the following partition cant be recovered help!!
valeush
#1 Post by valeush »
Hello! I accidentally delete a partition and I do not know how to recover it .. testdisk warns me of some errors I do not understand .. then attached in order the screens that came out .. I hope they can help me .. I had two partitions .. the disk c, the Disk b that was the one to eliminate, and a disk reserved for the system. But as I can not see the files I do not know if it is the one that eliminates ...
Sin título1.jpg (113.37 KiB) Viewed 3602 times
Sin título2.jpg (89.8 KiB) Viewed 3602 times
Sin título3.jpg (98.83 KiB) Viewed 3602 times
Re: the following partition cant be recovered help!!
Please use TestDisk 7.1-WIP instead of an older version.
No free space is visible on your disk, so no there is no deleted partition.
Did you delete the previous partition and create and format another partiton ?
valeush
#3 Post by valeush »
Yes, resize the partition I left, thinking I was putting them together.
Sin título4.jpg (83.32 KiB) Viewed 3591 times
This is the last screen that showed me
Sin título.jpg (89.51 KiB) Viewed 3591 times
valeush
#4 Post by valeush »
Is there anything I can do? From another program I could see the partition to delete and the files .. but it had a limit of 1 gb to recover and the partition had about 50 gb
#5 Post by cgrenier »
Please use TestDisk 7.1-WIP and post the new information
valeush
#6 Post by valeush »
Hello! This is the information I got from version 7.1
test 7-4.png (71.02 KiB) Viewed 3546 times
test 7-5.png (73.96 KiB) Viewed 3546 times
test 7-6.png (75.14 KiB) Viewed 3546 times
#7 Post by cgrenier »
For each partition found, use 'p' to list the files.
If you see your files, set this partition as P(rimary) and on next screen, choose Write, confirm, Quit and restart your computer.
