SSD just corrupted on shutdown now will not boot. Need help.
Smorgus
#1 Post by Smorgus »
So I have no idea what I am doing and I might have messed some stuff up, but any help would be greatly appreciated.
I tried to follow the guide and hit write on the partition and rebooted but it never would boot.
I think I was able to recover everything with photorec. But now I want to be able to boot it again without having to re-install Windows 7 again!
Please help!
So here is what I have.
Does anyone know what I should do so that I can get this to boot again back into Windows 7?
Thank you all so much and thank you for this program!
Re: SSD just corrupted on shutdown now will not boot. Need help.
Run TestDisk, Advanced, select the partition corresponding to E:, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
After a reboot, run "cmd" (right click run as administrator) and "chkdsk /f e:"
What are the results ?
Smorgus
#3 Post by Smorgus »
cgrenier wrote: 23 Feb 2017, 21:00 Run TestDisk, Advanced, select the partition corresponding to E:, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
Thank you so much for helping me!
But I did just like you said and got this:
Run "cmd" (right click run as administrator) and "chkdsk /f d:" (replace d: by the correct drive letter).
If it doesn't work, use PhotoRec on this partition, use [Whole] instead of [Free] after selecting this partition.
Smorgus
#5 Post by Smorgus »
Well damn, I guess it is damaged beyond repair. Chkdsk said it could not repair and aborted.
Thank you for the amazing program and the help!
I had to reformat it.
Thanks again!
