lost access to external drive
tukan
#1 Post by tukan »
I cannot access my external drive anymore. I can see it under My Computer but I cannot get into it. With TestDisk I am now trying to fix it.
My colleague told me it could be an issue with partition but I am not sure now after giving it some try. It might be sth with boot sector or data file system.
I followed instructions from some posts and did Quick Search and Deeper Search, I tried to go through Advanced as well (but did not see Boot and Rebuild BS options). I am not advanced on it and was really trying things but did not find a post describing exactly the same issue that I have and cannot figure it out myself.
Can you please help me? Please find below the testdisk.log.
Mon Feb 20 20:30:56 2017
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=200043134976
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=277395537920
filewin32_getfilesize(\\.\E:) GetFileSize err Niepoprawna funkcja.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Niepoprawna funkcja.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500105216512
Drive C: - 200 GB / 186 GiB - CHS 24320 255 63, sector size=512
Drive D: - 277 GB / 258 GiB - CHS 33724 255 63, sector size=512
Drive F: - 500 GB / 465 GiB - CHS 60800 255 63, sector size=512
Analyse Drive F: - 500 GB / 465 GiB - CHS 60800 255 63
Geometry from i386 MBR: head=102 sector=46
BAD_RS LBA=1936028272 1869871
check_part_i386 1 type 68: no test
BAD_RS LBA=1330184192 5737263
check_part_i386 2 type 79: no test
BAD_RS LBA=538989391 5544459
check_part_i386 3 type 53: no test
BAD_RS LBA=1394627663 1397717
check_part_i386 4 type 49: no test
1 * Novell 120512 47 32 235785 20 46 1851859059
Bad relative sector.
2 * Sys=79 82800 34 51 116349 218 61 538976288
3 * OnTrack DM WO ??? 33550 137 11 120594 153 54 1398362912
4 * Sys=49 86811 142 3 86812 225 45 21337
FAT32 at 0/0/7
FAT1 : 32-119231
FAT2 : 119232-238431
start_rootdir : 238432 root cluster : 2
Data : 238432-976724831
sectors : 976724832
cluster_size : 64
no_of_cluster : 15257600 (2 - 15257601)
fat_length 119200 calculated 119201
file_win32_pread(108,16,buffer,83064832(5170/139/26)) read err: read after end of file
file_win32_pread(108,16,buffer,83077120(5171/79/29)) read err: read after end of file
file_win32_pread(108,1,buffer,83077121(5171/79/30)) read err: read after end of file
file_win32_pread(108,16,buffer,83077119(5171/79/28)) read err: read after end of file
file_win32_pread(108,16,buffer,83077122(5171/79/31)) read err: read after end of file
file_win32_pread(108,1,buffer,83077129(5171/79/38)) read err: read after end of file
file_win32_pread(108,6,buffer,83077130(5171/79/39)) read err: read after end of file
file_win32_pread(108,16,buffer,83077183(5171/80/29)) read err: read after end of file
file_win32_pread(108,1,buffer,83077185(5171/80/31)) read err: read after end of file
file_win32_pread(108,16,buffer,83087360(5171/241/63)) read err: read after end of file
file_win32_pread(108,1,buffer,83087360(5171/241/63)) read err: read after end of file
file_win32_pread(108,16,buffer,83087361(5171/242/1)) read err: read after end of file
file_win32_pread(108,1,buffer,83087361(5171/242/1)) read err: read after end of file
file_win32_pread(108,14,buffer,83087362(5171/242/2)) read err: read after end of file
file_win32_pread(108,16,buffer,83087423(5171/242/63)) read err: read after end of file
file_win32_pread(108,16,buffer,83087439(5171/243/16)) read err: read after end of file
file_win32_pread(108,1,buffer,83087445(5171/243/22)) read err: read after end of file
file_win32_pread(108,16,buffer,83089408(5172/19/32)) read err: read after end of file
file_win32_pread(108,1,buffer,83089408(5172/19/32)) read err: read after end of file
file_win32_pread(108,1,buffer,83087366(5171/242/6)) read err: read after end of file
file_win32_pread(108,2,buffer,83087427(5171/243/4)) read err: read after end of file
file_win32_pread(108,16,buffer,83089407(5172/19/31)) read err: read after end of file
file_win32_pread(108,1,buffer,83089407(5172/19/31)) read err: read after end of file
file_win32_pread(108,16,buffer,83089410(5172/19/34)) read err: read after end of file
file_win32_pread(108,1,buffer,83089415(5172/19/39)) read err: read after end of file
file_win32_pread(108,8,buffer,83089416(5172/19/40)) read err: read after end of file
file_win32_pread(108,3,buffer,83089424(5172/19/48)) read err: read after end of file
file_win32_pread(108,16,buffer,83089487(5172/20/48)) read err: read after end of file
file_win32_pread(108,16,buffer,83091582(5172/54/1)) read err: read after end of file
file_win32_pread(108,1,buffer,83091587(5172/54/6)) read err: read after end of file
file_win32_pread(108,16,buffer,83093519(5172/84/48)) read err: read after end of file
file_win32_pread(108,16,buffer,83093520(5172/84/49)) read err: read after end of file
file_win32_pread(108,16,buffer,83095615(5172/118/2)) read err: read after end of file
file_win32_pread(108,16,buffer,83095631(5172/118/18)) read err: read after end of file
file_win32_pread(108,16,buffer,83095678(5172/119/2)) read err: read after end of file
file_win32_pread(108,1,buffer,83095680(5172/119/4)) read err: read after end of file
file_win32_pread(108,16,buffer,83097599(5172/149/33)) read err: read after end of file
file_win32_pread(108,16,buffer,84118388(5236/32/33)) read err: read after end of file
file_win32_pread(108,16,buffer,84118451(5236/33/33)) read err: read after end of file
file_win32_pread(108,16,buffer,84119552(5236/50/63)) read err: read after end of file
file_win32_pread(108,16,buffer,84119551(5236/50/62)) read err: read after end of file
file_win32_pread(108,1,buffer,84119551(5236/50/62)) read err: read after end of file
file_win32_pread(108,14,buffer,84119554(5236/51/2)) read err: read after end of file
file_win32_pread(108,3,buffer,84119568(5236/51/16)) read err: read after end of file
file_win32_pread(108,16,buffer,84119631(5236/52/16)) read err: read after end of file
file_win32_pread(108,16,buffer,84120168(5236/60/49)) read err: read after end of file
file_win32_pread(108,1,buffer,84120168(5236/60/49)) read err: read after end of file
file_win32_pread(108,2,buffer,84120231(5236/61/49)) read err: read after end of file
file_win32_pread(108,16,buffer,84125759(5236/149/33)) read err: read after end of file
file_win32_pread(108,16,buffer,84125775(5236/149/49)) read err: read after end of file
file_win32_pread(108,1,buffer,84125776(5236/149/50)) read err: read after end of file
file_win32_pread(108,11,buffer,84125822(5236/150/33)) read err: read after end of file
file_win32_pread(108,16,buffer,84127823(5236/182/18)) read err: read after end of file
file_win32_pread(108,16,buffer,84127870(5236/183/2)) read err: read after end of file
