recover partitions
mesapesa
recover partitions
#1 Post by mesapesa »
i lost my win7 and ubuntu mate installation when i try to shrink some data from win7 partition to be able to use as swap,in the process i lost my access to both my os and i'm currently at no boot disk error
my gparted and testdisk results are attached and the fdisk -l output is given below
how to recover atleast my win7 i can reinstall my linux installation from scratch with additional swap and home partitions.
ThankYou
it@it:~$ sudo fdisk -l
Disk /dev/ram0: 64 MiB, 67108864 bytes, 131072 sectors
Units: sectors of 1 * 512 = 512 bytes
Disk /dev/ram1: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram2: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram3: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram4: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram5: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram6: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram7: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram8: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram9: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram10: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram11: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram12: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram13: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram14: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram15: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/loop0: 1.5 GiB, 1593864192 bytes, 3113016 sectors
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Disklabel type: dos
Disk identifier: 0x4a5c2cb0
Device     Boot     Start       End   Sectors  Size Id Type
/dev/sda1            2048   1026047   1024000  500M  7 HPFS/NTFS/exFAT
/dev/sda2         1026048 146831359 145805312 69.5G  7 HPFS/NTFS/exFAT
/dev/sda3       146834163 188763749  41929587   20G  7 HPFS/NTFS/exFAT
Partition 3 does not start on physical sector boundary.
Disk /dev/sdb: 7.5 GiB, 8004304896 bytes, 15633408 sectors
Disklabel type: dos
Disk identifier: 0x003cbe50
/dev/sdb1  *     2048 15633407 15631360  7.5G  b W95 FAT32
Re: recover partitions
For each NTFS partition, use "p" to list the files. Once you have found the correct partition, use the arrow keys to switch the partition to P(rimary) or L(ogical).
Once you have selected all the partitions to keep/recover, go on next screen and choose Write, confirm, Quit and restart your computer.
mesapesa
#3 Post by mesapesa »
if i set first 3 ntfs partition on P and the remaing on L and write will this work
and where to set it on extended volume or is it not necessary
mesapesa
#4 Post by mesapesa »
is this ok
TESTDISK FINAL.png (77.51 KiB) Viewed 4911 times
mesapesa
#5 Post by mesapesa »
here is the testdisk.log file
Tue Feb 14 03:39:14 2017
OS: Linux, kernel 4.4.0-31-generic (#50-Ubuntu SMP Wed Jul 13 00:07:12 UTC 2016) x86_64
Compiler: GCC 5.3
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size       1953525168 sectors
/dev/sda: user_max   1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco        1953525168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZRX-00L4HB0, S/N:WD-WCC4JRAJ8HZZ, FW:01.01A01
Disk /dev/sdb - 8004 MB / 7633 MiB - CHS 1020 247 62, sector size=512 - SanDisk Cruzer Blade, FW:1.27
Disk /dev/sda - 1000 GB / 931 GiB - WDC WD10EZRX-00L4HB0
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
