Netwerk drive not accessable Topic is solved
Jardy
#1 Post by Jardy »
Hopefully somebody can help me.
My netwerk drive is no longer accessable so I put the harddrive in my PC.
I can see the drive in system maintenance, but no more.
After running testdisk I can see that the drive is XFS6.2 an I do not know how partitions should look like.
The big partition is indicated as bootable but the option P is not there to list the files.
I'd like to repair the drive because there are some homevideos (*.mts) on the drive which I want back.
Can somebody help me go forward.
The testdisk results:
L Linux Swap 0 2 1 31 254 63 513954
D Linux 33 1 1 33 254 63 16002
D Linux RAID 33 1 1 33 254 63 16002 [md0]
D Linux 34 1 1 139 254 63 1702827
D Linux RAID 34 1 1 139 254 63 1702827 [md0]
L Linux 140 1 1 248 254 63 1751022
>* Linux 250 0 1 121600 254 63 1949503815
Keys A: add partition, L: load backup, T: change type,
Enter: to continue
XFS 6.2+ - bitmap version, 998 GB / 929 GiB
Sponsored links
Jardy
Re: Netwerk drive not accessable
#2 Post by Jardy »
Hereby all the results of testdisk up until the deep search. Deep search does not finish, it sops when it hits the big partition:
> 1 E extended 0 1 1 249 254 63 4016187
2 P Linux 250 0 1 121600 254 63 1949503815
5 L Linux Swap 0 2 1 31 254 63 513954
X extended 32 0 1 32 254 63 16065
6 L Linux 32 1 1 32 254 63 16002
X extended 33 0 1 33 254 63 16065
7 L Linux 33 1 1 33 254 63 16002
X extended 34 0 1 139 254 63 1702890
8 L Linux 34 1 1 139 254 63 1702827
X extended 140 0 1 248 254 63 1751085
Next
>[Quick Search] [ Backup ]
Try to locate partition
Previous
9 L Linux 140 1 1 248 254 63 1751022
X extended 249 0 1 249 254 63 16065
10 L Linux 249 1 1 249 254 63 16002
Previous
Enter: to continue
SWAP2 version 1, 263 MB / 250 MiB
1 E extended 0 1 1 248 254 63 4000122
2 * Linux 250 0 1 121600 254 63 1949503815
6 L Linux 140 1 1 248 254 63 1751022
[ Quit ] >[Deeper Search] [ Write ]
Jardy
#3 Post by Jardy »
Problem solved.
I used UFS explore which enabled me to look at the XFS partition in Windows. With this tool I was able to copy the files back to my other disks.
#4 Post by Fiona »
Thanks for your feedback.
I'll set your topic as solved.