file_win32_pread(108,16,buffer,84129792(5236/213/34)) read err: read after end of file
file_win32_pread(108,16,buffer,84129791(5236/213/33)) read err: read after end of file
file_win32_pread(108,16,buffer,84129794(5236/213/36)) read err: read after end of file
file_win32_pread(108,16,buffer,84129808(5236/213/50)) read err: read after end of file
file_win32_pread(108,16,buffer,84129855(5236/214/34)) read err: read after end of file
file_win32_pread(108,16,buffer,84129871(5236/214/50)) read err: read after end of file
file_win32_pread(108,1,buffer,84129874(5236/214/53)) read err: read after end of file
file_win32_pread(108,11,buffer,84129918(5236/215/34)) read err: read after end of file
file_win32_pread(108,16,buffer,84129798(5236/213/40)) read err: read after end of file
file_win32_pread(108,16,buffer,84131715(5236/244/4)) read err: read after end of file
file_win32_pread(108,1,buffer,84131715(5236/244/4)) read err: read after end of file
file_win32_pread(108,16,buffer,84132547(5237/2/17)) read err: read after end of file
file_win32_pread(108,16,buffer,84132594(5237/3/1)) read err: read after end of file
file_win32_pread(108,16,buffer,84142080(5237/153/37)) read err: read after end of file
file_win32_pread(108,16,buffer,84142079(5237/153/36)) read err: read after end of file
file_win32_pread(108,16,buffer,84142082(5237/153/39)) read err: read after end of file
file_win32_pread(108,1,buffer,84142087(5237/153/44)) read err: read after end of file
file_win32_pread(108,16,buffer,84142096(5237/153/53)) read err: read after end of file
file_win32_pread(108,1,buffer,84142096(5237/153/53)) read err: read after end of file
file_win32_pread(108,16,buffer,84146255(5237/219/54)) read err: read after end of file
file_win32_pread(108,16,buffer,84147717(5237/243/4)) read err: read after end of file
file_win32_pread(108,16,buffer,84149555(5238/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,84156432(5238/126/25)) read err: read after end of file
file_win32_pread(108,16,buffer,91490304(5695/2/4)) read err: read after end of file
file_win32_pread(108,16,buffer,91489548(5694/245/4)) read err: read after end of file
file_win32_pread(108,16,buffer,91490174(5694/254/63)) read err: read after end of file
file_win32_pread(108,16,buffer,91490175(5695/0/1)) read err: read after end of file
file_win32_pread(108,1,buffer,91490175(5695/0/1)) read err: read after end of file
file_win32_pread(108,15,buffer,91490176(5695/0/2)) read err: read after end of file
file_win32_pread(108,3,buffer,91490191(5695/0/17)) read err: read after end of file
file_win32_pread(108,3,buffer,91490238(5695/1/1)) read err: read after end of file
file_win32_pread(108,16,buffer,91490301(5695/2/1)) read err: read after end of file
file_win32_pread(108,1,buffer,91490301(5695/2/1)) read err: read after end of file
file_win32_pread(108,2,buffer,91492223(5695/32/33)) read err: read after end of file
file_win32_pread(108,13,buffer,91490241(5695/1/4)) read err: read after end of file
file_win32_pread(108,16,buffer,91490317(5695/2/17)) read err: read after end of file
file_win32_pread(108,1,buffer,91490320(5695/2/20)) read err: read after end of file
file_win32_pread(108,11,buffer,91490364(5695/3/1)) read err: read after end of file
file_win32_pread(108,16,buffer,91490305(5695/2/5)) read err: read after end of file
file_win32_pread(108,1,buffer,91490305(5695/2/5)) read err: read after end of file
file_win32_pread(108,14,buffer,91490306(5695/2/6)) read err: read after end of file
file_win32_pread(108,2,buffer,91490321(5695/2/21)) read err: read after end of file
file_win32_pread(108,8,buffer,91490383(5695/3/20)) read err: read after end of file
file_win32_pread(108,11,buffer,91490430(5695/4/4)) read err: read after end of file
file_win32_pread(108,16,buffer,91491134(5695/15/15)) read err: read after end of file
file_win32_pread(108,1,buffer,91491134(5695/15/15)) read err: read after end of file
file_win32_pread(108,2,buffer,91491197(5695/16/15)) read err: read after end of file
file_win32_pread(108,2,buffer,91491260(5695/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,91492370(5695/34/54)) read err: read after end of file
file_win32_pread(108,16,buffer,91492415(5695/35/36)) read err: read after end of file
file_win32_pread(108,1,buffer,91492415(5695/35/36)) read err: read after end of file
file_win32_pread(108,8,buffer,91492431(5695/35/52)) read err: read after end of file
file_win32_pread(108,11,buffer,91492478(5695/36/36)) read err: read after end of file
file_win32_pread(108,16,buffer,91494003(5695/60/49)) read err: read after end of file
file_win32_pread(108,1,buffer,91494003(5695/60/49)) read err: read after end of file
file_win32_pread(108,16,buffer,91494129(5695/62/49)) read err: read after end of file
file_win32_pread(108,1,buffer,91494130(5695/62/50)) read err: read after end of file
file_win32_pread(108,16,buffer,91494402(5695/67/7)) read err: read after end of file
file_win32_pread(108,1,buffer,91494408(5695/67/13)) read err: read after end of file
file_win32_pread(108,7,buffer,91494409(5695/67/14)) read err: read after end of file
file_win32_pread(108,16,buffer,91494463(5695/68/5)) read err: read after end of file
file_win32_pread(108,1,buffer,91494463(5695/68/5)) read err: read after end of file
file_win32_pread(108,8,buffer,91494479(5695/68/21)) read err: read after end of file
file_win32_pread(108,11,buffer,91494526(5695/69/5)) read err: read after end of file
file_win32_pread(108,16,buffer,91496447(5695/99/36)) read err: read after end of file
file_win32_pread(108,16,buffer,91496450(5695/99/39)) read err: read after end of file
file_win32_pread(108,1,buffer,91496457(5695/99/46)) read err: read after end of file
file_win32_pread(108,6,buffer,91496458(5695/99/47)) read err: read after end of file
file_win32_pread(108,3,buffer,91496464(5695/99/53)) read err: read after end of file
file_win32_pread(108,16,buffer,91496527(5695/100/53)) read err: read after end of file
file_win32_pread(108,16,buffer,91496574(5695/101/37)) read err: read after end of file
file_win32_pread(108,1,buffer,91496574(5695/101/37)) read err: read after end of file
file_win32_pread(108,16,buffer,91496454(5695/99/43)) read err: read after end of file
file_win32_pread(108,16,buffer,91498495(5695/132/5)) read err: read after end of file
file_win32_pread(108,16,buffer,91498498(5695/132/8)) read err: read after end of file
file_win32_pread(108,16,buffer,91498559(5695/133/6)) read err: read after end of file
file_win32_pread(108,16,buffer,91498575(5695/133/22)) read err: read after end of file
file_win32_pread(108,1,buffer,91498579(5695/133/26)) read err: read after end of file
file_win32_pread(108,11,buffer,91498622(5695/134/6)) read err: read after end of file
file_win32_pread(108,16,buffer,91500559(5695/164/53)) read err: read after end of file
