Hardware RAID 15TB Lost Label & Table
knotty
#1 Post by knotty »
I have no idea why but my Linux NAS with 15TB hardware RAID5 (on HPE P222) reported that it disk label was unrecognised and partition table was unknown (using parted). The RAID utility tells me the logical drive is ok. I know that the label is GPT and that there was one partition for the complete drive. However TestDisk is showing the largest found partition to be about 2TB. Any ideas would be greatly appreciated. Thanks.
Regards.
Re: Hardware RAID 15TB Lost Label & Table
Can you post the testdisk.log generated by testdisk 7.1-WIP (not 7.0) ?
knotty
#3 Post by knotty »
Thanks for the prompt response, its really appreciated. I've posted the log file from 7.1 sorry its long so I've had to do it in two posts. I know there is only one partition on the whole logical drive so I selected 'none' this time. Not sure if this is correct.
Regards,
Paul.
PART 1:
Sun Apr 2 12:55:43 2017
OS: Linux, kernel 4.8.0-36-generic (#36~16.04.1-Ubuntu SMP Sun Feb 5 09:39:57 UTC 2017) x86_64
Compiler: GCC 4.4
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
Disk /dev/sda - 15 TB / 13 TiB - CHS 1823985 255 63, sector size=512 - HP LOGICAL VOLUME, FW:6.68
Disk /dev/sdb - 16 GB / 14 GiB - CHS 15264 64 32, sector size=512 - SanDisk Cruzer Glide, FW:1.00
Disk /dev/sdc - 31 GB / 29 GiB - CHS 30436 64 32, sector size=512 - HP iLO Internal SD-CARD, FW:2.09
Disk /dev/sdd - 268 MB / 256 MiB - CHS 32 255 63 (RO), sector size=512 - HP iLO LUN 01 Media 0, FW:2.09
Disk /dev/sda - 15 TB / 13 TiB - HP LOGICAL VOLUME
Partition table type: None
P Unknown 0 0 1 1823985 243 50 29302334384
Change partition type:
P ext4 0 0 1 1823985 243 50 29302334384
search_superblock
Analyse Disk /dev/sda - 15 TB / 13 TiB - CHS 1823985 255 63
recover_EXT2: s_block_group_nr=0/16383, s_mnt_count=0/28, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 536870202
recover_EXT2: part_size 4294961616
Filesystem created: Sun Aug 10 17:03:02 2014
ext3 0 1 1 267348 254 57 4294961616
ext3 blocksize=4096 Large_file Sparse_SB, 2199 GB / 2047 GiB
BeFS 270341 184 5 2748732259 20 50 16120839399888304 [4Z2NVc1ZidVhKVUFGUkNHeVdYVkh1Z2x]
BeFS blocksize=2048, 8253869 TB / 7506850 TiB
This partition ends after the disk limits. (start=4343039761, size=16120839399888304, end=16120843742928064, disk end=29302334384)
LVM magic value at 270723/247/37
LVM magic value at 270723/247/39
LVM magic value at 270723/247/40
LVM magic value at 270723/247/61
recover_EXT2: s_block_group_nr=0/111779, s_mnt_count=14/27, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 3662791488
recover_EXT2: part_size 29302331904
Filesystem created: Wed Feb 24 21:04:49 2016
Last mount time: Sun Feb 19 21:59:03 2017
ext4 274251 213 9 2098237 162 35 29302331904
ext4 blocksize=4096 Large_file Sparse_SB Recover, 15 TB / 13 TiB
This partition ends after the disk limits. (start=4405855742, size=29302331904, end=33708187645, disk end=29302334384)
LVM magic value at 292984/97/55
ext4 321181 144 50 2145167 94 13 29302331904
This partition ends after the disk limits. (start=5159781886, size=29302331904, end=34462113789, disk end=29302334384)
HFS magic value at 328949/212/27
part_size 1178159317
HFS 328949 212 27 402286 218 60 1178159317 [R¯ß¨h™¢b<ô"H„UÌ¡ž:Fh1Z2x]
HFS blocksize=33554432, 603 GB / 561 GiB
NTFS at 435902/75/50
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
NTFS 435901 232 51 435902 75 50 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 435902 75 50 435902 173 49 6174 [Boot]
LVM magic value at 437146/161/33
BeFS 437247 42 44 1302849196 102 18 33761262907371800 [ö6º‰AkÎõ
h´ö6‡:BNòcü]´ö6K]
BeFS blocksize=2048, 17285766 TB / 15721313 TiB
This partition ends after the disk limits. (start=7024375744, size=33761262907371800, end=33761269931747543, disk end=29302334384)
BeFS 438213 252 56 1302850163 57 30 33761262907371800 [ö6º‰AkÎõ
h´ö6‡:BNòcü]´ö6K]
This partition ends after the disk limits. (start=7039907776, size=33761262907371800, end=33761269947279575, disk end=29302334384)
LVM magic value at 438705/253/38
LVM magic value at 438797/212/8
NTFS at 448725/59/31
filesystem size 474056704
mftmirr_lcn 29628543
NTFS 419216 144 58 448725 59 31 474056704
NTFS found using backup sector, blocksize=4096, 242 GB / 226 GiB
NTFS 448725 59 31 478233 229 4 474056704
NTFS, blocksize=4096, 242 GB / 226 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/122, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8160
recover_EXT2: s_blocks_count 4010752
recover_EXT2: part_size 32086016
Filesystem created: Tue Jan 5 09:08:05 2016
ext4 484672 230 37 486670 42 26 32086016
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 16 GB / 15 GiB
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/122, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8160
ext4 489669 38 34 491666 105 23 32086016
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/122, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8160
ext4 491269 86 16 493266 153 5 32086016
WBFS 496926 221 51 1070141907 114 18 17183846612992
WBFS, 8798 TB / 8001 TiB
This partition ends after the disk limits. (start=7983130163, size=17183846612992, end=17191829743154, disk end=29302334384)
LVM magic value at 508514/18/40
FAT12 at 508587/118/60
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
FAT12 508587 118 60 508587 164 41 2880
NTFS at 508625/188/60
mft_lcn 2058
mftmirr_lcn 5162
NTFS 508625 90 61 508625 188 60 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 508625 188 60 508626 31 59 6174 [Boot]
FAT12 at 508658/115/1
check_FAT: Unusual media descriptor (0xf8!=0xf0)
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
no_of_cluster : 2586 (2 - 2587)
fat_length 8 calculated 8
FAT differs, FAT sectors=0-8/8
heads/cylinder 4 (FAT) != 255 (HD)
sect/track 17 (FAT) != 63 (HD)
FAT12 508658 115 1 508659 189 12 20739 [NO NAME]
FAT12 at 508878/198/56
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
FAT12 508878 198 56 508880 18 4 20739 [NO NAME]
LVM magic value at 511219/64/39
LVM magic value at 511220/3/41
LVM magic value at 511220/11/47
LVM magic value at 511220/109/29
LVM magic value at 511227/9/40
FAT12 at 511750/241/36
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 511750 241 36 511751 32 17 2880
FAT12 at 512006/139/45
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
FAT12 512006 139 45 512007 213 56 20739 [NO NAME]
cramfs Marker at 516601/146/43
recover_cramfs
CramFS 516601 146 43 516919 27 13 5101143 [ËÉäö¨f̃«£u¦ö]
cramfs, 2611 MB / 2490 MiB
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/122, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8160
ext4 537108 223 10 539106 34 62 32086016
LVM magic value at 570761/188/46
LVM magic value at 583831/84/51
SYSV4 Marker at 591258/184/35
recover_sysv4
SysV 4 591258 184 35 591258 184 34 0 [Æ8u0”]
SysV4, 0 B
Partition not added.
