USB stick data unavailable
Goldtam
#1 Post by Goldtam »
Hello all,
I can't access anymore to data on my USB stick.
Voir l'image en grand
When I plug the USB stick in, Windows displays:
So I use testdisk and proceed on the selected line:
I choose Intel/PC Partition (automaticly testdisk is on this option) then analyse.
No partition is found during Quick Search:
I do a deeper search but still no partition found:
If I try Advanced, it said that I have no partition available:
Do you know how can I have the data back ? None tools detect any files on the usb stick.
Thanks in advance for your help.
Regards,
Re: USB stick data unavailable
You can try PhotoRec 7.1-WIP but I don't know if it will work, the flash controller of the USB key may be damaged.
Goldtam
#3 Post by Goldtam »
Thank you for your quick answer.
Photorec find this:
But if I do search, no file is found (for the 2 options given: fat and src):
If the flash controller of the usb key is damaged, can it be fixed ?
Thank you again and Merry Christmas.