file_win32_pread(108,16,buffer,91500560(5695/164/54)) read err: read after end of file
file_win32_pread(108,1,buffer,91500562(5695/164/56)) read err: read after end of file
file_win32_pread(108,3,buffer,91500607(5695/165/38)) read err: read after end of file
file_win32_pread(108,8,buffer,91500623(5695/165/54)) read err: read after end of file
file_win32_pread(108,11,buffer,91500670(5695/166/38)) read err: read after end of file
file_win32_pread(108,2,buffer,91502592(5695/197/7)) read err: read after end of file
file_win32_pread(108,16,buffer,91502594(5695/197/9)) read err: read after end of file
file_win32_pread(108,1,buffer,91502595(5695/197/10)) read err: read after end of file
file_win32_pread(108,8,buffer,91502600(5695/197/15)) read err: read after end of file
file_win32_pread(108,16,buffer,91502655(5695/198/7)) read err: read after end of file
file_win32_pread(108,1,buffer,91502656(5695/198/8)) read err: read after end of file
file_win32_pread(108,8,buffer,91502671(5695/198/23)) read err: read after end of file
file_win32_pread(108,11,buffer,91502718(5695/199/7)) read err: read after end of file
file_win32_pread(108,16,buffer,91502598(5695/197/13)) read err: read after end of file
file_win32_pread(108,1,buffer,91502598(5695/197/13)) read err: read after end of file
file_win32_pread(108,16,buffer,91504642(5695/229/41)) read err: read after end of file
file_win32_pread(108,1,buffer,91504647(5695/229/46)) read err: read after end of file
file_win32_pread(108,8,buffer,91504648(5695/229/47)) read err: read after end of file
file_win32_pread(108,16,buffer,91504703(5695/230/39)) read err: read after end of file
file_win32_pread(108,1,buffer,91504703(5695/230/39)) read err: read after end of file
file_win32_pread(108,8,buffer,91504719(5695/230/55)) read err: read after end of file
file_win32_pread(108,11,buffer,91504766(5695/231/39)) read err: read after end of file
file_win32_pread(108,16,buffer,91505487(5695/243/4)) read err: read after end of file
file_win32_pread(108,16,buffer,91505550(5695/244/4)) read err: read after end of file
file_win32_pread(108,16,buffer,91505613(5695/245/4)) read err: read after end of file
file_win32_pread(108,16,buffer,91506239(5695/254/63)) read err: read after end of file
file_win32_pread(108,16,buffer,91506240(5696/0/1)) read err: read after end of file
file_win32_pread(108,16,buffer,91506241(5696/0/2)) read err: read after end of file
file_win32_pread(108,1,buffer,91506241(5696/0/2)) read err: read after end of file
file_win32_pread(108,16,buffer,91506256(5696/0/17)) read err: read after end of file
file_win32_pread(108,1,buffer,91506257(5696/0/18)) read err: read after end of file
file_win32_pread(108,3,buffer,91506303(5696/1/1)) read err: read after end of file
file_win32_pread(108,8,buffer,91506319(5696/1/17)) read err: read after end of file
file_win32_pread(108,11,buffer,91506366(5696/2/1)) read err: read after end of file
file_win32_pread(108,16,buffer,91506246(5696/0/7)) read err: read after end of file
file_win32_pread(108,16,buffer,91506306(5696/1/4)) read err: read after end of file
file_win32_pread(108,1,buffer,91506306(5696/1/4)) read err: read after end of file
file_win32_pread(108,8,buffer,91506311(5696/1/9)) read err: read after end of file
file_win32_pread(108,8,buffer,91506382(5696/2/17)) read err: read after end of file
file_win32_pread(108,11,buffer,91506429(5696/3/1)) read err: read after end of file
file_win32_pread(108,2,buffer,91508351(5696/33/33)) read err: read after end of file
file_win32_pread(108,16,buffer,91506687(5696/7/7)) read err: read after end of file
file_win32_pread(108,16,buffer,91506688(5696/7/8)) read err: read after end of file
file_win32_pread(108,16,buffer,91506689(5696/7/9)) read err: read after end of file
file_win32_pread(108,16,buffer,91506690(5696/7/10)) read err: read after end of file
file_win32_pread(108,1,buffer,91506693(5696/7/13)) read err: read after end of file
file_win32_pread(108,8,buffer,91506696(5696/7/16)) read err: read after end of file
file_win32_pread(108,16,buffer,91506751(5696/8/8)) read err: read after end of file
file_win32_pread(108,1,buffer,91506752(5696/8/9)) read err: read after end of file
file_win32_pread(108,8,buffer,91506767(5696/8/24)) read err: read after end of file
file_win32_pread(108,11,buffer,91506814(5696/9/8)) read err: read after end of file
file_win32_pread(108,16,buffer,91506694(5696/7/14)) read err: read after end of file
file_win32_pread(108,1,buffer,91506694(5696/7/14)) read err: read after end of file
file_win32_pread(108,16,buffer,91507262(5696/16/15)) read err: read after end of file
file_win32_pread(108,1,buffer,91507263(5696/16/16)) read err: read after end of file
file_win32_pread(108,16,buffer,91508735(5696/39/39)) read err: read after end of file
file_win32_pread(108,16,buffer,91508738(5696/39/42)) read err: read after end of file
file_win32_pread(108,1,buffer,91508738(5696/39/42)) read err: read after end of file
file_win32_pread(108,8,buffer,91508744(5696/39/48)) read err: read after end of file
file_win32_pread(108,16,buffer,91508799(5696/40/40)) read err: read after end of file
file_win32_pread(108,1,buffer,91508801(5696/40/42)) read err: read after end of file
file_win32_pread(108,8,buffer,91508815(5696/40/56)) read err: read after end of file
file_win32_pread(108,11,buffer,91508862(5696/41/40)) read err: read after end of file
file_win32_pread(108,16,buffer,91508742(5696/39/46)) read err: read after end of file
file_win32_pread(108,1,buffer,91508742(5696/39/46)) read err: read after end of file
file_win32_pread(108,16,buffer,91510131(5696/61/49)) read err: read after end of file
file_win32_pread(108,1,buffer,91510131(5696/61/49)) read err: read after end of file
file_win32_pread(108,16,buffer,91510783(5696/72/8)) read err: read after end of file
file_win32_pread(108,16,buffer,91510786(5696/72/11)) read err: read after end of file
file_win32_pread(108,1,buffer,91510786(5696/72/11)) read err: read after end of file
file_win32_pread(108,16,buffer,91510800(5696/72/25)) read err: read after end of file
file_win32_pread(108,1,buffer,91510801(5696/72/26)) read err: read after end of file
file_win32_pread(108,3,buffer,91510847(5696/73/9)) read err: read after end of file
file_win32_pread(108,8,buffer,91510863(5696/73/25)) read err: read after end of file
file_win32_pread(108,11,buffer,91510910(5696/74/9)) read err: read after end of file
file_win32_pread(108,2,buffer,91512832(5696/104/41)) read err: read after end of file
file_win32_pread(108,1,buffer,91510790(5696/72/15)) read err: read after end of file
file_win32_pread(108,1,buffer,91512831(5696/104/40)) read err: read after end of file
file_win32_pread(108,14,buffer,91512834(5696/104/43)) read err: read after end of file
