Damaged filesystem?
slomap
Damaged filesystem?
#1 Post by slomap »
I can't access my Seagate ST3000DM001 drive. It used to work in a desktop PC, but I had motherboard failure and decided it wasn't viable to repair it (it had been my second, say backup system in). I connected it through USB docking station to my maim computer and unfortunaetly it didn't work.
What TestDisk says is as follows:
Fri Jan 13 14:26:09 2017
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592977920
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Niepoprawna funkcja.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Niepoprawna funkcja.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592977920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119924588544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=750154244096
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Drive C: - 119 GB / 111 GiB - CHS 14580 255 63, sector size=512
Drive H: - 104 MB / 100 MiB - CHS 12 255 63, sector size=512
Drive J: - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
That the sdd or PhysicalDrive3
I did Analyse:
Analyse Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 45600 255 63
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
[b]Warning: Bad ending head (CHS and LBA don't match)[/b]
I guess that's the problem, but don't really know what to do with it :(
When I go forward:
NTFS at 2/14/13
filesystem size           4194304000
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              2  14 13 32637 120 59  524288000
     NTFS, blocksize=4096, 2147 GB / 2000 GiB
NTFS at 32637/120/60
it does find both partitions on the drive, I can access files etc. but it won't write partition table :(
filesystem size           1665961984
mftmirr_lcn               2
     HPFS - NTFS          32637 120 60 45600  36  4  208245248
     NTFS, blocksize=4096, 852 GB / 794 GiB
   * HPFS - NTFS              2  14 13 32637 120 59  524288000
   P HPFS - NTFS          32637 120 60 45600  36  4  208245248
 1 * HPFS - NTFS              2  14 13 32637 120 59  524288000
 2 P HPFS - NTFS          32637 120 60 45600  36  4  208245248
juest gives me an error.
Would appreciate help very much :)
Kind regards,
Pete
Re: Damaged filesystem?
Using latest 7.1-WIP version, try EFI GPT instead of PC Intel after selecting the disk.
Do you have more success rewriting the partition table ?
slomap
#3 Post by slomap »
Thank you for a replay. Unfortunetly it still can't write the table - it sees both partitions, I can check file just fine, but it still gives me error on write.
Full log:
Fri Jan 13 19:36:18 2017
Compiler: GCC 5.4, Cygwin 2005.2
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - INTEL SS DSC2CW120A3, S/N:VCVC240630CZ21B0NG, FW:400i
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - TOSHIBA MQ01ABD075, S/N:7 Q4CBFJT0, FW:AX00
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - Generic External, S/N:W1F1FQ7J, FW:0204
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - Generic External, S/N:W1F1FQ7J, FW:0204
Disk \\.\PhysicalDrive3 - 3000 GB / 2794 GiB - Generic External
Partition table type: EFI GPT
Trying alternate GPT
NTFS at 2/14/13
mftmirr_lcn               2
     MS Data                    33024  524321023  524288000 [Backup]
mftmirr_lcn               2
     MS Data                524321024  732566271  208245248 [Archiwum]
file_win32_pread(420,2,buffer,732566644(45600/41/62)) read err: read after end of file
   P MS Data                    33024  524321023  524288000 [Backup]
   P MS Data                524321024  732566271  208245248 [Archiwum]
 1 P MS Data                    33024  524321023  524288000 [Backup]
 2 P MS Data                524321024  732566271  208245248 [Archiwum]
