PhotoRec and SSD
Anthony317
PhotoRec and SSD
#1 Post by Anthony317 »
Hello folks!
Does it work on SSD? Is there a chance when PhotoRec will kill this type of drive during the recovery process? What can cause such SSD malfunction? It seems like Photorec ruined my computer, i guess there might be issues with my ssd.
I am looking forward to get a helpful suggestion here, please, share your opinions, thnk you!
Re: PhotoRec and SSD
PhotoRec opens the source device in read-only mode, it can not write anything on the disk. TestDisk and PhotoRec do not see any difference between a SSD and a mechanical disk.
The most serious source of problem on a ssd is electric problem (power drop, voltage spike...), it may damage the flash controller.
Wear leveling https://en.wikipedia.org/wiki/Wear_leveling is used on ssd to avoid too much write cycle on specific memory zone, but it's no bullet proof.
Anthony317
#3 Post by Anthony317 »
Thank you for the quick response!
Have you heard about FileVault encryption or any other type of data encrypting? Will PhotoRec work in case the volume is encrypted? Thank you, i do appreciate the help.