file_win32_pread(108,3,buffer,91512848(5696/104/57)) read err: read after end of file
file_win32_pread(108,3,buffer,91512895(5696/105/41)) read err: read after end of file
file_win32_pread(108,8,buffer,91512911(5696/105/57)) read err: read after end of file
file_win32_pread(108,11,buffer,91512958(5696/106/41)) read err: read after end of file
file_win32_pread(108,2,buffer,91514880(5696/137/10)) read err: read after end of file
file_win32_pread(108,1,buffer,91514879(5696/137/9)) read err: read after end of file
file_win32_pread(108,14,buffer,91514882(5696/137/12)) read err: read after end of file
file_win32_pread(108,3,buffer,91514896(5696/137/26)) read err: read after end of file
file_win32_pread(108,3,buffer,91514943(5696/138/10)) read err: read after end of file
file_win32_pread(108,8,buffer,91514959(5696/138/26)) read err: read after end of file
file_win32_pread(108,11,buffer,91515006(5696/139/10)) read err: read after end of file
file_win32_pread(108,2,buffer,91516928(5696/169/42)) read err: read after end of file
file_win32_pread(108,1,buffer,91516927(5696/169/41)) read err: read after end of file
file_win32_pread(108,14,buffer,91516930(5696/169/44)) read err: read after end of file
file_win32_pread(108,3,buffer,91516944(5696/169/58)) read err: read after end of file
file_win32_pread(108,3,buffer,91516991(5696/170/42)) read err: read after end of file
file_win32_pread(108,8,buffer,91517007(5696/170/58)) read err: read after end of file
file_win32_pread(108,11,buffer,91517054(5696/171/42)) read err: read after end of file
file_win32_pread(108,16,buffer,136969563(8525/245/4)) read err: read after end of file
file_win32_pread(108,16,buffer,136971149(8526/15/15)) read err: read after end of file
file_win32_pread(108,1,buffer,136971150(8526/15/16)) read err: read after end of file
file_win32_pread(108,2,buffer,136971212(8526/16/15)) read err: read after end of file
file_win32_pread(108,2,buffer,136971275(8526/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,136972367(8526/34/36)) read err: read after end of file
file_win32_pread(108,1,buffer,136972370(8526/34/39)) read err: read after end of file
file_win32_pread(108,16,buffer,136974336(8526/65/52)) read err: read after end of file
file_win32_pread(108,16,buffer,145999951(9088/19/35)) read err: read after end of file
file_win32_pread(108,16,buffer,145999998(9088/20/19)) read err: read after end of file
file_win32_pread(108,1,buffer,146000004(9088/20/25)) read err: read after end of file
file_win32_pread(108,16,buffer,202979407(12634/225/23)) read err: read after end of file
file_win32_pread(108,16,buffer,202979454(12634/226/7)) read err: read after end of file
file_win32_pread(108,1,buffer,202979462(12634/226/15)) read err: read after end of file
file_win32_pread(108,16,buffer,210451499(13099/254/63)) read err: read after end of file
file_win32_pread(108,16,buffer,212222604(13210/62/49)) read err: read after end of file
file_win32_pread(108,16,buffer,214001175(13320/244/4)) read err: read after end of file
file_win32_pread(108,16,buffer,262074368(16313/95/39)) read err: read after end of file
file_win32_pread(108,16,buffer,262074367(16313/95/38)) read err: read after end of file
file_win32_pread(108,16,buffer,262074370(16313/95/41)) read err: read after end of file
file_win32_pread(108,1,buffer,262074371(16313/95/42)) read err: read after end of file
file_win32_pread(108,16,buffer,262074384(16313/95/55)) read err: read after end of file
file_win32_pread(108,16,buffer,262074431(16313/96/39)) read err: read after end of file
file_win32_pread(108,16,buffer,262074494(16313/97/39)) read err: read after end of file
file_win32_pread(108,16,buffer,262078464(16313/160/40)) read err: read after end of file
file_win32_pread(108,16,buffer,262078463(16313/160/39)) read err: read after end of file
file_win32_pread(108,16,buffer,262078466(16313/160/42)) read err: read after end of file
file_win32_pread(108,1,buffer,262078471(16313/160/47)) read err: read after end of file
file_win32_pread(108,16,buffer,262078480(16313/160/56)) read err: read after end of file
file_win32_pread(108,16,buffer,262746191(16355/49/30)) read err: read after end of file
file_win32_pread(108,16,buffer,262754383(16355/179/32)) read err: read after end of file
file_win32_pread(108,1,buffer,262754390(16355/179/39)) read err: read after end of file
file_win32_pread(108,16,buffer,262760099(16356/15/15)) read err: read after end of file
file_win32_pread(108,16,buffer,262781007(16357/92/7)) read err: read after end of file
file_win32_pread(108,16,buffer,262781054(16357/92/54)) read err: read after end of file
file_win32_pread(108,1,buffer,262781054(16357/92/54)) read err: read after end of file
file_win32_pread(108,16,buffer,262803455(16358/193/27)) read err: read after end of file
file_win32_pread(108,1,buffer,262803455(16358/193/27)) read err: read after end of file
file_win32_pread(108,16,buffer,262805567(16358/226/60)) read err: read after end of file
file_win32_pread(108,16,buffer,262805583(16358/227/13)) read err: read after end of file
file_win32_pread(108,1,buffer,262805585(16358/227/15)) read err: read after end of file
file_win32_pread(108,11,buffer,262805630(16358/227/60)) read err: read after end of file
file_win32_pread(108,16,buffer,262807477(16359/2/17)) read err: read after end of file
file_win32_pread(108,16,buffer,262811163(16359/60/49)) read err: read after end of file
file_win32_pread(108,1,buffer,262811164(16359/60/50)) read err: read after end of file
file_win32_pread(108,16,buffer,262852671(16361/209/40)) read err: read after end of file
file_win32_pread(108,1,buffer,262852671(16361/209/40)) read err: read after end of file
file_win32_pread(108,8,buffer,262852687(16361/209/56)) read err: read after end of file
file_win32_pread(108,16,buffer,262867070(16362/183/12)) read err: read after end of file
file_win32_pread(108,1,buffer,262867073(16362/183/15)) read err: read after end of file
file_win32_pread(108,16,buffer,262869055(16362/214/44)) read err: read after end of file
file_win32_pread(108,1,buffer,262869056(16362/214/45)) read err: read after end of file
file_win32_pread(108,8,buffer,262869071(16362/214/60)) read err: read after end of file
file_win32_pread(108,16,buffer,262873706(16363/33/33)) read err: read after end of file
file_win32_pread(108,1,buffer,262873706(16363/33/33)) read err: read after end of file
file_win32_pread(108,16,buffer,262901823(16364/224/52)) read err: read after end of file
file_win32_pread(108,1,buffer,262901824(16364/224/53)) read err: read after end of file
file_win32_pread(108,16,buffer,262907616(16365/61/49)) read err: read after end of file
file_win32_pread(108,16,buffer,263084048(16376/57/18)) read err: read after end of file
file_win32_pread(108,16,buffer,263111817(16377/243/4)) read err: read after end of file
