What a wonderful resource this site is, have learned a great deal in the last days.
2TB Lacie Rugged Thunderbolt/USB3 exFAT Drive (storage only, no boot) not being recognised by Windows10 or OSX machines - needs to "format/initialise". This occurred after a "safe" eject from OSX, having copied some files onto the drive.
S.M.A.R.T shows CRC errors.
TestDisk lists disk size correctly and can see the partition - can even browse the files although get a lot of failures when attempting to bulk copy, resulting in huge files (>200gb) with unreadable names.
I can set partition to (P)rimary, Write, Reboot, no change. I have done this many times now, perhaps hoping for a different result.
Here is log file from recent partition table rewrite, could someone cleverer than me have a look and see perhaps why this isn't working?
Sat Feb 4 18:17:25 2017
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499514343424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=2000398932992
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1ER164, S/N:W4Z16GYV, FW:CC25
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 850 EVO 500GB, S/N:S2RBNB0HB58876P, FW:EMT02B6Q
Disk /dev/sdc - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD40EZRZ-00WN9B0, S/N:WD-WCC4E4TFH60U, FW:80.00A80
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - LaCie Rugged THB USB3, S/N:CB5001016051, FW:1153
Disk /dev/sdd - 2000 GB / 1863 GiB - LaCie Rugged THB USB3
Analyse Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63
1 P HPFS - NTFS 0 0 3 243201 80 63 3907029166
exFAT, blocksize=131072, 2000 GB / 1863 GiB
file_pread(7,16,buffer,3907029168(243201/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(7,1,buffer,3907029168(243201/81/1)) ReadFile The drive cannot find the sector requested.
file_pread(7,8,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(7,3,buffer,3907029184(243201/81/17)) lseek err Invalid argument
file_pread(7,3,buffer,3907029231(243201/82/1)) lseek err Invalid argument
file_pread(7,8,buffer,3907029247(243201/82/17)) lseek err Invalid argument
file_pread(7,11,buffer,3907029294(243201/83/1)) lseek err Invalid argument
file_pread(7,2,buffer,3907031216(243201/113/33)) lseek err Invalid argument
* HPFS - NTFS 0 0 3 243201 80 63 3907029166
Failing to repair 2TB exfat USB drive
Re: Failing to repair 2TB exfat USB drive
Clone your disk to a new empty disk using ddrescue.
Read https://www.cgsecurity.org/testdisk.pdf chapter "DDRescue: data recovery from damaged disk" and "Creating a live USB".
Once it's done, remove the damaged disk and try again to recover your data.
MikatAudio
Thank you for your time in replying Christophe, much appreciated.
I'll get a replacement drive on order, and have a go restoring my image onto that before I give up completely.
I suppose this also means that the damaged partition drive is toast?