FAT32 at 597440/183/18
Bad root_cluster
FAT12 at 597440/183/19
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT differs, FAT sectors=0-9/9
FAT12 597440 183 19 597440 228 63 2880 [NO NAME]
FAT32 at 597495/241/13
Bad root_cluster
FAT12 at 597495/241/14
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 597495 241 14 597496 31 58 2880 [NO NAME]
FAT32 at 607738/230/23
Bad root_cluster
FAT12 at 607738/230/24
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 607738 230 24 607739 21 5 2880 [NO NAME]
Linux SWAP 2 608199 125 47 608199 125 62 16
SWAP2 version 0, pagesize=8192, 8192 B
recover_EXT2: s_block_group_nr=0/768, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 25165824
recover_EXT2: part_size 201326592
Filesystem created: Fri Mar 4 22:10:38 2016
Last mount time: Thu Mar 9 18:12:31 2017
ext4 608371 141 5 620903 141 16 201326592
ext4 blocksize=4096 Large_file Sparse_SB Recover, 103 GB / 96 GiB
LVM magic value at 623456/238/61
block_group_nr 49
Filesystem created: Mon Jan 4 20:33:53 2016
ext4 628304 112 31 630301 179 20 32086016
LVM magic value at 634226/151/5
Linux SWAP 2 641587 144 22 641587 144 37 16
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/64, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 2097152
recover_EXT2: part_size 16777216
Filesystem created: Sun Jun 8 18:24:49 2014
Last mount time: Sun Jun 8 18:25:01 2014
ext4 641702 44 5 642746 129 5 16777216 [openvpnas2]
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 8589 MB / 8192 MiB
LVM magic value at 643959/62/26
LVM magic value at 644288/65/21
block_group_nr 1
recover_EXT2: s_block_group_nr=1/768, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 644658 220 41 657190 220 52 201326592
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 103 GB / 96 GiB
block_group_nr 25
recover_EXT2: s_block_group_nr=25/768, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 657313 63 29 669845 63 40 201326592
LVM magic value at 670873/211/54
LVM magic value at 671217/20/20
LVM magic value at 671347/223/29
LVM magic value at 671444/194/31
LVM magic value at 671469/61/1
LVM magic value at 671487/87/9
LVM magic value at 671584/188/13
LVM magic value at 671627/251/33
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/768, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 668317 128 34 680849 128 45 201326592
LVM magic value at 682457/85/12
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/768, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
ext4 677898 9 62 690430 10 10 201326592
Sys=0C 726454 157 25 831277 58 33 1683975267
FATX, 862 GB / 802 GiB
HFS magic value at 837624/184/1
part_size 4506
HFS 837624 184 1 837625 0 33 4506 [PL2303 driver¦ö]
HFS blocksize=4096, 2307 KB / 2253 KiB
FAT12 at 847638/6/45
FAT1 : 1-1
FAT2 : 2-2
start_rootdir : 3
Data : 35-830
sectors : 832
cluster_size : 4
no_of_cluster : 199 (2 - 200)
fat_length 1 calculated 1
heads/cylinder 64 (FAT) != 255 (HD)
FAT12 847638 6 45 847638 19 57 832 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 425 KB / 416 KiB
FAT32 at 847660/94/29
Bad root_cluster
FAT12 at 847660/94/30
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 847660 94 30 847660 140 11 2880 [NO NAME]
block_group_nr 5
recover_EXT2: "e2fsck -b 40961 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=5/16, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=2048
recover_EXT2: s_blocks_count 131072
recover_EXT2: part_size 262144
Filesystem created: Tue Dec 22 00:23:23 2015
ext2 848950 86 32 848966 167 32 262144
ext2 blocksize=1024 Sparse_SB Backup_SB, 134 MB / 128 MiB
BeFS 868633 205 22 2749330551 42 4 16120839399888304 [4Z2NVc1ZidVhKVUFGUkNHeVdYVkh1Z2x]
This partition ends after the disk limits. (start=13954602081, size=16120839399888304, end=16120853354490384, disk end=29302334384)
LVM magic value at 895344/40/36
SYSV4 Marker at 905512/158/34
recover_sysv4
SysV 4 905512 158 34 6304340 60 19 86732165632 [>G!Þ`&]
SysV4, 44 TB / 40 TiB
This partition ends after the disk limits. (start=14547060267, size=86732165632, end=101279225898, disk end=29302334384)
LVM magic value at 935014/37/14
LVM magic value at 937760/106/45
LVM magic value at 938352/9/28
HFS magic value at 938374/75/48
part_size 8421378
HFS 938374 75 48 938898 128 26 8421378
HFS blocksize=16777216, 4311 MB / 4112 MiB
HFS magic value at 944450/130/59
part_size 8421378
HFS 944450 130 59 944974 183 37 8421378
BeFS 947870 82 30 2749409787 174 12 16120839399888304 [4Z2NVc1ZidVhKVUFGUkNHeVdYVkh1Z2x]
This partition ends after the disk limits. (start=15227536745, size=16120839399888304, end=16120854627425048, disk end=29302334384)
HFS magic value at 950965/91/33
part_size 8421378
HFS 950965 91 33 951489 144 11 8421378
ext4 963544 130 41 2787530 80 4 29302331904
This partition ends after the disk limits. (start=15479342590, size=29302331904, end=44781674493, disk end=29302334384)
block_group_nr 49
recover_EXT2: s_block_group_nr=49/358, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 11747328
recover_EXT2: part_size 93978624
Filesystem created: Sat Sep 4 09:51:43 2010
ext4 969457 7 45 975306 236 56 93978624
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 48 GB / 44 GiB
LVM magic value at 984680/110/7
LVM magic value at 984680/110/9
LVM magic value at 984680/110/10
LVM magic value at 984680/110/31
FAT12 at 984851/95/1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 984851 95 1 984851 140 45 2880 [EFI System Partition]
FAT12 at 984859/135/33
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 984859 135 33 984859 181 14 2880 [EFI System Partition]
NTFS at 985325/190/34
mft_lcn 2058
mftmirr_lcn 5162
NTFS 985325 92 35 985325 190 34 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 985325 190 34 985326 33 33 6174 [Boot]
HFS magic value at 1003224/219/62
part_size 8421378