file_win32_pread(108,1,buffer,263111817(16377/243/4)) read err: read after end of file
file_win32_pread(108,16,buffer,263114681(16378/33/33)) read err: read after end of file
file_win32_pread(108,16,buffer,263112783(16378/3/25)) read err: read after end of file
file_win32_pread(108,16,buffer,263112830(16378/4/9)) read err: read after end of file
file_win32_pread(108,16,buffer,263114752(16378/34/41)) read err: read after end of file
file_win32_pread(108,16,buffer,263113655(16378/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263114878(16378/36/41)) read err: read after end of file
file_win32_pread(108,16,buffer,263116461(16378/61/49)) read err: read after end of file
file_win32_pread(108,16,buffer,263116524(16378/62/49)) read err: read after end of file
file_win32_pread(108,16,buffer,263118911(16378/100/42)) read err: read after end of file
file_win32_pread(108,16,buffer,263120975(16378/133/27)) read err: read after end of file
file_win32_pread(108,16,buffer,263123007(16378/165/43)) read err: read after end of file
file_win32_pread(108,16,buffer,263124992(16378/197/12)) read err: read after end of file
file_win32_pread(108,16,buffer,263124991(16378/197/11)) read err: read after end of file
file_win32_pread(108,16,buffer,263124994(16378/197/14)) read err: read after end of file
file_win32_pread(108,1,buffer,263124998(16378/197/18)) read err: read after end of file
file_win32_pread(108,8,buffer,263125000(16378/197/20)) read err: read after end of file
file_win32_pread(108,16,buffer,263127882(16378/243/4)) read err: read after end of file
file_win32_pread(108,16,buffer,263128634(16378/254/63)) read err: read after end of file
file_win32_pread(108,1,buffer,263128634(16378/254/63)) read err: read after end of file
file_win32_pread(108,16,buffer,263128761(16379/2/1)) read err: read after end of file
file_win32_pread(108,1,buffer,263128765(16379/2/5)) read err: read after end of file
file_win32_pread(108,16,buffer,263137280(16379/137/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263137279(16379/137/14)) read err: read after end of file
file_win32_pread(108,16,buffer,263137298(16379/137/33)) read err: read after end of file
file_win32_pread(108,16,buffer,263137343(16379/138/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263137359(16379/138/31)) read err: read after end of file
file_win32_pread(108,16,buffer,263137286(16379/137/21)) read err: read after end of file
file_win32_pread(108,16,buffer,263139407(16379/170/63)) read err: read after end of file
file_win32_pread(108,16,buffer,263141376(16379/202/16)) read err: read after end of file
file_win32_pread(108,16,buffer,263141375(16379/202/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263141378(16379/202/18)) read err: read after end of file
file_win32_pread(108,1,buffer,263141379(16379/202/19)) read err: read after end of file
file_win32_pread(108,8,buffer,263141384(16379/202/24)) read err: read after end of file
file_win32_pread(108,16,buffer,263141382(16379/202/22)) read err: read after end of file
file_win32_pread(108,16,buffer,263144010(16379/244/4)) read err: read after end of file
file_win32_pread(108,16,buffer,263144073(16379/245/4)) read err: read after end of file
file_win32_pread(108,16,buffer,263145785(16380/17/15)) read err: read after end of file
file_win32_pread(108,1,buffer,263145786(16380/17/16)) read err: read after end of file
file_win32_pread(108,16,buffer,263148591(16380/61/49)) read err: read after end of file
file_win32_pread(108,16,buffer,263194943(16383/32/33)) read err: read after end of file
file_win32_pread(108,16,buffer,263193980(16383/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263206912(16383/222/32)) read err: read after end of file
file_win32_pread(108,16,buffer,263209023(16384/1/1)) read err: read after end of file
file_win32_pread(108,16,buffer,263209026(16384/1/4)) read err: read after end of file
file_win32_pread(108,1,buffer,263209028(16384/1/6)) read err: read after end of file
file_win32_pread(108,16,buffer,263209102(16384/2/17)) read err: read after end of file
file_win32_pread(108,1,buffer,263209109(16384/2/24)) read err: read after end of file
file_win32_pread(108,16,buffer,263211023(16384/32/48)) read err: read after end of file
file_win32_pread(108,16,buffer,263219200(16384/162/35)) read err: read after end of file
file_win32_pread(108,16,buffer,263219199(16384/162/34)) read err: read after end of file
file_win32_pread(108,16,buffer,263219202(16384/162/37)) read err: read after end of file
file_win32_pread(108,1,buffer,263219212(16384/162/47)) read err: read after end of file
file_win32_pread(108,3,buffer,263219213(16384/162/48)) read err: read after end of file
file_win32_pread(108,16,buffer,263219326(16384/164/35)) read err: read after end of file
file_win32_pread(108,16,buffer,263219206(16384/162/41)) read err: read after end of file
file_win32_pread(108,16,buffer,263223359(16384/228/36)) read err: read after end of file
file_win32_pread(108,16,buffer,263223375(16384/228/52)) read err: read after end of file
file_win32_pread(108,16,buffer,263223422(16384/229/36)) read err: read after end of file
file_win32_pread(108,16,buffer,263225344(16385/5/5)) read err: read after end of file
file_win32_pread(108,16,buffer,263225040(16385/0/16)) read err: read after end of file
file_win32_pread(108,16,buffer,263225041(16385/0/17)) read err: read after end of file
file_win32_pread(108,1,buffer,263225043(16385/0/19)) read err: read after end of file
file_win32_pread(108,16,buffer,263225151(16385/2/1)) read err: read after end of file
file_win32_pread(108,1,buffer,263225156(16385/2/6)) read err: read after end of file
file_win32_pread(108,16,buffer,263225031(16385/0/7)) read err: read after end of file
file_win32_pread(108,16,buffer,263225157(16385/2/7)) read err: read after end of file
file_win32_pread(108,16,buffer,263225343(16385/5/4)) read err: read after end of file
file_win32_pread(108,16,buffer,263225361(16385/5/22)) read err: read after end of file
file_win32_pread(108,16,buffer,263226110(16385/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263227518(16385/39/37)) read err: read after end of file
file_win32_pread(108,1,buffer,263227525(16385/39/44)) read err: read after end of file
file_win32_pread(108,16,buffer,263228853(16385/60/49)) read err: read after end of file
file_win32_pread(108,16,buffer,263229503(16385/71/6)) read err: read after end of file
file_win32_pread(108,16,buffer,263233552(16385/135/23)) read err: read after end of file
file_win32_pread(108,16,buffer,263233615(16385/136/23)) read err: read after end of file
file_win32_pread(108,16,buffer,263241216(16386/2/1)) read err: read after end of file
file_win32_pread(108,1,buffer,263241224(16386/2/9)) read err: read after end of file
