Are you planning to build a version for it too or is there a way to install everything manually?
TestDisk for Synology DS3615xs please!
I just found out that there's a data recovery utility for Synology NAS, but unfortunately not for the DS3615xs.
Re: TestDisk for Synology DS3615xs please!
DS3615xs may be using an x86_64 CPU. Try the Linux version.
If it doesn't work, please post the output of "uname -a"
OK thanks, but then how should I manually install it?cgrenier wrote: 17 May 2017, 07:06 DS3615xs may be using an x86_64 CPU. Try the Linux version.
I am more used with Windows or Synology package installations.
