I Have this problem
UnnamedName
I Have this problem
#1 Post by UnnamedName »
Hello, I used your program to recover my files from a partition that was on my hard drive.
I did all the steps that the page showed, but once I restart my computer, this appears
I do not know what this is, but as you did the program, I need you to help me as this equipment is very important to have.
Please reply later.
PD: I used Google Translate.
Re: I Have this problem
The wrong partition may have been set as *(bootable). You can use testdisk again ot use fdisk to change the active partition.
