Ext USB Portable 2TB
dyth
#1 Post by dyth »
Hi All,
I unable to access the portable and from windows chkdsk get this error message "all NTFS boot sectors are unreadbale or corrupt. cannot continue" and I just use "TestDisk" on Analysis screen I saw "Partition: read error".
My question, can "TestDisk" able rescue my files??
Thank You in advance and kind to reply my question.
- David
Re: Ext USB Portable 2TB
Try TestDdisk, Advanced, List.
If it doesn't work, try to clone the disk to a new empty one using ddrescue, read https://www.cgsecurity.org/testdisk.pdf for details.
Once it's done, try again testdisk and if it doesn't work, use photorec.
dyth
#3 Post by dyth »
Thanks Cg, the analysis still not yet complete (attach the screen shot for your refer).
I will try with your suggestion and keep you an update.
Thank you again!
- David
Analysis scanning
Analysis scanning