HFS 1003224 219 62 1003749 17 40 8421378
HFS magic value at 1009483/184/40
part_size 8421378
HFS 1009483 184 40 1010007 237 18 8421378
HFS magic value at 1011653/249/47
part_size 8421378
HFS 1011653 249 47 1012178 47 25 8421378
BeFS 1018356 168 6 2749480274 4 51 16120839399888304 [4Z2NVc1ZidVhKVUFGUkNHeVdYVkh1Z2x]
This partition ends after the disk limits. (start=16359899729, size=16120839399888304, end=16120855759788032, disk end=29302334384)
BeFS 1018453 60 57 2749480370 152 39 16120839399888304 [4Z2NVc1ZidVhKVUFGUkNHeVdYVkh1Z2x]
This partition ends after the disk limits. (start=16361451281, size=16120839399888304, end=16120855761339584, disk end=29302334384)
NTFS at 1033164/109/34
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1033164 11 35 1033164 109 34 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1033164 109 34 1033164 207 33 6174 [Boot]
LVM magic value at 1033906/71/20
NTFS at 1034109/253/41
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1034109 155 42 1034109 253 41 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1034109 253 41 1034110 96 40 6174 [Boot]
exFAT 1034451 228 7 1034451 228 6 0
exFAT, blocksize=1, 0 B
FAT12 at 1034451/230/63
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
FAT12 1034451 230 63 1034453 50 11 20739 [NO NAME]
NTFS at 1034722/92/11
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1034721 249 12 1034722 92 11 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1034722 92 11 1034722 190 10 6174 [Boot]
FAT12 at 1034766/35/9
FAT1 : 1-8
FAT2 : 9-16
start_rootdir : 17
Data : 49-20736
sectors : 20739
cluster_size : 8
FAT12 1034766 35 9 1034767 109 20 20739 [NO NAME]
exFAT 1034773 226 35 1034773 226 34 0
NTFS at 1035112/142/63
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1035112 45 1 1035112 142 63 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1035112 142 63 1035112 240 62 6174 [Boot]
LVM magic value at 1035249/153/19
Sys=0C 1043341 117 18 1140557 199 50 1561780239
FATX, 799 GB / 744 GiB
FAT12 at 1140747/11/17
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1140747 11 17 1140747 56 61 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1140747/56/62
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1140747 56 62 1140747 102 43 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1140871/33/47
FAT1 : 1-6
FAT2 : 7-12
start_rootdir : 13
Data : 45-2047
sectors : 2048
cluster_size : 1
no_of_cluster : 2003 (2 - 2004)
fat_length 6 calculated 6
FAT12 1140871 33 47 1140871 66 15 2048 [EFI System Partition] [UEFIboot]
FAT12, blocksize=512, 1048 KB / 1024 KiB
FAT16 at 1144428/68/9
FAT1 : 1-30
FAT2 : 31-60
start_rootdir : 61
Data : 93-30716
sectors : 30720
cluster_size : 4
no_of_cluster : 7656 (2 - 7657)
fat_length 30 calculated 30
FAT16 1144428 68 9 1144430 45 47 30720
FAT16, blocksize=2048, 15 MB / 15 MiB
FAT12 at 1144621/243/11
FAT1 : 1-1
FAT2 : 2-2
start_rootdir : 3
Data : 35-742
sectors : 744
cluster_size : 4
no_of_cluster : 177 (2 - 178)
FAT12 1144621 243 11 1144621 254 61 744 [EFI System Partition] [ANACONDA]
FAT12, blocksize=2048, 380 KB / 372 KiB
FAT16 at 1144622/0/33
check_FAT: Unusual number of reserved sectors 4 (FAT), should be 1.
FAT1 : 4-79
FAT2 : 80-155
start_rootdir : 156
Data : 188-76391
sectors : 76392
cluster_size : 4
no_of_cluster : 19051 (2 - 19052)
fat_length 76 calculated 75
FAT differs, FAT sectors=0-16/76
FAT16 1144622 0 33 1144626 193 5 76392 [EFI System Partition] [ANACONDA]
FAT16, blocksize=2048, 39 MB / 37 MiB
FAT12 at 1144761/137/5
FAT1 : 1-1
FAT2 : 2-2
start_rootdir : 3
Data : 35-742
sectors : 744
cluster_size : 4
FAT12 1144761 137 5 1144761 148 55 744 [EFI System Partition] [ANACONDA]
FAT16 at 1144761/149/27
FAT1 : 4-79
FAT2 : 80-155
start_rootdir : 156
Data : 188-74103
sectors : 74104
cluster_size : 4
no_of_cluster : 18479 (2 - 18480)
fat_length 76 calculated 73
FAT16 1144761 149 27 1144766 50 42 74104 [EFI System Partition] [ANACONDA]
FAT16, blocksize=2048, 37 MB / 36 MiB
recover_EXT2: s_block_group_nr=0/0, s_mnt_count=1/31, s_blocks_per_group=8192, s_inodes_per_group=1440
recover_EXT2: s_blocks_count 5760
recover_EXT2: part_size 11520
Filesystem created: Mon Nov 11 19:04:22 2013
Last mount time: Mon Nov 11 19:04:23 2013
ext2 1144783 234 12 1144784 162 2 11520
ext2 blocksize=1024 Sparse_SB, 5898 KB / 5760 KiB
FAT12 at 1144889/142/26
FAT1 : 1-7
FAT2 : 8-14
start_rootdir : 15
Data : 47-8314
sectors : 8316
cluster_size : 4
no_of_cluster : 2067 (2 - 2068)
fat_length 7 calculated 7
FAT12 1144889 142 26 1144890 19 25 8316 [EFI System Partition]
FAT12, blocksize=2048, 4257 KB / 4158 KiB
FAT12 at 1144928/62/59
FAT1 : 1-1
FAT2 : 2-2
start_rootdir : 3
Data : 35-742
sectors : 744
cluster_size : 4
FAT12 1144928 62 59 1144928 74 46 744 [EFI System Partition] [ANACONDA]
FAT16 at 1144933/31/57
FAT1 : 4-79
FAT2 : 80-155
start_rootdir : 156
Data : 188-76391
sectors : 76392
cluster_size : 4
FAT differs, FAT sectors=16-32/76
FAT16 1144933 31 57 1144937 224 29 76392 [EFI System Partition] [ANACONDA]
FAT12 at 1145469/20/24
FAT1 : 1-12
FAT2 : 13-24
start_rootdir : 25
Data : 57-12568
sectors : 12572
cluster_size : 4
no_of_cluster : 3128 (2 - 3129)
fat_length 12 calculated 10
FAT12 1145469 20 24 1145469 219 58 12572 [EFI System Partition] [ANACONDA]
FAT12, blocksize=2048, 6436 KB / 6286 KiB
FAT12 at 1145998/208/3
FAT1 : 1-7
FAT2 : 8-14
start_rootdir : 15
Data : 47-8314
sectors : 8316
cluster_size : 4
knotty
#4 Post by knotty »
PART 2:
FAT12 1145998 208 3 1145999 85 2 8316 [EFI System Partition]
FAT12 at 1147108/16/13
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1147108 16 13 1147108 61 57 2880 [EFI System Partition] [EFISECTOR]
NTFS at 1147109/72/4
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1147108 229 5 1147109 72 4 6174
Buffer can't store more than 200 lines.
