Hdd error - testdisk.log - HELP
stacieys
#1 Post by stacieys »
Wed Nov 16 16:21:13 2016
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=999732936704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=999732936704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=729074753536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=419430400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=999725174784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=106896384
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Disk /dev/sdb - 999 GB / 931 GiB - CHS 121543 255 63, sector size=512
Drive C: - 729 GB / 679 GiB - CHS 88638 255 63, sector size=512
Drive E: - 419 MB / 400 MiB - CHS 100 64 32, sector size=2048
Drive G: - 999 GB / 931 GiB - CHS 121542 255 63, sector size=512
Drive Z: - 106 MB / 101 MiB - CHS 12 255 63, sector size=512
Analyse Disk /dev/sdb - 999 GB / 931 GiB - CHS 121543 255 63
FAT32 at 0/1/1
Info: size boot_sector 1952588232, partition 1952588232
FAT1 : 32-119193
FAT2 : 119194-238355
start_rootdir : 238356 root cluster : 2
Data : 238356-1952588179
sectors : 1952588232
cluster_size : 128
no_of_cluster : 15252733 (2 - 15252734)
fat_length 119162 calculated 119162
file_pread(5,128,buffer,238419(14/214/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,238419(14/214/28)) ReadFile Data error (cyclic redundancy check).
fat32_set_part_name() cannot read FAT32 root cluster.
1 P FAT32 LBA 0 1 1 121542 254 63 1952588232 [NO NAME]
FAT32 at 0/1/1
FAT1 : 32-119193
cluster_size : 128
FAT32 at 0/1/1
FAT32, blocksize=65536, 999 GB / 931 GiB
file_pread(5,2,buffer,1952604160(121543/251/53)) lseek err Invalid argument
file_pread(5,1,buffer,1952604160(121543/251/53)) lseek err Invalid argument
file_pread(5,1,buffer,1952604159(121543/251/52)) lseek err Invalid argument
file_pread(5,14,buffer,1952604161(121543/251/54)) lseek err Invalid argument
file_pread(5,3,buffer,1952604175(121543/252/5)) lseek err Invalid argument
file_pread(5,3,buffer,1952604222(121543/252/52)) lseek err Invalid argument
file_pread(5,8,buffer,1952604238(121543/253/5)) lseek err Invalid argument
file_pread(5,11,buffer,1952604285(121543/253/52)) lseek err Invalid argument
file_pread(5,2,buffer,1952606207(121544/29/21)) lseek err Invalid argument
* FAT32 LBA 0 1 1 121542 254 63 1952588232 [NO NAME]
dir_partition inode=0
FAT: cluster=2(0x2), pos=238419
FAT: Can't read directory cluster.
1 * FAT32 LBA 0 1 1 121542 254 63 1952588232 [NO NAME]
Re: Hdd error - testdisk.log - HELP
The CRC errors means the disk contains bad sectors. You need to clone the disk to a new empty disk.
You can use gnu ddrescue from a Linux LiveUSB, see https://www.cgsecurity.org/testdisk.pdf for the details.
Once the copy is done, remove the original disks and try to access your data on the clone
Good luck
