microSD no partition found, showing 0 byte
fabfab
#1 Post by fabfab »
I have a Samsung 64 GB microSD which I would like to use but I can't find any possible way to format and use it with my Android phone.
Neither quick or deeper searches are able to find any partition, as the device is "empty"...
device properties
device properties
Re: microSD no partition found, showing 0 byte
Use the warranty to get a new one. Il looks like there is an electronic damage.
