I've been confused as to which version of TestDisk should be used on a Windows 7 64-bit system... O_o
Thanks!
7.0, 7.1 WIP, "Use only on systems lacking WoW64"?
Autolooper
Re: 7.0, 7.1 WIP, "Use only on systems lacking WoW64"?
Both testdisk 7.1-WIP 32-bits and 64-bits are generated using cygwin, so you can use the 64-bits version without problem.
