Where to start working? Topic is solved
Nonsmoker
#1 Post by Nonsmoker »
Hello I'm new here :-)
I moved a lot of Data from my external hd to the main hd and later installed the OS (Linux Mint) over it. :roll: Both disks use ext4 :|
Should I start working on the external hd or the main hd (or both)? Am I right that using photorec would be the best option in my case? Is it really necessary to create an image - the hd is fairly large (1TB)?
Any help is much appreciated. :-)
Re: Where to start working?
No need to create a disk image but when using photorec, be careful to not store new files on any of the 2 source disks.
Start to recover files from the disk where less data has been added by Mint installation.
Nonsmoker
#3 Post by Nonsmoker »
Thank you. :)
In photorec, i'm being asked to select the Partition. I have just One Partition (almost the entire disc). Should I select this Partition or "whole disc"?
