USB ext 2TB HD saying needs to format (its not new)
CKBW
#1 Post by CKBW »
My 2.0TB WD 3.5" external hard drive I've used for several yrs is suddenly asking to format every time I plug it in (USB).
...so after reading around the internet, I ended up here thinking I need to recover or rebuild the partition?
I downloaded TestDisk and Analysed it (and also went under Advance) to try and view files (to confirm they are still there). After a Quick Search and List Files I get an error that says:
FYI, I am using the default (*) primary bootable characteristics selection on the ext hard drive when trying to view/list the files.
Disk Management on my Win7 64bit PC is showing a health partition and a SMART info on the drive shows no errors.
Any suggestions?
Thank you for any help.
Re: USB ext 2TB HD saying needs to format (its not new)
Please post the testdisk.log file content showing what you have done in the Advanced menu.
CKBW
#3 Post by CKBW »
Will do, I went ahead and started a deep search on the disk (not the recognized drive letter)... scan is at 33% after an hour and 1/2 so far.
CKBW
#4 Post by CKBW »
after a deep search, I still get the same error when trying to view/list the files.
I have been able to view the files using a GUI file recovery program, but I would like to salvage the partition if possible.
here is the the testdisk.log contents (ext HD in question is: Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512):
Tue Mar 7 14:30:47 2017
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=989715234816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=9409921024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\R:)=2000364240896
Drive C: - 989 GB / 921 GiB - CHS 120326 255 63, sector size=512
Drive D: - 9409 MB / 8974 MiB - CHS 1144 255 63, sector size=512
Drive R: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Analyse Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 243197 57 60 3906961408
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/32/33
filesystem size 3906961408
mftmirr_lcn 2
NTFS, blocksize=4096, 2000 GB / 1862 GiB
file_pread(5,8,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(5,14,buffer,3906963458(243197/57/63)) lseek err Invalid argument
file_pread(5,3,buffer,3906963472(243197/58/14)) lseek err Invalid argument
file_pread(5,3,buffer,3906963519(243197/58/61)) lseek err Invalid argument
file_pread(5,8,buffer,3906963535(243197/59/14)) lseek err Invalid argument
file_pread(5,11,buffer,3906963582(243197/59/61)) lseek err Invalid argument
file_pread(5,2,buffer,3906965504(243197/90/30)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 243197 57 60 3906961408
Not an exFAT boot sector.
1 * HPFS - NTFS 0 32 33 243197 57 60 3906961408
NTFS at 0/32/33
mftmirr_lcn 2
file_pread(5,2,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(5,14,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(5,8,buffer,3906963463(243197/58/5)) lseek err Invalid argument
file_pread(5,3,buffer,3906963471(243197/58/13)) lseek err Invalid argument
file_pread(5,3,buffer,3906963518(243197/58/60)) lseek err Invalid argument
file_pread(5,8,buffer,3906963534(243197/59/13)) lseek err Invalid argument
file_pread(5,11,buffer,3906963581(243197/59/60)) lseek err Invalid argument
file_pread(5,2,buffer,3906965503(243197/90/29)) lseek err Invalid argument
file_pread(5,6,buffer,3906963458(243197/57/63)) lseek err Invalid argument
file_pread(5,1,buffer,3906963474(243197/58/16)) lseek err Invalid argument
file_pread(5,1,buffer,3906963521(243197/58/63)) lseek err Invalid argument
file_pread(5,1,buffer,3906963542(243197/59/21)) lseek err Invalid argument
file_pread(5,1,buffer,3906963592(243197/60/8)) lseek err Invalid argument
file_pread(5,1,buffer,3906965505(243197/90/31)) lseek err Invalid argument
#5 Post by cgrenier »
If a program can list your files, it's safer to use it to copy your data.
Otherwise using latest 7.1-WIP, you can try TestDisk, Advanced, Boot, Repair MFT.
CKBW
#6 Post by CKBW »
the problem with the GUI file recovery program I have is that it doesn't remember/contain file location - so I have thousands of files with no directory structure. :(
I'll grab those file today and then try to repair the MFT and let you know what happens, thanks!
CKBW
#7 Post by CKBW »
cgrenier wrote: 09 Mar 2017, 07:27 If a program can list your files, it's safer to use it to copy your data.
under Advance > Boot... I only see:
-Quit- -List- -Org. BS- -Rebuild BS- -Dump-