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1147109 72 4 1147109 170 3 6174 [Boot]
FAT12 at 1147636/45/10
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1147636 45 10 1147636 90 54 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1147636/90/55
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1147636 90 55 1147636 136 36 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1147664/101/42
FAT1 : 1-6
FAT2 : 7-12
start_rootdir : 13
Data : 45-2047
sectors : 2048
cluster_size : 1
FAT12 1147664 101 42 1147664 134 10 2048 [EFI System Partition] [UEFIboot]
BeFS 1158178 100 36 2749620095 192 18 16120839399888304 [4Z2NVc1ZidVhKVUFGUkNHeVdYVkh1Z2x]
This partition ends after the disk limits. (start=18606135905, size=16120839399888304, end=16120858006024208, disk end=29302334384)
LVM magic value at 1159407/4/48
FAT12 at 1163337/168/12
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1163337 168 12 1163337 213 56 2880 [EFI System Partition] [EFISECTOR]
NTFS at 1163338/73/16
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1163337 230 17 1163338 73 16 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1163338 73 16 1163338 171 15 6174 [Boot]
FAT12 at 1163722/8/35
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1163722 8 35 1163722 54 16 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1163722/54/17
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1163722 54 17 1163722 99 61 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1163726/57/32
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1163726 57 32 1163726 103 13 2880 [EFI System Partition] [EFISECTOR]
NTFS at 1163726/223/38
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1163726 125 39 1163726 223 38 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1163726 223 38 1163727 66 37 6174 [Boot]
FAT12 at 1164231/68/10
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1164231 68 10 1164231 113 54 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1164231/113/55
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1164231 113 55 1164231 159 36 2880 [EFISECTOR]
FAT12 at 1164236/39/16
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1164236 39 16 1164236 84 60 2880 [EFI System Partition] [EFISECTOR]
NTFS at 1164236/205/22
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1164236 107 23 1164236 205 22 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1164236 205 22 1164237 48 21 6174 [Boot]
FAT12 at 1164669/137/9
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1164669 137 9 1164669 182 53 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1164669/182/54
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1164669 182 54 1164669 228 35 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1185460/69/10
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1185460 69 10 1185460 114 54 2880 [BALDER10]
FAT12 at 1185462/83/54
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1185462 83 54 1185462 129 35 2880 [BALDER10]
LVM magic value at 1189726/18/31
LVM magic value at 1192444/116/10
NTFS at 1204408/110/47
filesystem size 1024000
mft_lcn 42666
mftmirr_lcn 2
NTFS 1204344 176 50 1204408 110 47 1024000
NTFS found using backup sector, blocksize=4096, 524 MB / 500 MiB
mft_lcn 42666
mftmirr_lcn 2
NTFS 1204408 110 47 1204472 44 44 1024000
NTFS, blocksize=4096, 524 MB / 500 MiB
FAT12 at 1205248/163/60
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1205248 163 60 1205248 209 41 2880 [EFI System Partition] [EFISECTOR]
NTFS at 1205396/112/61
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1205396 14 62 1205396 112 61 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1205396 112 61 1205396 210 60 6174 [Boot]
recover_EXT2: s_block_group_nr=0/768, s_mnt_count=7/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Fri Dec 9 09:01:48 2016
ext4 1205416 177 18 1217948 177 29 201326592
NTFS at 1228463/107/61
filesystem size 2146455552
mftmirr_lcn 2
NTFS 1094852 189 59 1228463 107 61 2146455552
NTFS found using backup sector, blocksize=4096, 1098 GB / 1023 GiB
mftmirr_lcn 2
NTFS 1228463 107 61 1362074 25 63 2146455552
NTFS, blocksize=4096, 1098 GB / 1023 GiB
HFS magic value at 1372900/90/53
part_size 8194
HFS 1372900 90 53 1372900 220 56 8194
HFS blocksize=131072, 4195 KB / 4097 KiB
LVM magic value at 1374420/202/48
SYSV4 Marker at 1381041/108/12
recover_sysv4
SysV 4 1381041 108 12 9401592 97 57 128850151168 [ªe]v,]
SysV4, 65 TB / 60 TiB
This partition ends after the disk limits. (start=22186430480, size=128850151168, end=151036581647, disk end=29302334384)
FAT32 at 1383749/154/40
Bad root_cluster
FAT12 at 1383749/154/41
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1383749 154 41 1383749 200 22 2880 [NO NAME]
HFS magic value at 1409211/129/54
part_size 33554434
HFS 1409211 129 54 1411300 44 57 33554434
HFS blocksize=8388608, 17 GB / 16 GiB
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/23, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8000
recover_EXT2: s_blocks_count 768000
recover_EXT2: part_size 6144000
Filesystem created: Tue Mar 29 15:07:46 2016
ext4 1419440 224 47 1419823 83 34 6144000
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 3145 MB / 3000 MiB
WBFS 1420195 220 41 569270213 181 31 12428879440379904
WBFS, 6363586 TB / 5787648 TiB
This partition ends after the disk limits. (start=22815446575, size=12428879440379904, end=12428902255826478, disk end=29302334384)
cramfs Marker at 1430270/79/44
recover_cramfs
CramFS 1430270 79 44 1430520 74 42 4015933 [Š<7#4qyǨQ¼)SµR]