file_win32_pread(108,16,buffer,263243201(16386/33/33)) read err: read after end of file
file_win32_pread(108,1,buffer,263243201(16386/33/33)) read err: read after end of file
file_win32_pread(108,16,buffer,263244918(16386/60/49)) read err: read after end of file
file_win32_pread(108,1,buffer,263244918(16386/60/49)) read err: read after end of file
file_win32_pread(108,16,buffer,263245044(16386/62/49)) read err: read after end of file
file_win32_pread(108,16,buffer,263247888(16386/107/58)) read err: read after end of file
file_win32_pread(108,16,buffer,263247998(16386/109/42)) read err: read after end of file
file_win32_pread(108,1,buffer,263248003(16386/109/47)) read err: read after end of file
file_win32_pread(108,16,buffer,263259203(16387/32/33)) read err: read after end of file
file_win32_pread(108,16,buffer,263264256(16387/112/46)) read err: read after end of file
file_win32_pread(108,16,buffer,263264255(16387/112/45)) read err: read after end of file
file_win32_pread(108,16,buffer,263264258(16387/112/48)) read err: read after end of file
file_win32_pread(108,1,buffer,263264262(16387/112/52)) read err: read after end of file
file_win32_pread(108,8,buffer,263264264(16387/112/54)) read err: read after end of file
file_win32_pread(108,16,buffer,263266304(16387/145/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263268415(16387/178/47)) read err: read after end of file
file_win32_pread(108,16,buffer,263270400(16387/210/16)) read err: read after end of file
file_win32_pread(108,16,buffer,263270399(16387/210/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263270402(16387/210/18)) read err: read after end of file
file_win32_pread(108,1,buffer,263270415(16387/210/31)) read err: read after end of file
file_win32_pread(108,16,buffer,263270526(16387/212/16)) read err: read after end of file
file_win32_pread(108,1,buffer,263270529(16387/212/19)) read err: read after end of file
file_win32_pread(108,16,buffer,263270406(16387/210/22)) read err: read after end of file
file_win32_pread(108,16,buffer,263272447(16387/242/47)) read err: read after end of file
file_win32_pread(108,16,buffer,263272511(16387/243/48)) read err: read after end of file
file_win32_pread(108,16,buffer,263274242(16388/16/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263274305(16388/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,263274575(16388/21/33)) read err: read after end of file
file_win32_pread(108,16,buffer,322895951(20099/87/36)) read err: read after end of file
file_win32_pread(108,16,buffer,326444691(20320/61/49)) read err: read after end of file
file_win32_pread(108,16,buffer,331575296(20639/154/60)) read err: read after end of file
file_win32_pread(108,16,buffer,331575295(20639/154/59)) read err: read after end of file
file_win32_pread(108,16,buffer,331575298(20639/154/62)) read err: read after end of file
file_win32_pread(108,1,buffer,331575298(20639/154/62)) read err: read after end of file
file_win32_pread(108,8,buffer,331575304(20639/155/5)) read err: read after end of file
file_win32_pread(108,3,buffer,331575312(20639/155/13)) read err: read after end of file
file_win32_pread(108,3,buffer,331575359(20639/155/60)) read err: read after end of file
file_win32_pread(108,16,buffer,331575422(20639/156/60)) read err: read after end of file
file_win32_pread(108,16,buffer,331575302(20639/155/3)) read err: read after end of file
file_win32_pread(108,1,buffer,331575302(20639/155/3)) read err: read after end of file
file_win32_pread(108,16,buffer,331580847(20639/243/4)) read err: read after end of file
file_win32_pread(108,16,buffer,331580910(20639/244/4)) read err: read after end of file
file_win32_pread(108,16,buffer,331582559(20640/15/15)) read err: read after end of file
file_win32_pread(108,16,buffer,331582685(20640/17/15)) read err: read after end of file
file_win32_pread(108,1,buffer,331582685(20640/17/15)) read err: read after end of file
file_win32_pread(108,16,buffer,331599998(20641/37/3)) read err: read after end of file
file_win32_pread(108,16,buffer,331601936(20641/67/51)) read err: read after end of file
file_win32_pread(108,16,buffer,331601999(20641/68/51)) read err: read after end of file
file_win32_pread(108,1,buffer,331601999(20641/68/51)) read err: read after end of file
file_win32_pread(108,16,buffer,331603968(20641/100/4)) read err: read after end of file
file_win32_pread(108,1,buffer,331603968(20641/100/4)) read err: read after end of file
file_win32_pread(108,16,buffer,331603969(20641/100/5)) read err: read after end of file
file_win32_pread(108,16,buffer,331603970(20641/100/6)) read err: read after end of file
file_win32_pread(108,1,buffer,331603971(20641/100/7)) read err: read after end of file
file_win32_pread(108,16,buffer,331603984(20641/100/20)) read err: read after end of file
file_win32_pread(108,16,buffer,331604031(20641/101/4)) read err: read after end of file
file_win32_pread(108,1,buffer,331604032(20641/101/5)) read err: read after end of file
file_win32_pread(108,16,buffer,331606032(20641/132/52)) read err: read after end of file
file_win32_pread(108,16,buffer,331608064(20641/165/5)) read err: read after end of file
file_win32_pread(108,1,buffer,331608065(20641/165/6)) read err: read after end of file
file_win32_pread(108,16,buffer,331608066(20641/165/7)) read err: read after end of file
file_win32_pread(108,1,buffer,331608066(20641/165/7)) read err: read after end of file
file_win32_pread(108,8,buffer,331608072(20641/165/13)) read err: read after end of file
file_win32_pread(108,3,buffer,331608080(20641/165/21)) read err: read after end of file
file_win32_pread(108,3,buffer,331608127(20641/166/5)) read err: read after end of file
file_win32_pread(108,8,buffer,331608143(20641/166/21)) read err: read after end of file
file_win32_pread(108,16,buffer,331610112(20641/197/37)) read err: read after end of file
file_win32_pread(108,16,buffer,331608070(20641/165/11)) read err: read after end of file
file_win32_pread(108,16,buffer,331610111(20641/197/36)) read err: read after end of file
file_win32_pread(108,16,buffer,331610130(20641/197/55)) read err: read after end of file
file_win32_pread(108,16,buffer,331610175(20641/198/37)) read err: read after end of file
file_win32_pread(108,16,buffer,373520447(23250/145/63)) read err: read after end of file
file_win32_pread(108,16,buffer,373526607(23250/243/49)) read err: read after end of file
file_win32_pread(108,16,buffer,454273040(28277/48/12)) read err: read after end of file
BAD_RS LBA=2471379274 611245
FAT16 >32M 153836 62 29 389972 30 27 3793522823
This partition ends after the disk limits. (start=2471379274, size=3793522823, end=6264902096, disk end=976768001)
The harddisk (500 GB / 465 GiB) seems too small! (< 3207 GB / 2987 GiB)
I would really appreciate your support.
