3TB usb 3.0 went crazy
Raflesia
#1 Post by Raflesia »
Greetings.
i have the following problem.
a 3TB external USB 3.0 HD went crazy; none of my pc couldn't recognize it.
So i remove it from its case and i connected it to an USB/SATA adapter to see if the problems were in the USB 3.0 formware of its case.
Well, no luck, in addiction W7 reported HD was size mismatched.
So i connected it to a spare pc using a SATA bus, then booted using a parted magic live cd and the i ran into TESTDISK.
so this is what's happened.
first of all i selected the DRIVE, the one in red.
Sun Mar 17 04:37:23 2002
OS: Linux, kernel 4.8.2-pmagic64 (#1 SMP Sun Oct 16 18:22:46 CDT 2016) x86_64
Compiler: GCC 5.3
ext2fs lib: 1.43.3, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.5, ewf lib: 20140608, curses lib: ncurses 5.9
/dev/sda: size 5860533168 sectors
/dev/sda: user_max 5860533168 sectors
/dev/sda: native_max 5860533168 sectors
/dev/sda: dco 5860533168 sectors
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - ST3000DM003-1F216N, S/N:W300W18V, FW:CC54
Disk /dev/sdb - 62 GB / 57 GiB - CHS 59232 64 32, sector size=512 - SanDisk Ultra USB 3.0, FW:1.00
Disk /dev/sr1 - 563 MB / 537 MiB - 274944 sectors (RO), sector size=2048 - SONY DVD RW AW-G170A, FW:1.71
then i choose INTEL/PC partition
Disk /dev/sda - 3000 GB / 2794 GiB - ST3000DM003-1F216N
and then Analyze
Analyse Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 1 2 45600 1 1 732564000
so we can see in the log, the 2 entries about partition, but both are wrong.
Originally, this HD had a single NTFS partition of 3TB. Logically was a GPT one.
so i started a QUICK SEARCH
i aborted since previous scan led to no result.
the i did as follow,
go back to DISK selection
Partition table type: None
but i specified NONE as partition table type.
then Advanced..
P Unknown 0 0 1 364801 80 63 5860533168
Change partition type:
P NTFS 0 0 1 364801 80 63 5860533168
where i changed manually partition type from NONE to NTFS
then QUIT, ANALYSE and ... magically....
NTFS at 0/8/9
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
filesystem size 732564000
sectors_per_cluster 1
mftmirr_lcn 2
clusters_per_mft_record 1
NTFS part_offset=262144, part_size=3000582144000, sector_size=512
NTFS at 0/8/9
mftmirr_lcn 2
NTFS 0 8 9 364800 8 8 5860512000 [_V_]
now, please look carefully the line in red.
Testdisk retrieved the original label of the disk that was _V_
and the entire line was in a nicely green background color.
So maybe i was at the end;
P command, listed MY FILES !!!!!! HURRAH !!!! but i wanted to fix this mess then i hit ENTER...
but.....
damn...
P NTFS 0 8 9 364800 8 8 5860512000 [_V_]
echo "0 5860512000 linear /dev/sda 512" | dmsetup create test0
Write isn't available because the partition table type "None" has been selected.
and i'm stucked here...
how can i fix my hard disk ???
really don't know what else i could do.
Please, any advice will be appreciated..
Bye,
Reflesia
Re: 3TB usb 3.0 went crazy
It looks like your disk was using 4096 bytes sector and is now using 512 bytes sector.
Try TestDisk, sda, EFI GPT, Analyse, Quick Search.
Is your partition found ?
Raflesia
#3 Post by Raflesia »
Thanks for your kind and fast reply.
Well i did as u suggested and... voila !!! partition and DATA back again.
Thanks so much... how can i repay you ?
Best.
Raf.
p.s.
Happy New Year 2017
p.p.s
Do you have any ideas about how this mess has happened ?
crappy HW, bad USB 3.0, SW bugs ??
i have always used this external disk in a religious manner..but without any symptoms..it went crazy
I don't really know why this problem occur but you can check if your computer applied updates prior to the problem...
How to repay me ? There is no obligation but if English is your native language, you can help by copy editing https://www.cgsecurity.org/testdisk.pdf (source: https://www.cgsecurity.org/testdisk_doc.zip )
Donations are otherwise welcome: https://www.cgsecurity.org/wiki/Donation
Raflesia
#5 Post by Raflesia »
Hi Cristophe, and Happy New Year.
well, i have completely backed-up all my data, even if the hard disk is fully usable under the parted disk->testdisk.
I have a new USB 3.0 external BOX, so i connected the HD in it and tried to see it under windows.
Well, absolutely no luck; the device is detected, but disk management reports it as a RAW partition.
So i am here wondering if there is a way to revert back the RAW partition to the NTFS it was once without any loss of data.
Testdisk reports my HD, a Seagate Barracuda 3.00TB, has an EFI GPT partition type; shouln't it be an Intel/PC partition ?
Any chances or better to repartion/reformat under WIN ?
Thanks in advance.
Raf.
Raflesia
#6 Post by Raflesia »
***UPDATE***
Really i don't know what's happened, but gparted reported and advised me to perform chkdsk /f
so i connected the HD inside its new BOX to my win/pc..
then i issued a chkdsk x: /f/v command...and keeping fingers crossed.....after a few minutes all went ok :) :o
HD is fully recovered and all its content seems to be ok; there are several large RAR archives, circa 80Gb each and testing them was succesful.
So i think my problem is solved; but anyway, without backup made possible by TESTDISK, i never tried a chkdsk !!!!!
So Christophe, thanks again.
All the best
Raf.
#7 Post by cgrenier »
Perfect! Happy ending ;-)
