext4). Don't know that it matters, as I think TestDisk will "just" figure that out.
TestDisk reports the first partition is "bad" but that, I expect, is because GRUB is gone. Am I correct that its ok to write a new partition table with this first partition labeled "bad"? Should I first try to mark it "P"?
Some of the directories and files in ext4 I browse are red. I understand that means they're deleted. Can/should I do anything special to them before writing a new partition table?
I've tried to copy files to another drive. Some of the files (/boot directory) copy fine, but when I try to copy my /home directory a few files (304) copy and the rest all "fail". I now see that maybe I should "H"ide deleted files first before attempting to copy. I suppose only the copy utility within TestDisk itself (as opposed to, for example, rsync) has any chance of success in this context. Any other suggestions about what I may be doing wrong on this score would be appreciated.
I thought I had a testdisk.log to share but apparently did not get it copied. I'll try to grab it tonight and attach to this post FWIW.
Linux System Repair Best Practices Topic is solved
Re: Linux System Repair Best Practices
Try the following
- boot from a Linux LiveUSB/LiveDVD
- lsblk
- mount the original "/" in /mnt (ie mount /dev/sdb1 /mnt)
- mount the original "/boot" in /mnt/boot
Reboot your computer
- lsblk
mount -t proc none /mnt/proc
mount -t sysfs sysfs /mnt/sys
mount --bind /dev/ /mnt/dev
chroot /mnt /bin/bash
cp /proc/mounts /etc/mtab
grub2-install /dev/sdb
exit
umount /mnt/dev
umount /mnt/sys
umount /mnt/proc
umount /mnt/boot
umount /mnt
pgreenwood
my efforts to mount the local HDD fail
Attempts to mount /dev/sda1 show the same thing. I think the first partition is swap. Wouldn't that be /dev/sda1?
~# fdisk -l shows:
Do I need to first write (with testdisk) a partition table to /dev/hda before I can mount the partitions? Thank you!
root@tester:/home/tester# mount /dev/sda2 /mnt
mount: block device /dev/sda2 is write-protected, mounting read-only
mount: special device /dev/sda2 does not exist
root@tester:/home/tester# ~# fdisk -l shows:
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0xea48fe5b
Device Boot Start End Blocks Id System
Disk /dev/sdb: 640.1 GB, 640135028736 bytes
255 heads, 63 sectors/track, 77825 cylinders
Disk identifier: 0xacdd9b22
/dev/sdb1 1 122 976531+ c W95 FAT32 (LBA)
Partition 1 does not end on cylinder boundary.
/dev/sdb2 123 77825 624149347+ 83 Linux
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
root@tester:/home/tester# -
pgreenwood
I went back to testdisk. Working from my "rescue" disk I changed the file type of the first partition to 82 swap and marked the second partition "P" as per /etc/fdisk from my salvaged data. I wrote the table via testdisk. Now fdisk and lsblk recognized the primary Linux partition as sd*1 and I was able to run through the commands above and write a new GRUB. I couldn't get the disk to boot via the USB dock but did get it to boot on another computer. I then followed the process once more on /dev/sda1 (my laptop's HDD) and now I have a bootable system again. Thanks, again, Christophe and all others who lend real and moral support!
