wrong testdisk command?
msamio
#1 Post by msamio »
hi! i thing i made a mistake. I had 2hdd drive (2tbx2 RAID0). Yesterday night i had a blue screen; after the crash there was a 4TB hole on my computer.
So, i try to fix that. At first, after analyze i could see the files on testdisk menu.
But what did ı do,, Mistakenly i chose ''extend'' and i guess it delete the 'system reserve' part. :S
What should i do?
...analiseing
..after 1 hour
after continue
Re: wrong testdisk command?
You forgot the post the image of the actual partition table and you didn't say if you had one or 2 partitions. Were they NTFS or exFAT ?
Can you list the files of the NTFS partition ?
If a partition is missing, press enter and on next screen, choose Deeper Search.