cramfs, 2056 MB / 1960 MiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/628, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 20580352
recover_EXT2: part_size 164642816
Filesystem created: Sun Mar 27 23:12:07 2016
Last mount time: Fri Apr 29 10:16:35 2016
ext4 1436699 120 28 1446948 3 29 164642816 [system]
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 84 GB / 78 GiB
HFS magic value at 1494372/91/11
part_size 2315255810
HFS 1494372 91 11 1638490 93 24 2315255810 [UQ,O6«I´šI$ŠI&š‰§uÑ,tÍ$°:h1Z2x]
HFS blocksize=33554432, 1185 GB / 1104 GiB
FAT16 at 1640286/188/15
FAT1 : 1-30
FAT2 : 31-60
start_rootdir : 61
Data : 93-30716
sectors : 30720
cluster_size : 4
FAT16 1640286 188 15 1640288 165 53 30720
FAT12 at 1640509/173/53
FAT1 : 1-1
FAT2 : 2-2
start_rootdir : 3
Data : 35-742
sectors : 744
cluster_size : 4
FAT12 1640509 173 53 1640509 185 40 744 [EFI System Partition] [ANACONDA]
FAT16 at 1640509/194/20
FAT1 : 4-79
FAT2 : 80-155
start_rootdir : 156
Data : 188-76391
sectors : 76392
cluster_size : 4
FAT16 1640509 194 20 1640514 131 55 76392 [EFI System Partition] [ANACONDA]
FAT16 at 1640704/163/34
FAT1 : 4-79
FAT2 : 80-155
start_rootdir : 156
Data : 188-74103
sectors : 74104
cluster_size : 4
FAT16 1640704 163 34 1640709 64 49 74104 [EFI System Partition] [ANACONDA]
ext2 1640732 140 33 1640733 68 23 11520
FAT12 at 1640845/124/52
FAT1 : 1-7
FAT2 : 8-14
start_rootdir : 15
Data : 47-8314
sectors : 8316
cluster_size : 4
FAT12 1640845 124 52 1640846 1 51 8316 [EFI System Partition]
FAT12 at 1640893/220/60
FAT1 : 1-1
FAT2 : 2-2
start_rootdir : 3
Data : 35-742
sectors : 744
cluster_size : 4
FAT12 1640893 220 60 1640893 232 47 744 [EFI System Partition] [ANACONDA]
FAT16 at 1640899/243/47
FAT1 : 4-79
FAT2 : 80-155
start_rootdir : 156
Data : 188-76391
sectors : 76392
cluster_size : 4
FAT16 1640899 243 47 1640904 181 19 76392 [EFI System Partition] [ANACONDA]
FAT12 at 1641590/74/21
FAT1 : 1-12
FAT2 : 13-24
start_rootdir : 25
Data : 57-12568
sectors : 12572
cluster_size : 4
FAT12 1641590 74 21 1641591 18 55 12572 [EFI System Partition] [ANACONDA]
FAT12 at 1645381/174/10
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1645381 174 10 1645381 219 54 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1646041/213/13
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1646041 213 13 1646042 3 57 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1646042/20/11
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1646042 20 11 1646042 65 55 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1646077/50/10
FAT1 : 1-6
FAT2 : 7-12
start_rootdir : 13
Data : 45-2047
sectors : 2048
cluster_size : 1
FAT12 1646077 50 10 1646077 82 41 2048 [EFI System Partition] [UEFIboot]
LVM magic value at 1652385/1/44
FAT12 at 1655305/26/58
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1655305 26 58 1655305 72 39 2880 [EFI System Partition] [EFISECTOR]
NTFS at 1664997/155/47
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1664997 57 48 1664997 155 47 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1664997 155 47 1664997 253 46 6174
FAT12 at 1678516/119/4
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 1678516 119 4 1678516 164 48 2880 [EFI System Partition] [EFISECTOR]
recover_EXT2: s_block_group_nr=0/768, s_mnt_count=9/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Last mount time: Mon Dec 12 12:39:17 2016
ext4 1678664 27 36 1691196 27 47 201326592
HFS magic value at 1698644/89/54
part_size 536870922
HFS 1698644 89 54 1732063 5 32 536870922
HFS blocksize=536870912, 274 GB / 256 GiB
HFS magic value at 1761514/91/33
part_size 33554434
HFS 1761514 91 33 1763603 6 36 33554434
NTFS at 1771117/220/8
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1771117 122 9 1771117 220 8 6174
mft_lcn 2058
mftmirr_lcn 5162
NTFS 1771117 220 8 1771118 63 7 6174
WBFS 1775244 205 49 569625262 166 39 12428879440379904
This partition ends after the disk limits. (start=28519307823, size=12428879440379904, end=12428907959687726, disk end=29302334384)
cramfs Marker at 1787837/225/63
recover_cramfs
CramFS 1787837 225 63 1788087 220 61 4015933 [Š<7#4qyǨQ¼)SµR]
block_group_nr 3
ext4 1795886 147 36 1806135 30 37 164642816 [system]
HFS magic value at 1807093/171/2
part_size 270532610
HFS 1807093 171 2 1823933 139 27 270532610 []2J‰ÓdE]
HFS blocksize=134217728, 138 GB / 129 GiB
The harddisk (15 TB / 13 TiB) seems too small! (< 17285770 TB / 15721316 TiB)
h´ö6‡:BNòcü]´ö6K]
h´ö6‡:BNòcü]´ö6K]
knotty
#5 Post by knotty »
PART 3:
P ext3 0 1 1 267348 254 57 4294961616
P HFS 328949 212 27 402286 218 60 1178159317 [R¯ß¨h™¢b<ô"H„UÌ¡ž:Fh1Z2x]
P NTFS 419216 144 58 448725 59 31 474056704
P NTFS 435901 232 51 435902 75 50 6174
P NTFS 435902 75 50 435902 173 49 6174 [Boot]
P NTFS 448725 59 31 478233 229 4 474056704
P ext4 484672 230 37 486670 42 26 32086016
P ext4 489669 38 34 491666 105 23 32086016
P ext4 491269 86 16 493266 153 5 32086016
P FAT12 508587 118 60 508587 164 41 2880
P NTFS 508625 90 61 508625 188 60 6174
P NTFS 508625 188 60 508626 31 59 6174 [Boot]
P FAT12 508658 115 1 508659 189 12 20739 [NO NAME]
P FAT12 508878 198 56 508880 18 4 20739 [NO NAME]
P FAT12 511750 241 36 511751 32 17 2880
P FAT12 512006 139 45 512007 213 56 20739 [NO NAME]
P CramFS 516601 146 43 516919 27 13 5101144 [ËÉäö¨f̃«£u¦ö]
P ext4 537108 223 10 539106 34 62 32086016
P FAT12 597440 183 19 597440 228 63 2880 [NO NAME]
P FAT12 597495 241 14 597496 31 58 2880 [NO NAME]
P FAT12 607738 230 24 607739 21 5 2880 [NO NAME]
P Linux SWAP 2 608199 125 47 608199 125 62 16
P ext4 608371 141 5 620903 141 16 201326592
P ext4 628304 112 31 630301 179 20 32086016
P Linux SWAP 2 641587 144 22 641587 144 37 16
