Partion Recovery
hrzboy
Partion Recovery
#1 Post by hrzboy »
I have a 1TB harddisk.Firstly,I have 180GB free space in the end of disk.
So I decide to extract 150GB out to install a windows 10 64bit.
But when I tried to do so by windows disk tool and diskgenius.There was no selection to do this.
And I found out that the Partion Qualifier is 42 as Raid.I've never have same model harddisks,and hardly remember that I have ever set up the Raid.
So I manually change it back into 07 ntfs in diskgenius and applied the change.
At first it was alright,so I then extract 150g free space out.
And then when I boot the xp from another harddisk 500GB,I found that I was not able to read the data on this 1TB harddisk.
It shows unallocated.And the 150G is able to be use,and accidently be wrote some file.
Then I found TestDisk,seems my only hope.
I tried many operations,seems the only work way is to select Intel selection and deep analyze.
After anaylyzing about 6%,it discovered the right partion but the size is bigger than original and won't apply.
So what can I do to apply it?
Screeshot
Screeshot
Re: Partion Recovery
the png is missing. Can you copy/paste the testdisk.log file content ?
Try Deeper Search if you can't recover your partition after Quick Search.
hrzboy
#3 Post by hrzboy »
Thanks for your advice
I did the deeper search
This is the log:
Wed May 17 20:27:36 2017
TestDisk 7.1-WIP, Data Recovery Utility, April 2017
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=42952379904
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=114898904064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=114898904064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=113829617664
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=113525282304
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AADS-00S9B0, FW:01.00A01
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00RKKA0, FW:80.00A80
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10EZEX-00RKKA0
file_pread(5,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
recover_EXT2: s_block_group_nr=0/384, s_mnt_count=11/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 12582912
recover_EXT2: part_size 100663296
Filesystem created: Sun Mar 16 02:35:14 2014
Last mount time:    Mon Jun 16 12:47:26 2014
     Linux                 1932  30 19  8198  30 24  100663296
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 51 GB / 48 GiB
     Linux                 1932 127 52  8198 127 57  100663296
NTFS at 6724/76/8
filesystem size           1953515520
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=55309237760, part_size=1000199946240, sector_size=512
NTFS at 6724/108/41
mftmirr_lcn               2
     HPFS - NTFS           6724 108 41 128325  36 31 1953515520 [New Era]
This partition ends after the disk limits. (start=108027904, size=1953515520, end=2061543423, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 1055 GB / 983 GiB)
dir_partition inode=2
file_pread(5,8,buffer,31039480(2140726/232/43)) lseek err Invalid argument
file_pread(5,1,buffer,31039480(2140726/232/43)) lseek err Invalid argument
ext2fs_dir_iterate failed with error 1.
So what could I do now?
hrzboy
#4 Post by hrzboy »
cgrenier wrote: 17 May 2017, 07:04 the png is missing. Can you copy/paste the testdisk.log file content ?
Thanks, I re-uploaded the screenshot,and the log.What could I do now?
#5 Post by cgrenier »
Can you try with EFI GPT as partition table type ?
