Problem with Raid0
p1rado
Problem with Raid0
#1 Post by p1rado »
Hello folks!
Greetings from BRAZIL!
I had a problem with my Raid 0, similar with this one:
http://blog.quindorian.org/2013/07/repa ... rted.html/
I had to re-cread Raid volume and search for lost partition
I was doing the step-by-step guide but when I had to chose the type of partition, Intel showed no results, even with deeper search.
And EFI GPT worked fine, showing 3 partitions. I did the "Write" step but the problem persists
All 3 partitions are P and MS Data. If I try to list files, it returns only directories like
dr-xr-xr-x
471MB / 450 MiB
drwxr-xr-x (System Volume Information) / EFI / Boot, etc
FAT32 103MB / 99 MiB
And another one with huge volume (almost everything, 499GB / 465 GiB)
If I do a Deeper Search, a lot of erros occur
What should I do? How to proceed?
Re: Problem with Raid0
Please post the testdisk.log file content.
p1rado
#3 Post by p1rado »
Hello there!
Sorry, I tried to attach the file here in the forum but it returned a message saying "invalid extension"
So I made this uploads:
http://www.filedropper.com/testdisk1
http://www.filedropper.com/testdisk2
Thanks again!
maphius
#4 Post by maphius »
Hi there,
Did you ever get this sorted?