P ext4 641702 44 5 642746 129 5 16777216 [openvpnas2]
P ext4 644658 220 41 657190 220 52 201326592
P ext4 657313 63 29 669845 63 40 201326592
P ext4 668317 128 34 680849 128 45 201326592
P ext4 677898 9 62 690430 10 10 201326592
P Sys=0C 726454 157 25 831277 58 33 1683975267
P HFS 837624 184 1 837625 0 33 4506 [PL2303 driver¦ö]
P FAT12 847638 6 45 847638 19 57 832 [EFI System Partition] [NO NAME]
P FAT12 847660 94 30 847660 140 11 2880 [NO NAME]
P ext2 848950 86 32 848966 167 32 262144
P HFS 938374 75 48 938898 128 26 8421378
P HFS 944450 130 59 944974 183 37 8421378
P HFS 950965 91 33 951489 144 11 8421378
P ext4 969457 7 45 975306 236 56 93978624
P FAT12 984851 95 1 984851 140 45 2880 [EFI System Partition]
P FAT12 984859 135 33 984859 181 14 2880 [EFI System Partition]
P NTFS 985325 92 35 985325 190 34 6174
P NTFS 985325 190 34 985326 33 33 6174 [Boot]
P HFS 1003224 219 62 1003749 17 40 8421378
P HFS 1009483 184 40 1010007 237 18 8421378
P HFS 1011653 249 47 1012178 47 25 8421378
P NTFS 1033164 11 35 1033164 109 34 6174
P NTFS 1033164 109 34 1033164 207 33 6174 [Boot]
P NTFS 1034109 155 42 1034109 253 41 6174
P NTFS 1034109 253 41 1034110 96 40 6174 [Boot]
P FAT12 1034451 230 63 1034453 50 11 20739 [NO NAME]
P NTFS 1034721 249 12 1034722 92 11 6174
P NTFS 1034722 92 11 1034722 190 10 6174 [Boot]
P FAT12 1034766 35 9 1034767 109 20 20739 [NO NAME]
P NTFS 1035112 45 1 1035112 142 63 6174
P NTFS 1035112 142 63 1035112 240 62 6174 [Boot]
P Sys=0C 1043341 117 18 1140557 199 50 1561780239
P NTFS 1094852 189 59 1228463 107 61 2146455552
P FAT12 1140747 11 17 1140747 56 61 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1140747 56 62 1140747 102 43 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1140871 33 47 1140871 66 15 2048 [EFI System Partition] [UEFIboot]
P FAT16 1144428 68 9 1144430 45 47 30720
P FAT12 1144621 243 11 1144621 254 61 744 [EFI System Partition] [ANACONDA]
P FAT16 1144622 0 33 1144626 193 5 76392 [EFI System Partition] [ANACONDA]
P FAT12 1144761 137 5 1144761 148 55 744 [EFI System Partition] [ANACONDA]
P FAT16 1144761 149 27 1144766 50 42 74104 [EFI System Partition] [ANACONDA]
P ext2 1144783 234 12 1144784 162 2 11520
P FAT12 1144889 142 26 1144890 19 25 8316 [EFI System Partition]
P FAT12 1144928 62 59 1144928 74 46 744 [EFI System Partition] [ANACONDA]
P FAT16 1144933 31 57 1144937 224 29 76392 [EFI System Partition] [ANACONDA]
P FAT12 1145469 20 24 1145469 219 58 12572 [EFI System Partition] [ANACONDA]
P FAT12 1145998 208 3 1145999 85 2 8316 [EFI System Partition]
P FAT12 1147108 16 13 1147108 61 57 2880 [EFI System Partition] [EFISECTOR]
P NTFS 1147108 229 5 1147109 72 4 6174
P NTFS 1147109 72 4 1147109 170 3 6174 [Boot]
P FAT12 1147636 45 10 1147636 90 54 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1147636 90 55 1147636 136 36 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1147664 101 42 1147664 134 10 2048 [EFI System Partition] [UEFIboot]
P FAT12 1163337 168 12 1163337 213 56 2880 [EFI System Partition] [EFISECTOR]
P NTFS 1163337 230 17 1163338 73 16 6174
P NTFS 1163338 73 16 1163338 171 15 6174 [Boot]
P FAT12 1163722 8 35 1163722 54 16 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1163722 54 17 1163722 99 61 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1163726 57 32 1163726 103 13 2880 [EFI System Partition] [EFISECTOR]
P NTFS 1163726 125 39 1163726 223 38 6174
P NTFS 1163726 223 38 1163727 66 37 6174 [Boot]
P FAT12 1164231 68 10 1164231 113 54 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1164231 113 55 1164231 159 36 2880 [EFISECTOR]
P FAT12 1164236 39 16 1164236 84 60 2880 [EFI System Partition] [EFISECTOR]
P NTFS 1164236 107 23 1164236 205 22 6174
P NTFS 1164236 205 22 1164237 48 21 6174 [Boot]
P FAT12 1164669 137 9 1164669 182 53 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1164669 182 54 1164669 228 35 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1185460 69 10 1185460 114 54 2880 [BALDER10]
P FAT12 1185462 83 54 1185462 129 35 2880 [BALDER10]
P NTFS 1204344 176 50 1204408 110 47 1024000
P NTFS 1204408 110 47 1204472 44 44 1024000
P FAT12 1205248 163 60 1205248 209 41 2880 [EFI System Partition] [EFISECTOR]
P NTFS 1205396 14 62 1205396 112 61 6174
P NTFS 1205396 112 61 1205396 210 60 6174 [Boot]
P ext4 1205416 177 18 1217948 177 29 201326592
P NTFS 1228463 107 61 1362074 25 63 2146455552
P HFS 1372900 90 53 1372900 220 56 8194
P FAT12 1383749 154 41 1383749 200 22 2880 [NO NAME]
P HFS 1409211 129 54 1411300 44 57 33554434
P ext4 1419440 224 47 1419823 83 34 6144000
P CramFS 1430270 79 44 1430520 74 42 4015934 [Š<7#4qyǨQ¼)SµR]
P ext4 1436699 120 28 1446948 3 29 164642816 [system]
P HFS 1494372 91 11 1638490 93 24 2315255810 [UQ,O6«I´šI$ŠI&š‰§uÑ,tÍ$°:h1Z2x]
P FAT16 1640286 188 15 1640288 165 53 30720
P FAT12 1640509 173 53 1640509 185 40 744 [EFI System Partition] [ANACONDA]
P FAT16 1640509 194 20 1640514 131 55 76392 [EFI System Partition] [ANACONDA]
P FAT16 1640704 163 34 1640709 64 49 74104 [EFI System Partition] [ANACONDA]
P ext2 1640732 140 33 1640733 68 23 11520
P FAT12 1640845 124 52 1640846 1 51 8316 [EFI System Partition]
P FAT12 1640893 220 60 1640893 232 47 744 [EFI System Partition] [ANACONDA]
P FAT16 1640899 243 47 1640904 181 19 76392 [EFI System Partition] [ANACONDA]
P FAT12 1641590 74 21 1641591 18 55 12572 [EFI System Partition] [ANACONDA]
P FAT12 1645381 174 10 1645381 219 54 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1646041 213 13 1646042 3 57 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1646042 20 11 1646042 65 55 2880 [EFI System Partition] [EFISECTOR]
