Bad XBOX partiton, Invalid Signature
sdh91075
#1 Post by sdh91075 »
Trying to fix my son's Xbox 360 usb flash drive, it's an original xbox flash drive that is 16gb.
When plugged in to the xbox it asked to be formatted when it already is, plugged into a pc it asks to be formatted. When running check disk on pc it says it's RAW. Ran testdisk and get bad xbox partition, invalid signature. Is there anyway to fix this? Tried doing internet search and came up with no leads.
here is save log from scan
Wed Apr 19 21:25:05 2017
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=67108864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=988792397312
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2048
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=67108864
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 67 MB / 64 MiB - CHS 8 255 63, sector size=512
Drive C: - 988 GB / 920 GiB - CHS 120213 255 63, sector size=512
Drive D: - 2048 B - CHS 1 64 32, sector size=2048
Partition table type: XBox
Analyse Disk \\.\PhysicalDrive1 - 67 MB / 64 MiB - CHS 8 255 63
Bad XBOX partition, invalid signature
Any help would be greatly appreciated. Really don't want to lose any of the stuff saved on drive since some of it can no longer be reacquired.
Re: Bad XBOX partiton, Invalid Signature
Its probably a physical/electronic problem as the disk is listed as 64MB only.
No solution except contacting a data recovery company.
Sorry
