I am recovering data from a failed server, with about 250 Gig of data. TestDisk has now been running for over 2 weeks, through a USB attached external drive. Resource monitor shows that TestDisk is processing at about 5 - 6 MB per second so I expected it to be completed after about 13 hours!
I look at the log generated, and it lists files I am trying to recover. I look at the destination drive and only about 1/3 of the files in the log are there!
What should I do at this point? If I abort the run now, will the files "appear" or does the abort prevent an update to the drive directory structure?
TestDisk log shows files recovered, but nothing on new drive
Re: TestDisk log shows files recovered, but nothing on new drive
You should clone the damaged disk to a new empty one using ddrescue.
See https://www.cgsecurity.org/testdisk.pdf for details
Once it's done, remove the original disk and try to recover your data from the clone.