P FAT12 1646077 50 10 1646077 82 41 2048 [EFI System Partition] [UEFIboot]
P FAT12 1655305 26 58 1655305 72 39 2880 [EFI System Partition] [EFISECTOR]
P NTFS 1664997 57 48 1664997 155 47 6174
P NTFS 1664997 155 47 1664997 253 46 6174
P FAT12 1678516 119 4 1678516 164 48 2880 [EFI System Partition] [EFISECTOR]
P ext4 1678664 27 36 1691196 27 47 201326592
P HFS 1698644 89 54 1732063 5 32 536870922
P HFS 1761514 91 33 1763603 6 36 33554434
P NTFS 1771117 122 9 1771117 220 8 6174
P NTFS 1771117 220 8 1771118 63 7 6174
P CramFS 1787837 225 63 1788087 220 61 4015934 [Š<7#4qyǨQ¼)SµR]
P ext4 1795886 147 36 1806135 30 37 164642816 [system]
P HFS 1807093 171 2 1823933 139 27 270532610 []2J‰ÓdE]
echo "0 4294961616 linear /dev/sda 63" | dmsetup create test0
echo "0 1178159317 linear /dev/sda 5284579067" | dmsetup create test1
echo "0 474056704 linear /dev/sda 6734714169" | dmsetup create test2
echo "0 6174 linear /dev/sda 7002764231" | dmsetup create test3
echo "0 6174 linear /dev/sda 7002770404" | dmsetup create test4
echo "0 474056704 linear /dev/sda 7208770872" | dmsetup create test5
echo "0 32086016 linear /dev/sda 7786270206" | dmsetup create test6
echo "0 32086016 linear /dev/sda 7866534912" | dmsetup create test7
echo "0 32086016 linear /dev/sda 7892241918" | dmsetup create test8
echo "0 2880 linear /dev/sda 8170457648" | dmsetup create test9
echo "0 6174 linear /dev/sda 8171066355" | dmsetup create test10
echo "0 6174 linear /dev/sda 8171072528" | dmsetup create test11
echo "0 20739 linear /dev/sda 8171598015" | dmsetup create test12
echo "0 20739 linear /dev/sda 8175137599" | dmsetup create test13
echo "0 2880 linear /dev/sda 8221278968" | dmsetup create test14
echo "0 20739 linear /dev/sda 8225385191" | dmsetup create test15
echo "0 5101144 linear /dev/sda 8299204305" | dmsetup create test16
echo "0 32086016 linear /dev/sda 8628654078" | dmsetup create test17
echo "0 2880 linear /dev/sda 9597885147" | dmsetup create test18
echo "0 2880 linear /dev/sda 9598772371" | dmsetup create test19
echo "0 2880 linear /dev/sda 9763325483" | dmsetup create test20
echo "0 16 linear /dev/sda 9770724856" | dmsetup create test21
echo "0 201326592 linear /dev/sda 9773489002" | dmsetup create test22
echo "0 32086016 linear /dev/sda 10093710846" | dmsetup create test23
echo "0 16 linear /dev/sda 10307104248" | dmsetup create test24
echo "0 16777216 linear /dev/sda 10308945406" | dmsetup create test25
echo "0 201326592 linear /dev/sda 10356444670" | dmsetup create test26
echo "0 201326592 linear /dev/sda 10559737342" | dmsetup create test27
echo "0 201326592 linear /dev/sda 10736520702" | dmsetup create test28
echo "0 201326592 linear /dev/sda 10890431998" | dmsetup create test29
echo "0 1683975267 linear /dev/sda 11670493425" | dmsetup create test30
echo "0 4506 linear /dev/sda 13456441152" | dmsetup create test31
echo "0 832 linear /dev/sda 13617304892" | dmsetup create test32
echo "0 2880 linear /dev/sda 13617663851" | dmsetup create test33
echo "0 262144 linear /dev/sda 13638387199" | dmsetup create test34
echo "0 8421378 linear /dev/sda 15074983082" | dmsetup create test35
echo "0 8421378 linear /dev/sda 15172597498" | dmsetup create test36
echo "0 8421378 linear /dev/sda 15277258490" | dmsetup create test37
echo "0 93978624 linear /dev/sda 15574327190" | dmsetup create test38
echo "0 2880 linear /dev/sda 15821637300" | dmsetup create test39
echo "0 2880 linear /dev/sda 15821768372" | dmsetup create test40
echo "0 6174 linear /dev/sda 15829251955" | dmsetup create test41
echo "0 6174 linear /dev/sda 15829258128" | dmsetup create test42
echo "0 8421378 linear /dev/sda 16116807418" | dmsetup create test43
echo "0 8421378 linear /dev/sda 16217356026" | dmsetup create test44
echo "0 8421378 linear /dev/sda 16252221178" | dmsetup create test45
echo "0 6174 linear /dev/sda 16597780387" | dmsetup create test46
echo "0 6174 linear /dev/sda 16597786560" | dmsetup create test47
echo "0 6174 linear /dev/sda 16612970891" | dmsetup create test48
echo "0 6174 linear /dev/sda 16612977064" | dmsetup create test49
echo "0 20739 linear /dev/sda 16618469867" | dmsetup create test50
echo "0 6174 linear /dev/sda 16622808563" | dmsetup create test51
echo "0 6174 linear /dev/sda 16622814736" | dmsetup create test52
echo "0 20739 linear /dev/sda 16623518003" | dmsetup create test53
echo "0 6174 linear /dev/sda 16629077115" | dmsetup create test54
echo "0 6174 linear /dev/sda 16629083288" | dmsetup create test55
echo "0 1561780239 linear /dev/sda 16761280553" | dmsetup create test56
echo "0 2146455552 linear /dev/sda 17588809345" | dmsetup create test57
echo "0 2880 linear /dev/sda 18326101264" | dmsetup create test58
echo "0 2880 linear /dev/sda 18326104144" | dmsetup create test59
echo "0 2048 linear /dev/sda 18328094740" | dmsetup create test60
echo "0 30720 linear /dev/sda 18385240112" | dmsetup create test61
echo "0 744 linear /dev/sda 18388351684" | dmsetup create test62
echo "0 76392 linear /dev/sda 18388352462" | dmsetup create test63
echo "0 744 linear /dev/sda 18390594100" | dmsetup create test64
echo "0 74104 linear /dev/sda 18390594878" | dmsetup create test65
echo "0 11520 linear /dev/sda 18390953648" | dmsetup create test66
echo "0 8316 linear /dev/sda 18392650756" | dmsetup create test67
echo "0 744 linear /dev/sda 18393272284" | dmsetup create test68
echo "0 76392 linear /dev/sda 18393350654" | dmsetup create test69
echo "0 12572 linear /dev/sda 18401960768" | dmsetup create test70
echo "0 8316 linear /dev/sda 18410470976" | dmsetup create test71