Thanks,
Victor
Re: lost access to external drive
Searching partitions inside a partiton is useless.
Run TestDisk, select "Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512", PC/Intel,
Advanced, select the partition, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit and restart your computer.
Please post the testdisk.log file content if it doesn't work.
tukan
#3 Post by tukan »
I followed your instructions. I got to the point where I saw the List of the files which I could recognize to a big extent. I chose Write and Confirmed and then Quit the TestDisk and restarted my laptop. However, I still cannot access the drive. When I try that it is always asking to start formatting which I refuse of course. Please find below the log but I replaced long lists of files in text with "HERE COMES LIST OF FILES WHICH I DELETE TO MAKE THE LOG SHORTER". I hope that is ok. Can you please help me on next steps I need to take?
BTW Files marked red on the List are files that myself-user deleted at some point of time in the past or they were deleted due to this error I am trying to fix now?
I will really appreciate your help.
Thanks,
Victor
Tue Feb 21 21:25:25 2017
FAT32 at 0/1/2
Info: size boot_sector 976724832, partition 976768001
FAT1 : 32-119231
sectors : 976724832
cluster_size : 64
test_FAT()
1 * FAT32 LBA 0 1 2 60800 254 63 976768001
sector_size 512
cluster_size 64
reserved 32
fats 2
dir_entries 0
sectors 0
media F8
fat_length 0
secs_track 63
heads 255
hidden 64
total_sect 976724832
fat32_length 119200
flags 0000
version 0.0
root_cluster 2
info_sector 1
backup_boot 6
free_count 2315363
next_free 3
fat32_boot_sector
FAT32 at 0/1/2
FAT1 : 32-119231
sectors : 976724832
cluster_size : 64
FAT32 at 0/1/2
FAT1 : 32-119231
sectors : 976724832
cluster_size : 64
check_FAT: Incorrect number of sectors per FAT
Bad
Bad
First sectors (Boot code and partition information) are not identical.
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=7631064, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
file_pread(5,16,buffer,50174(3/31/27)) ReadFile Błąd danych (CRC).
file_pread(5,16,buffer,50175(3/31/28)) ReadFile Błąd danych (CRC).
file_pread(5,16,buffer,50176(3/31/29)) ReadFile Błąd danych (CRC).
file_pread(5,16,buffer,50177(3/31/30)) ReadFile Błąd danych (CRC).
file_pread(5,16,buffer,50178(3/31/31)) ReadFile Błąd danych (CRC).
file_pread(5,16,buffer,55204(3/111/17)) ReadFile Błąd danych (CRC).
FAT32 at 32(0/1/34), nbr=101220
FAT32 at 119232(7/108/38), nbr=101228
FAT32 at 240705(14/251/47), nbr=1
FAT32 at 240724(14/252/3), nbr=1
FAT32 at 240728(14/252/7), nbr=1
FAT32 at 240732(14/252/11), nbr=1
FAT32 at 240736(14/252/15), nbr=1
FAT32 at 240740(14/252/19), nbr=1
FAT32 at 240759(14/252/38), nbr=1
FAT32 at 240763(14/252/42), nbr=1
FAT32 at 1262013(78/142/62), nbr=2
first_fat 32, second_fat 119232
FAT : 32, reserved=32, fat_length=119200
sectors_per_cluster 64
file_pread(5,1,buffer,50178(3/31/31)) ReadFile Błąd danych (CRC).
