I have win10 computer with 2 hard drives attached, 1tb each. One of the drives, c:, has a fresh install of win 10.
The other drive, e:, has all my files, photos, videos etc. It has win10 also but it does not boot. It says no os found.
Here is the testdisk log:
Mon Jan 16 14:48:57 2017
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999731229184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2048
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=999258321408
Drive C: - 999 GB / 931 GiB - CHS 121543 255 63, sector size=512
Drive D: - 2048 B - CHS 1 64 32, sector size=2048
Drive E: - 999 GB / 930 GiB - CHS 121486 255 63, sector size=512
Analyse Drive E: - 999 GB / 930 GiB - CHS 121486 255 63
Geometry from i386 MBR: head=102 sector=52
BAD_RS LBA=1920221984 1286028
check_part_i386 1 type 72: no test
BAD_RS LBA=1936028192 5737917
check_part_i386 2 type 6C: no test
1 P Sys=72 119528 74 3 232582 38 44 1816210284
Bad relative sector.
2 * Sys=6C 120512 46 15 242121 118 1 1953653108
BAD_RS LBA=2970170452 4294967295
HPFS - NTFS 184884 142 47 233635 105 33 783182471
This partition ends after the disk limits. (start=2970170452, size=783182471, end=3753352922, disk end=1951676409)
BAD_RS LBA=2673688576 10709
FAT12 166429 106 14 398136 79 62 3722371303
This partition ends after the disk limits. (start=2673688576, size=3722371303, end=6396059878, disk end=1951676409)
The harddisk (999 GB / 930 GiB) seems too small! (< 3274 GB / 3049 GiB)
New options :
Dump : No
Align partition: Yes
Expert mode : No
interface_load
interface_load
Change partition type:
New options :
Dump : No
Expert mode : No
OS not found
Re: OS not found
It's useless to search partitions inside the partition E:.
When starting TestDisk, select PhysicalDisk1
Re: OS not found
Thank you,
At "select the partition type" it defaults to "none" but on the bottom it says "do NOT select "none".
What should I select?
Re: OS not found
Also,
at "select a media" I get the following:
disk /dev/sda - 1000gb /931 GiB
drive c: -999GB /931 GiB
Drive e: -999 GB /930 Gib
C: is the good drive
E: is the damaged one
There is no "physicalDisk1" option
Re: OS not found
He is the right disk:
Thu Jan 19 04:17:42 2017
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=16005464064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=16005464064
Fix disk size using CHS
Disk /dev/sdc - 16 GB / 14 GiB - CHS 1945 255 63, sector size=512
Drive F: - 15 GB / 14 GiB - CHS 1945 255 63, sector size=512
Disk /dev/sda - 1000 GB / 931 GiB
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
check_part_i386 2 type 27: no test
1 P HPFS - NTFS 0 32 33 121486 93 8 1951676409
2 * Windows RE(store) 121486 93 16 121543 186 51 921600
NTFS at 0/32/33
filesystem size 1951676409
mft_lcn 736082
mftmirr_lcn 81144119
NTFS, blocksize=4096, 999 GB / 930 GiB
NTFS at 121486/93/16
filesystem size 921600
mft_lcn 38400
mftmirr_lcn 2
HPFS - NTFS 121486 93 16 121543 186 51 921600
NTFS, blocksize=4096, 471 MB / 450 MiB
file_pread(4,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(4,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(4,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(4,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(4,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(4,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(4,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(4,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 121486 93 15 1951676416
P HPFS - NTFS 121486 93 16 121543 186 51 921600
1 * HPFS - NTFS 0 32 33 121486 93 15 1951676416
2 P HPFS - NTFS 121486 93 16 121543 186 51 921600
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn 736082
mft_lcn 38400
mftmirr_lcn 2