echo "0 2880 linear /dev/sda 18428291040" | dmsetup create test72
echo "0 6174 linear /dev/sda 18428304451" | dmsetup create test73
echo "0 6174 linear /dev/sda 18428310624" | dmsetup create test74
echo "0 2880 linear /dev/sda 18436775184" | dmsetup create test75
echo "0 2880 linear /dev/sda 18436778064" | dmsetup create test76
echo "0 2048 linear /dev/sda 18437228564" | dmsetup create test77
echo "0 2880 linear /dev/sda 18689019500" | dmsetup create test78
echo "0 6174 linear /dev/sda 18689023411" | dmsetup create test79
echo "0 6174 linear /dev/sda 18689029584" | dmsetup create test80
echo "0 2880 linear /dev/sda 18695194468" | dmsetup create test81
echo "0 2880 linear /dev/sda 18695197348" | dmsetup create test82
echo "0 2880 linear /dev/sda 18695261812" | dmsetup create test83
echo "0 6174 linear /dev/sda 18695266103" | dmsetup create test84
echo "0 6174 linear /dev/sda 18695272276" | dmsetup create test85
echo "0 2880 linear /dev/sda 18703375308" | dmsetup create test86
echo "0 2880 linear /dev/sda 18703378188" | dmsetup create test87
echo "0 2880 linear /dev/sda 18703453812" | dmsetup create test88
echo "0 6174 linear /dev/sda 18703458103" | dmsetup create test89
echo "0 6174 linear /dev/sda 18703464276" | dmsetup create test90
echo "0 2880 linear /dev/sda 18710416124" | dmsetup create test91
echo "0 2880 linear /dev/sda 18710419004" | dmsetup create test92
echo "0 2880 linear /dev/sda 19044419256" | dmsetup create test93
echo "0 2880 linear /dev/sda 19044452312" | dmsetup create test94
echo "0 1024000 linear /dev/sda 19347797497" | dmsetup create test95
echo "0 1024000 linear /dev/sda 19348821496" | dmsetup create test96
echo "0 2880 linear /dev/sda 19362319448" | dmsetup create test97
echo "0 6174 linear /dev/sda 19364687683" | dmsetup create test98
echo "0 6174 linear /dev/sda 19364693856" | dmsetup create test99
echo "0 201326592 linear /dev/sda 19365019208" | dmsetup create test100
echo "0 2146455552 linear /dev/sda 19735264896" | dmsetup create test101
echo "0 8194 linear /dev/sda 22055644222" | dmsetup create test102
echo "0 2880 linear /dev/sda 22229937427" | dmsetup create test103
echo "0 33554434 linear /dev/sda 22638982895" | dmsetup create test104
echo "0 6144000 linear /dev/sda 22803317758" | dmsetup create test105
echo "0 4015934 linear /dev/sda 22977292570" | dmsetup create test106
echo "0 164642816 linear /dev/sda 23080577022" | dmsetup create test107
echo "0 2315255810 linear /dev/sda 24007091923" | dmsetup create test108
echo "0 30720 linear /dev/sda 26351206448" | dmsetup create test109
echo "0 744 linear /dev/sda 26354788036" | dmsetup create test110
echo "0 76392 linear /dev/sda 26354789326" | dmsetup create test111
echo "0 74104 linear /dev/sda 26357920062" | dmsetup create test112
echo "0 11520 linear /dev/sda 26358368432" | dmsetup create test113
echo "0 8316 linear /dev/sda 26360182788" | dmsetup create test114
echo "0 744 linear /dev/sda 26360959964" | dmsetup create test115
echo "0 76392 linear /dev/sda 26361057790" | dmsetup create test116
echo "0 12572 linear /dev/sda 26372148032" | dmsetup create test117
echo "0 2880 linear /dev/sda 26433056736" | dmsetup create test118
echo "0 2880 linear /dev/sda 26443662096" | dmsetup create test119
echo "0 2880 linear /dev/sda 26443666000" | dmsetup create test120
echo "0 2048 linear /dev/sda 26444230164" | dmsetup create test121
echo "0 2880 linear /dev/sda 26592476520" | dmsetup create test122
echo "0 6174 linear /dev/sda 26748180443" | dmsetup create test123
echo "0 6174 linear /dev/sda 26748186616" | dmsetup create test124
echo "0 2880 linear /dev/sda 26965367040" | dmsetup create test125
echo "0 201326592 linear /dev/sda 26967738896" | dmsetup create test126
echo "0 536870922 linear /dev/sda 27288721520" | dmsetup create test127
echo "0 33554434 linear /dev/sda 28298728175" | dmsetup create test128
echo "0 6174 linear /dev/sda 28453002299" | dmsetup create test129
echo "0 6174 linear /dev/sda 28453008472" | dmsetup create test130
echo "0 4015934 linear /dev/sda 28721615642" | dmsetup create test131
echo "0 164642816 linear /dev/sda 28850917886" | dmsetup create test132
echo "0 270532610 linear /dev/sda 29030959819" | dmsetup create test133
Write isn't available because the partition table type "None" has been selected.
knotty
#6 Post by knotty »
I've just re-run the analysis on 7.1 with GPT selected instead of 'none'. Please see photo attached.
Thanks.
knotty
#7 Post by knotty »
Sorry for the multiple posts but I keep discovering more info which I think may be of interest. I've just cross referenced TestDisk 7.1 CHS with what the RAID card is stating via hpacucli.
It looks like 'heads' is matching both with 255.
'Cylinder' in TestDisk is 1,823,985 but hpacucli is 65,535
'Sector' in TestDisk is 63 but hpacucli is 32
Have I interpreted this correctly? See screenshot attached.
Thanks.
#8 Post by cgrenier »
Do you know how many partitions you had on /dev/sda ?
The /var/log/messages file (or an older version) from your NAS may have this information. Example:
Apr  4 06:40:01 adsl kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Apr  4 06:40:01 adsl kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Apr  4 06:40:01 adsl kernel: sd 0:0:0:0: [sda] Write Protect is off
Apr  4 06:40:01 adsl kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Apr  4 06:40:01 adsl kernel: sda: sda1
knotty
#9 Post by knotty »
Thanks for your reply.
There was definitely only one partition on the entire disk.
Thanks again.
#10 Post by cgrenier »
Can you post the testdisk.log file when you searched with GPT partition table ?
