Recover failed disk in RAID array
Jrh1982
#1 Post by Jrh1982 »
Hi there, I am trying to use testdisk to recover a disk from a failed RAID array.
Scenario: 1 x disk in RAID1 array failed, disk has been removed and connected to a different machine. Ran test disk and it can see the physical disk but is unable to discover any partitions on it. It gives the message Partition sector doesn't have the endmark 0xAA55
Not sure if I am going about this correctly or not. Any help would be greatly appreciated.
Test disk log:
Fri Apr 21 05:51:59 2017
TestDisk 7.1-WIP, Data Recovery Utility, April 2017
OS: Windows Server 2008 R2 (7601) SP1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=107374182400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=892720906240
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST310005 24AS, S/N:V9FPEECM, FW:JC4B
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST310005 24AS, S/N:V9FPC4LM, FW:JC4B
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM 001-1ER164, S/N:152D20337A0C
Drive C: - 107 GB / 100 GiB - CHS 13054 255 63, sector size=512
Drive D: - 892 GB / 831 GiB - CHS 108533 255 63, sector size=512
Disk /dev/sdc - 2000 GB / 1863 GiB - ST2000DM 001-1ER164
file_pread(6,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(6,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
Store new MBR code
Thanks
Re: Recover failed disk in RAID array
There is no trace of a partition table or partition...
Can you try PhotoRec on this disk ? Does it recover valid files ?
