Dear all
I have make a mistake in the selection which partition to recover an end it up with empty
NTFS partition.
Deep search gives the same results with the same partition.
I have writen driver for some specific hardware on that disk.
What to do?
Thanks.
Recovering partition after wrong selection in Testdisk
Re: Recovering partition after wrong selection in Testdisk
Deeper Search should find the same partitions than previously...
In the worst case, it's always possible to use PhotoRec.
Thanks deep search
result is the same. Almos empty partition.
How to recover it and bootin the
Wim 7?
Wim 7?