NTFS at 63/221/31
NTFS at 9140/1/1
 1 P HPFS - NTFS              0  32 33    63 221 30    1024000
 2 P HPFS - NTFS             63 221 31  9139 211 32  145805312
 3 P HPFS - NTFS           9140   1  1 11749 254 63   41929587
NTFS at 0/32/33
filesystem size           1024000
sectors_per_cluster       8
mft_lcn                   42666
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 524 MB / 500 MiB
NTFS at 63/221/31
filesystem size           145805312
mftmirr_lcn               2
     NTFS, blocksize=4096, 74 GB / 69 GiB
NTFS at 9140/1/1
filesystem size           41929587
mft_lcn                   3
mftmirr_lcn               2620599
     NTFS, blocksize=4096, 21 GB / 19 GiB
recover_EXT2: s_block_group_nr=0/79, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 2617920
recover_EXT2: part_size 20943360
     Linux                11750 136 35 13054  50 52   20943360
     ext4 blocksize=4096 Large_file Sparse_SB, 10723 MB / 10226 MiB
NTFS at 13054/75/14
filesystem size           209715200
mftmirr_lcn               2
     HPFS - NTFS          13054  75 14 26108 117 57  209715200
     NTFS, blocksize=4096, 107 GB / 100 GiB
NTFS at 26108/150/27
mftmirr_lcn               2
     HPFS - NTFS          26108 150 27 39162 193  7  209715200
NTFS at 39162/225/40
filesystem size           419430400
mftmirr_lcn               2
     HPFS - NTFS          39162 225 40 65271  56  1  419430400
     NTFS, blocksize=4096, 214 GB / 200 GiB
NTFS at 65271/88/34
mftmirr_lcn               2
     HPFS - NTFS          65271  88 34 91379 173 58  419430400
NTFS at 91379/206/28
filesystem size           485505024
mftmirr_lcn               2
     HPFS - NTFS          91379 206 28 121601  25 24  485505024
     NTFS, blocksize=4096, 248 GB / 231 GiB
     Linux                11750 136 35 13054  75 13   20944896
     ext4 blocksize=4096 Large_file Sparse_SB, 10723 MB / 10227 MiB
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 1024000 linear /dev/sda 2048" | dmsetup create test0
echo "0 145805312 linear /dev/sda 1026048" | dmsetup create test1
echo "0 41929587 linear /dev/sda 146834163" | dmsetup create test2
echo "0 20944896 linear /dev/sda 188772352" | dmsetup create test3
echo "0 209715200 linear /dev/sda 209717248" | dmsetup create test4
echo "0 209715200 linear /dev/sda 419434496" | dmsetup create test5
echo "0 419430400 linear /dev/sda 629151744" | dmsetup create test6
echo "0 419430400 linear /dev/sda 1048584192" | dmsetup create test7
echo "0 485505024 linear /dev/sda 1468016640" | dmsetup create test8
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 12-Feb-2017 15:27 .
       5 dr-xr-xr-x     0      0         0 12-Feb-2017 15:27 ..
      57 dr-xr-xr-x     0      0         0 30-Mar-2016 07:12 $Recycle.Bin
    5321 dr-xr-xr-x     0      0         0 12-Feb-2017 15:24 6awrap68
  149112 dr-xr-xr-x     0      0         0 29-Nov-2016 16:11 6b2a0d656378b8604969199d
   98894 dr-xr-xr-x     0      0         0 24-Aug-2016 05:13 AnuSM
     183 dr-xr-xr-x     0      0         0 19-Jan-2017 14:58 Boot
  148050 dr-xr-xr-x     0      0         0 12-Feb-2017 14:55 Config.Msi
  103844 dr-xr-xr-x     0      0         0  9-Jan-2017 13:16 CryptoPreventQuarantine
   97601 dr-xr-xr-x     0      0         0 28-Feb-2016 13:36 Intel
   85184 dr-xr-xr-x     0      0         0  4-Mar-2016 07:35 LJM1005_MFP_Full_Solution
   85829 dr-xr-xr-x     0      0         0 29-Feb-2016 15:34 MSOCache
