Ok. I have a 3tb drive that I am working with. I know it was formatted causing loss of access to the data. Nothing written to the drive after.
Using testdisk I have went to "analyze ", advanced ", changed the type to what it would have been originally. Clicked "boot", "rebuild bs"
Now, after running many hours, and getting about a quarter of the way along.... the program just vanished from the screen. I have tried 3 times with the same results.
Running windows 7 ultimate.
Thanks for any ideas
testdisk crash during boot rebuild
Re: testdisk crash during boot rebuild
Did you try using latest 7.1-WIP ?
Please post the testdisk.log file content, it may contains some information about the problem
I am currently trying 7.1 will update once it has ran. Thanks
Ok. So looks like it died again. Here is the testdisk log.
Wed Mar 15 20:01:22 2017
OS: Windows 7 (7600)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=250057064448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=320071532544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=250058113024
filewin32_getfilesize(\\.\L:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\L:) SetFilePointer err Incorrect function.
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST3250310AS, S/N:523645594343524c202020202020202020202020, FW:3.AHC
Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - WDC WD3200AAJS-00VWA0, S/N:2020202057202d44435752413057353430313136, FW:12.01B02
Disk /dev/sdc - 250 GB / 232 GiB - CHS 32301 240 63, sector size=512 - WDC WD2500JD-00HBB0, S/N:2020202057202d444d574c413237393736393431, FW:08.02D08
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - ST3000DM001-1E6166, S/N:202020202020202020202020315734465a473339, FW:SC48
Disk /dev/sdd - 3000 GB / 2794 GiB - ST3000DM001-1E6166
Analyse Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63
Error: size boot_sector 1565540352 > partition 4294967295
HPFS - NTFS 1 5 5 267350 94 7 4294967295
file_pread(7,2,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(7,1,buffer,1565566975(364801/98/33)) lseek err Invalid argument
* HPFS - NTFS 1 5 5 267350 94 8 4294967296
1 * HPFS - NTFS 1 5 5 267350 94 8 4294967296
Change partition type:
1 P HPFS - NTFS 0 0 2 267349 89 4 4294967295
ntfs_boot_sector
filesystem size 35 1
sectors_per_cluster 0 0
mft_lcn 1565565838 0
mftmirr_lcn 3155090966 0
clusters_per_mft_record -106 0
clusters_per_index_record -98 0
Status: Bad
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 16399
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
Search mft stopped: 65536/4294967295
ntfs_boot_sector
Status: Bad
Status: Bad
9 [main] testdisk_win 5528 cygwin_exception::open_stackdumpfile: Dumping stack trace to testdisk_win.exe.stackdump
ntfs_boot_sector
Status: Bad
Status: Bad
rebuild_NTFS_BS
mft at 16399
ntfs_boot_sector
Status: Bad
Status: Bad
Before this was accidentally formated, it was still lost, but at least I could see my files. This is the log from that point. ..
Mon Mar 6 17:13:42 2017
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=3000592979968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=3000592979968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=375072489472
Disk /dev/sdh - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive C: - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive D: - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Drive F: - 250 GB / 232 GiB - CHS 32301 240 63, sector size=512
Drive G: - 375 GB / 349 GiB - CHS 45599 255 63, sector size=512
Analyse Disk /dev/sdh - 3000 GB / 2794 GiB - CHS 364801 255 63
Invalid NTFS or EXFAT boot
1 P HPFS - NTFS 0 32 33 45600 23 55 732563456
NTFS at 1/5/5
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)
filesystem size 732563456
sectors_per_cluster 1
mftmirr_lcn 2
clusters_per_mft_record 1
HPFS - NTFS 1 5 5 364800 190 62 5860507648 [Seagate Expansion Drive]
file_pread(7,2,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(7,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(7,14,buffer,1565566977(364801/98/35)) lseek err Invalid argument
file_pread(7,3,buffer,1565566991(364801/98/49)) lseek err Invalid argument
file_pread(7,3,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(7,8,buffer,1565567054(364801/99/49)) lseek err Invalid argument
file_pread(7,11,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(7,2,buffer,1565569023(364801/131/2)) lseek err Invalid argument
* HPFS - NTFS 1 5 5 364800 190 62 5860507648 [Seagate Expansion Drive]
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 8-Feb-2017 17:00 .
5 dr-xr-xr-x 0 0 0 8-Feb-2017 17:00 ..
522003 dr-xr-xr-x 0 0 0 14-Apr-2016 20:39 $RECYCLE.BIN
122583 dr-xr-xr-x 0 0 0 12-Oct-2014 06:55 ABE VOLUME CALCULATORS, CYLINDER_files
299543 dr-xr-xr-x 0 0 0 13-Oct-2014 18:11 Isaac's Stories
255893 dr-xr-xr-x 0 0 0 16-Nov-2015 18:45 MUSIC
393778 dr-xr-xr-x 0 0 0 26-May-2016 00:07 My Documents4
451036 dr-xr-xr-x 0 0 0 14-Oct-2014 13:15 My Videos
463994 dr-xr-xr-x 0 0 0 14-Oct-2014 13:58 Outlook Express
36 dr-xr-xr-x 0 0 0 14-Oct-2014 14:16 Seagate
465971 dr-xr-xr-x 0 0 0 14-Oct-2014 13:59 Seagate Backup
533270 dr-xr-xr-x 0 0 0 5-Nov-2014 14:32 System Volume Information
451443 dr-xr-xr-x 0 0 0 14-Oct-2014 13:32 VIDEO_TS
588 dr-xr-xr-x 0 0 0 11-Dec-2016 15:42 _incoming photos
122548 dr-xr-xr-x 0 0
And the rest of my files.
Can I get back to this point?
Thanks
NTFS at 1/5/5
mftmirr_lcn 2
Thanks
