Trying to recover data from usb thumb drive
tintedsepia
#1 Post by tintedsepia »
Hi
My Sandisk 16Gb seems to be playing up.
This is what is reported in Windows 10:-
Disk Management.png (104.4 KiB) Viewed 2016 times
The following is what happened when I ran a detailed report in TestDIsk
ClusterSize TestDisk.JPG (33.71 KiB) Viewed 2016 times
Thu Apr 20 15:46:06 2017
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=15631122432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=31104958464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=15631122432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=31104958464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499581452288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=31093735424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=15631122432
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 850 EVO 1TB, S/N:S21DNXAG706050F, FW:EMT01B6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Hitachi HDS721010DLE630, S/N:MSK523Y200J9TB, FW:MS2OA610
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-9YN162, S/N:S1D6RXHQ, FW:CC4B
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 850 EVO 500GB, S/N:S2RBNXAH331140F, FW:EMT02B6Q
Disk /dev/sde - 15 GB / 14 GiB - CHS 1900 255 63, sector size=512 - SanDisk Cruzer Blade, S/N:4C531001630301115333, FW:1.27
Disk /dev/sdg - 31 GB / 28 GiB - CHS 3781 255 63, sector size=512 - SanDisk Ultra, S/N:4C530001261013115411, FW:1.00
Disk /dev/sde - 15 GB / 14 GiB - SanDisk Cruzer Blade
Partition table type: None
P Unknown 0 0 1 1900 95 51 30529536
Change partition type:
P FAT32 0 0 1 1900 95 51 30529536
fat32_boot_sector
Bad
Bad
Sectors are identical.
Finally I tried PhotoRec and this is what it produced
Is there any hope of getting data back from this usb thumb drive?
Re: Trying to recover data from usb thumb drive
PhotoRec doesn't recover anything, so there is no chance to recover data via a software solution.
If you really valued your data, contact a data recovery company.
