Raid 5 EXT4-fs (md0): VFS: Can't find ext4 filesystem
john410312
#1 Post by john410312 »
My Raid 5 (4x3TB) was running degraded and before I was able to replace the failed HD, an Ubuntu kernel upgrade fried the raid. Not being able to rebuild the arrray, I zeroed the superblock and recreated. Probably my first mistake. I was able to get the array to resync and become clean but still am unable to mount due to...
john@nasmedia:~$ sudo mount -a
mount: wrong fs type, bad option, bad superblock on /dev/md0,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
john@nasmedia:~$ dmesg | tail
[  616.187924] EXT4-fs (md0): VFS: Can't find ext4 filesystem
fdisk responds
Disk /dev/md0: 9001.4 GB, 9001370124288 bytes
2 heads, 4 sectors/track, -2097367168 cylinders, total 17580801024 sectors
I/O size (minimum/optimal): 524288 bytes / 1572864 bytes
Disk identifier: 0x00000000
Disk /dev/md0 doesn't contain a valid partition table
Testdisk /dev/md0 responds
Disk /dev/md0 - 9001 GB / 8383 GiB - CHS 2197600128 2 4
Trying alternate GPT
A deep search gives me some MS partitions but they are for a 6001GB build that was what the Raid was before when it was a 3x3TB Raid. Pressing L to list files brings up nothing.
See also viewtopic.php?f=7&t=6824
Not sure where to go now.