   96128 dr-xr-xr-x     0      0         0  8-Feb-2017 13:51 NST
      58 dr-xr-xr-x     0      0         0 14-Jul-2009 03:20 PerfLogs
      60 dr-xr-xr-x     0      0         0  9-Feb-2017 14:50 Program Files
     274 dr-xr-xr-x     0      0         0  1-Feb-2017 04:19 Program Files (x86)
     392 dr-xr-xr-x     0      0         0 12-Feb-2017 15:28 ProgramData
   84284 dr-xr-xr-x     0      0         0 30-Apr-2016 13:12 Recovery
   84904 dr-xr-xr-x     0      0         0 12-Feb-2017 14:41 System Volume Information
     496 dr-xr-xr-x     0      0         0 12-Feb-2017 15:24 Users
     686 dr-xr-xr-x     0      0         0  5-Feb-2017 14:35 Windows
  148066 dr-xr-xr-x     0      0         0  1-Dec-2016 10:16 XiaoMi
   24069 dr-xr-xr-x     0      0         0 12-Feb-2017 15:24 Ypackage69
  135163 dr-xr-xr-x     0      0         0 27-May-2016 15:29 adb
  135454 dr-xr-xr-x     0      0         0 29-Nov-2016 14:40 cb0430bfb0222b7d1b88378a
  156489 dr-xr-xr-x     0      0         0  1-Dec-2016 11:34 mi
  103304 -r--r--r--     0      0      1024  8-Jun-2016 13:10 AMTAG.BIN
   94675 -r--r--r--     0      0    274596  8-Feb-2017 13:51 ANG0
   85448 -r--r--r--     0      0    274596 29-Feb-2016 07:31 ANG0.tmp
   84100 -r--r--r--     0      0    271158  1-Aug-2016 11:23 DUMP3004.tmp
   86154 -r--r--r--     0      0    272150  1-Aug-2016 11:36 DUMP642e.tmp
   97685 -r--r--r--     0      0    361868  8-Feb-2017 13:03 LEOPT
   86212 -r--r--r--     0      0    446865  3-Feb-2017 15:15 MXLUE
  155774 -r--r--r--     0      0      1521 29-Nov-2016 15:17 MicRooCerAut2011_2011_03_22.crt
   90841 -r--r--r--     0      0    441601 30-Apr-2016 00:04 NMIBK
  139523 -r--r--r--     0      0    464888  6-Feb-2017 12:29 PSZWB
   24484 -r--r--r--     0      0    393991 31-Jan-2017 15:10 PUBOF
   91082 -r--r--r--     0      0    449226 20-Aug-2016 23:01 QBLVU
  138441 -r--r--r--     0      0    298243  6-Feb-2017 08:31 ZWONT
    1279 -r--r--r--     0      0         0 19-Jan-2017 14:58 asc_rdflag
   85315 -r--r--r--     0      0    383786 21-Nov-2010 03:23 bootmgr
   85384 -r--r--r--     0      0    383786 29-Feb-2016 07:08 bootmgr.tmp
      20 -r--r--r--     0      0     10168 24-Nov-2016 10:53 bootsqm.dat
   87442 -r--r--r--     0      0 3453214720 12-Feb-2017 15:24 pagefile.sys
     189 dr-xr-xr-x     0      0         0 13-May-2016 02:59 $RECYCLE.BIN
     197 dr-xr-xr-x     0      0         0 12-Feb-2017 15:24 Adocuments11
      35 dr-xr-xr-x     0      0         0 29-Feb-2016 00:31 Boot
     106 dr-xr-xr-x     0      0         0  5-Mar-2016 13:45 Kaspersky Rescue Disk 10.0
     196 dr-xr-xr-x     0      0         0 30-May-2016 03:11 Program Files
     101 dr-xr-xr-x     0      0         0 29-Feb-2016 20:57 Recovery
      97 dr-xr-xr-x     0      0         0 29-Feb-2016 00:33 System Volume Information
     208 dr-xr-xr-x     0      0         0 12-Feb-2017 15:24 Tstore62
      96 -r--r--r--     0      0      8192 29-Feb-2016 00:31 BOOTSECT.BAK
      99 -r--r--r--     0      0    405508 28-Apr-2016 10:55 RPIYN
     188 -r--r--r--     0      0         0 30-Apr-2016 12:54 Recovery.txt
      85 -r--r--r--     0      0    383786 21-Nov-2010 03:23 bootmgr
mesapesa
#6 Post by mesapesa »
after setting every thing above as shown in the above picture ihave now recovered everything is working ok except the linux which i will to reinstall again.Thankyou all for the help.
