Hi all, I've tried quite a few Testdisk guides/other forum posts, but at this point I'm out of ideas, I suspect the disk is probably too far gone, but I thought I'd ask in case anyone has any further advice/steps to try.
Background: A friend has a 1TB Seagate backup plus that had stopped working and just made a beeping noise on powerup. I worked out it was likely a stuck head on the platter and with some careful encouragement got it off the platter and the disk spinning again. I didn't expect it to be recoverable, but at this point I was slightly shocked it was spinning so I just plugged the SATA cable from an external caddy straight into the powered up disk. I was actually able to read the entire structure, and very slowly copy off a lot of the files.
This was with disk connected via USB, attached to an external caddy.
At some point windows reported a cyclic redundancy check and the drive stopped reading. At this point I turned to TestDisk; the drive no longer shows up in Windows (although occasionally it will), although it can be seen by TestDisk/Photorec. I can't currenly attach/scan the disk with CrystalDisk.
With the disk in the caddy, the USB connection will be lost from time to time while attempting to run chkdsk/TestDisk, so I've now connected it straight to the motherboard with a SATA cable.
Partition search fails to find any partion, as does the deeper search; it creates a very large (~2GB) log file, with most of the lines reading "Readfile The specified network resource or device is no longer available):
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM 024 HN-M101M, S/N:2SPT9JCD465410, FW:2AR1
Disk /dev/sdd - 1000 GB / 931 GiB - ST1000LM 024 HN-M101M
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
file_pread(7,16,buffer,32(0/0/33)) ReadFile The specified network resource or device is no longer available.
file_pread(7,3,buffer,48(0/0/49)) ReadFile The specified network resource or device is no longer available.
etc...
Is the disk too far damaged to be read at this point? I was initially surprised to have recovered/be able to read so much data, so I assume it's still roughly in tact on the disk, although connectivity seems to be the current issue.
Any advice greatly appreciated.
External HDD - Seagate backup plus, no partition info. Topic is solved
Re: External HDD - Seagate backup plus, no partition info.
Try to clone the disk using ddrescue from a Linux LiveUSB. How to create a the LivsUSB and how to use ddrescue are described in https://www.cgsecurity.org/testdisk.pdf
The disk cloning will only work if the head is not stuck on the platter (again).
Many thanks for the advice, I'll be sure to try that as soon as I can. Also thanks for taking time to reply, greatly appreciated.
By attaching via the USB caddy again, I did manage to get windows to see the disk; although CrystalDisk was unable to report any information.
Running qPhotoRec on the drive created a log file ~360MB, which was mainly "file_win32_pread(276,897,buffer,4612(0/73/14)) read err: read after end of file":
It would be "PhysicalDrive3" in the below output:
Sun May 07 13:55:43 2017
PhotoRec 7.1-WIP, Data Recovery Utility, April 2017
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, ewf lib: 20140608, libjpeg: libjpeg-turbo-1.3.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=640140967936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=79919316992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=640137822208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=426704371712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=73400320000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=104857600
Disk \\.\PhysicalDrive0 - 80 GB / 74 GiB (RO) - INTEL SS DSA2M080G2GC
No partition 0 0 1 9729 80 63 156301488 [Whole disk]
1 * HPFS - NTFS 0 32 33 12 223 19 204800 [System Reserved]
2 P HPFS - NTFS 12 223 20 9729 45 44 156092416
NTFS, blocksize=4096, 79 GB / 74 GiB
Partition table type defaults to None
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB (RO) - ST1000LM 024 HN-M101MBB
P Unknown 0 0 1 121601 80 63 1953525168
706 first-level signatures enabled
file_win32_pread(276,1,buffer,4612(0/73/14)) read err: read after end of file
file_win32_pread(276,1024,buffer,5382(0/85/28)) read err: read after end of file
file_win32_pread(276,897,buffer,6406(0/101/44)) read err: read after end of file
file_win32_pread(276,897,buffer,7303(0/115/59)) read err: read after end of file
etc.
I'll try the advice you suggested.
Many thanks again.
etc.
Many thanks again.
Hi, just as a followup rather than leave a a thread with no resolution, the I believe the disk suffered further mechanical issues (likely similar to the first), it makes a few read sounds then spins down. I'm reasonably sure it's a professional recovery job at this point.
Many thanks for the time/help.
