MacOsx no information on HDD (Mac OS Extended)
After reboot? I didn't find my HDD in Finder. Disk Utility see it, but lost all data and the name off HDD. What is the best way to repair information ?
- Screen Shot 2017-01-17 at 00.01.41.png (53.18 KiB) Viewed 4033 times
- Screen Shot 2017-01-17 at 00.05.11.png (54.02 KiB) Viewed 4033 times
Re: MacOsx no information on HDD (Mac OS Extended)
What is the result of
sudo fsck_hfs /dev/disk5s2Re: MacOsx no information on HDD (Mac OS Extended)
Thank you.
I plugged HDD to my Macbook and now it disk2s2
MacBook-Air:~ evgeniy$ sudo fsck_hfs -f /dev/disk2s2
** /dev/rdisk2s2
Executing fsck_hfs (version hfs-305.10.1).
** Checking Journaled HFS Plus volume.
Invalid B-tree node size
(3, 0)
** The volume could not be verified completely.
I used command from your manual. "fsck_hfs -r -d /dev/disk2s2"
MacBook-Air:~ evgeniy$ sudo fsck_hfs -r -d /dev/disk2s2
Password:
journal_replay(/dev/disk2s2) returned 0
** /dev/rdisk2s2
Using cacheBlockSize=32K cacheTotalBlock=16384 cacheSize=524288K.
Block 3906357342 is not an MDB or Volume Header
(3, 0)
volume check failed with error 7
volume type is pure HFS+
primary MDB is at block 0 0x00
alternate MDB is at block 0 0x00
primary VHB is at block 2 0x02
alternate VHB is at block 3906357342 0xe8d6485e
sector size = 512 0x200
VolumeObject flags = 0x03
total sectors for volume = 3906357344 0xe8d64860
total sectors for embedded volume = 0 0x00
CheckHFS returned -1317, fsmodified = 0
** /dev/rdisk2s2
(3, 0)
Password:
** /dev/rdisk2s2
(3, 0)
If it doesn't improve after another fsck, you will have to use PhotoRec to recover your data, but it will not recover the original filenames.
