Help needed in recover
STMFLUSAWWW
#1 Post by STMFLUSAWWW »
I used this tool before and worked well.
This time it did not work any more getting these information when I run it see images in this sequence.
step 1.png (37.4 KiB) Viewed 2593 times
step 2.png (27.8 KiB) Viewed 2593 times
step 3.png (27.68 KiB) Viewed 2593 times
Any one out there which knows what I'm looking at and knows how to correct it.
Is this possible to be corrected and if yes can you help with screen share after the scan is done?
Thanks
Steven
Re: Help needed in recover
You didn't post the screenshot of the actual partition table.
I am assuming you want to recover a deleted partition. If it's not the case, please explain your problem and post the testdisk.log file content.
To recover a deleted partition:
For each partition, use 'p' to list its content.
If you want to recover this partition, set it to *(bootable), P(rimary) or L(ogical).
On next screen, choose Write, confirm, Quit and restart your computer
STMFLUSAWWW
#3 Post by STMFLUSAWWW »
Dear,
Thanks for the replay,
The images are exactly what happen on my computer.
You write: "If you want to recover this partition, set it to *(bootable), P(rimary) or L(ogical)."
So which of them *,P or L.
And what about the first image where it has the two warnings?
Thanks a lot for the help
Steven
STMFLUSAWWW
#4 Post by STMFLUSAWWW »
Dear,
Can you help me, it is really important to me.
Thanks.
Steven