fat32_free_info read error
fat32_find_root_cluster(sectors_per_cluster=64,no_of_cluster=15258274,reserved=32,fat_length=119200,expert=0,first_free_cluster=4294967295)
cluster 2, etat=1, found=1,nb_subdir=4,nb_subdir_ok=4
fat32_get_prev_cluster error
prev cluster(2)=>0
New / Current boot sector
FAT32
sector_size 512 512
cluster_size 64 64
reserved 32 32
fats 2 2
dir_entries 0 0
sectors 0 0
media F8 F8
fat_length 0 0
secs_track 63 63
heads 255 255
hidden 64 64
total_sect 976724704 976724832
fat32_length 119200 119200
flags 0000 0000
version 0.0 0.0
root_cluster 2 2
info_sector 1 1
backup_boot 6 6
free_count uninitialised 2315363
next_free uninitialised 3
dir_partition inode=0
FAT: cluster=2(0x2), pos=238496
3 drwxr-xr-x 0 0 0 29-Sep-2010 23:03 SamsungSoftware
28 -rwxr-xr-x 0 0 4268032 5-Jul-2010 17:45 AppInst.exe
159 -rwxr-xr-x 0 0 88 18-Jun-2010 19:20 Autorun.inf
160 -rwxr-xr-x 0 0 146233 22-Jul-2010 17:53 Read me.pdf
X 7508 drwxr-xr-x 0 0 0 21-May-2011 13:01 Nowy folder
7509 drwxr-xr-x 0 0 0 21-May-2011 13:01 System Volume Information
7508 drwxr-xr-x 0 0 0 21-May-2011 13:01 ERP
6596251 -rwxr-xr-x 0 0 5170 2-Jun-2011 23:08 TREEINFO.WC
7471106 drwxr-xr-x 0 0 0 5-Jun-2011 23:02 Recycled
X 25777 drwxr-xr-x 0 0 32768 30-Jul-2011 21:24 MSIcb221.tmp
X 25778 drwxr-xr-x 0 0 32768 30-Jul-2011 21:26 MSId50ab.tmp
X 39416 drwxr-xr-x 0 0 32768 17-Sep-2011 22:06 MSI3043c.tmp
X 9984 drwxr-xr-x 0 0 32768 25-Jun-2012 23:24 _SI13266.TMP
X 570 drwxr-xr-x 0 0 32768 9-Dec-2012 21:48 MSIf3030.tmp
X 1052 drwxr-xr-x 0 0 32768 24-Jan-2013 21:59 _SI95953.TMP
X 1054 drwxr-xr-x 0 0 32768 29-Jan-2013 19:04 MSIa06f7.tmp
X 38451 drwxr-xr-x 0 0 32768 9-Mar-2013 11:48 MSI4e53b.tmp
X 42111 drwxr-xr-x 0 0 32768 4-Apr-2013 22:18 _SI28494.TMP
X 7096 drwxr-xr-x 0 0 32768 5-May-2013 13:03 MSI9bba6.tmp
X 15 drwxr-xr-x 0 0 32768 24-Nov-2013 12:37 MSIf2c5e.tmp
dir_partition inode=3
FAT: cluster=3(0x3), pos=238560
Directory /SamsungSoftware
3 drwxr-xr-x 0 0 0 29-Sep-2010 23:03 .
0 drwxr-xr-x 0 0 0 29-Sep-2010 23:03 ..
4 drwxr-xr-x 0 0 0 29-Sep-2010 23:03 Documentation
165 -rwxr-xr-x 0 0 60868356 28-Jul-2010 21:02 AutoBackupSetup.exe
2023 -rwxr-xr-x 0 0 22232313 30-Jul-2010 12:42 SecretZoneSetup.exe
dir_partition inode=7508
FAT: cluster=7508(0x1d54), pos=718880
Directory /ERP
7508 drwxr-xr-x 0 0 0 21-May-2011 13:01 .
0 drwxr-xr-x 0 0 0 21-May-2011 13:01 ..
7513 drwxr-xr-x 0 0 0 21-May-2011 13:02 Others
dir_partition inode=7513
FAT: cluster=7513(0x1d59), pos=719200
Directory /ERP/Others
7513 drwxr-xr-x 0 0 0 21-May-2011 13:02 .
7508 drwxr-xr-x 0 0 0 21-May-2011 13:02 ..
7514 drwxr-xr-x 0 0 0 21-May-2011 13:02 Movies
7515 drwxr-xr-x 0 0 0 21-May-2011 13:02 Pictures
5898242 drwxr-xr-x 0 0 0 23-May-2011 00:27 Others
1310722 -rwxr-xr-x 0 0 6144 24-May-2014 00:45 Thumbs.db
5898390 drwxr-xr-x 0 0 0 23-May-2011 00:29 Double
6029538 -rwxr-xr-x 0 0 156160 25-Jan-2012 23:33 ~WRL1051.TMP
dir_partition inode=7514
FAT: cluster=7514(0x1d5a), pos=719264
FAT: cluster=15204354(0xe80002), pos=973317024
FAT: cluster=3561797(0x365945), pos=228193376
FAT: cluster=8791068(0x86241c), pos=562866720
FAT: cluster=8791069(0x86241d), pos=562866784
FAT: cluster=5832706(0x590002), pos=373531552
file_pread(5,64,buffer,373531552(23251/67/17)) ReadFile Błąd danych (CRC).
FAT: cluster=5837347(0x591223), pos=373828576
Directory /ERP/Others/Movies
7514 drwxr-xr-x 0 0 0 21-May-2011 13:02 .
7513 drwxr-xr-x 0 0 0 21-May-2011 13:02 ..
Directory /ERP
Directory /ERP
dir_partition inode=5898390
FAT: cluster=5898390(0x5a0096), pos=377735328
Directory /ERP/Others/Double
5898390 drwxr-xr-x 0 0 0 23-May-2011 00:29 .
7513 drwxr-xr-x 0 0 0 23-May-2011 00:29 ..
dir_partition inode=5898242
FAT: cluster=5898242(0x5a0002), pos=377725856
Directory /ERP/Others/Others
5898242 drwxr-xr-x 0 0 0 23-May-2011 00:27 .
7513 drwxr-xr-x 0 0 0 23-May-2011 00:27 ..
dir_partition inode=7515
FAT: cluster=7515(0x1d5b), pos=719328
Directory /ERP/Others/Pictures
7515 drwxr-xr-x 0 0 0 21-May-2011 13:02 .
dir_partition inode=10929380
FAT: cluster=10929380(0xa6c4e4), pos=699718688
FAT: cluster=10929375(0xa6c4df), pos=699718368
Directory /ERP/Others/Pictures/BD
10929380 drwxr-xr-x 0 0 0 29-Dec-2011 00:00 .
7515 drwxr-xr-x 0 0 0 29-Dec-2011 00:00 ..
dir_partition inode=7516
FAT: cluster=7516(0x1d5c), pos=719392
FAT: cluster=13563(0x34fb), pos=1106400
FAT: cluster=30641(0x77b1), pos=2199392
Directory /ERP/Others/Pictures/RS
7516 drwxr-xr-x 0 0 0 21-May-2011 13:02 .
7515 drwxr-xr-x 0 0 0 21-May-2011 13:02 ..
Directory /ERP
Directory /ERP
Directory /ERP
Directory /ERP
fat_copy dst=/cygdrive/d/Nowy folder/ERP/Others/Movies/Collin first_cluster=1194331 (76675488) size=62924435
Directory /ERP
Write new boot!
fat32_boot_sector
FAT32 at 0/1/2
Info: size boot_sector 976724704, partition 976768001
FAT1 : 32-119231
Data : 238432-976724703
sectors : 976724704
cluster_size : 64
no_of_cluster : 15257598 (2 - 15257599)
fat_length 119200 calculated 119200
file_pread(5,16,buffer,112(0/1/50)) ReadFile Błąd danych (CRC).
FAT32 at 0/1/2
FAT1 : 32-119231
sectors : 976724704
cluster_size : 64
OK
OK
Sectors are identical.
There are bad sectors (see the CRC error message in the log file).
You can either copy the files using testdisk/advanced/list to another disk or clone the damaged disk to a new empty one using ddrescue.
Read https://www.cgsecurity.org/testdisk.pdf on how to create a Linux LiveUSB and how to use ddrescue.
