3 TB Data HD: harddisk seems too small
DiskTest
#1 Post by DiskTest »
OS: Win10x64 (Just upgraded from Win7x64 when the problem started)
Disk:
Type Fixed Disk, Data disk (Not bootable)
System Name 81h
Partition Style GPT
Total Size 2.73 TB (3 TB)
The disk was working fine in Win7x64 desktop as a data disk, but when I upgraded the system to Win10x64, the disk really slowed down, and then and failed showing up as RAW.
During the run, TestDisk gives errors like "check_FAT: Bad jump in FAT partition" and then towards the end, the following:
The harddisk (801 GB / 746 GiB) seems too small! (< 3000 GB / 2794 GiB)
MS Data 2048 4294965247 4294963200
NTFS, blocksize=4096, 2199 GB / 2047 GiB
MS Data 264192 5860532223 5860268032 [Movie Backups]
The partition "Movie Backups" is the only partition, and it has over 2TB of data. I started running Deep Scan. What shoud be the next steps? Thanks for your help.
==== The log file content is listed below =====
Sun May 21 21:26:36 2017
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=801569726464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=801569726464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=4000787029504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=801569726464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=801569726464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=4000787029504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=94538563584
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=2000392552448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\T:)=65394442240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=2000392552448
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - INTEL SS DSA2M160G2GC, S/N:VCOP006500QU61A0NG, FW:2CV1
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20 EARS-00MVWB0, S/N:W -DCWZA1A701953, FW:51.0
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20 EARS-00MVWB0, S/N:W -DCWZA1A815142, FW:51.0
Disk /dev/sdd - 801 GB / 746 GiB - CHS 97451 255 63, sector size=512 - WDC WD30 EZRX-00DC0B0, S/N:W -DCW1C0T645299, FW:80.0
Disk /dev/sde - 801 GB / 746 GiB - CHS 97451 255 63, sector size=512 - WDC WD30 EZRX-00D8PB0, S/N:W -DMW4C0N434723, FW:80.0
Disk /dev/sdf - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - Seagate BUP BK, S/N:NA7P8W8E, FW:0304
Disk /dev/sde - 801 GB / 746 GiB - WDC WD30 EZRX-00D8PB0
Partition table type: EFI GPT
Analyse Disk /dev/sde - 801 GB / 746 GiB - CHS 97451 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 1565565871)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Data 264192 5860532223 5860268032 [Basic data partition] [Movie Backups]
Mon May 22 19:11:27 2017
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
Dump : No
Align partition: Yes
Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Backup partition structure
partition_save
NTFS at 0/32/33
filesystem size 4294963200
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=2199021158400, sector_size=512
NTFS at 0/32/33
mftmirr_lcn 2
This partition ends after the disk limits. (start=2048, size=4294963200, end=4294965247, disk end=1565565872)
NTFS at 16/113/34
filesystem size 5860268032
mftmirr_lcn 2
NTFS part_offset=135266304, part_size=3000457232384, sector_size=512
NTFS at 16/113/34
mftmirr_lcn 2
This partition ends after the disk limits. (start=264192, size=5860268032, end=5860532223, disk end=1565565872)
HFS+ magic value at 9191/160/58
part_size 5528448
Mac HFS 147663552 153191999 5528448
HFS+ blocksize=4096 + Backup, 2830 MB / 2699 MiB
HFS+ magic value at 10957/80/12
part_size 1196480
Mac HFS 176029256 177225735 1196480
HFS+ blocksize=2048, 612 MB / 584 MiB
HFS+ magic value at 11344/213/18
part_size 1235404
Mac HFS 182254796 183490199 1235404
HFS+ blocksize=2048 + Backup, 632 MB / 603 MiB
HFS+ magic value at 11421/200/40
part_size 1315400
Mac HFS 183491004 184806403 1315400
HFS+ blocksize=2048 + Backup, 673 MB / 642 MiB
LVM magic value at 32836/49/35
HFS+ magic value at 41214/67/31
part_size 613432
Mac HFS 662107161 662720592 613432
HFS+ blocksize=4096, 314 MB / 299 MiB
LVM magic value at 60616/157/18
FAT32 at 62576/113/2
FAT1 : 32-641
FAT2 : 642-1251
start_rootdir : 1252 root cluster : 2
Data : 1252-624987
sectors : 624992
cluster_size : 8
no_of_cluster : 77967 (2 - 77968)
fat_length 610 calculated 610
FAT: cluster=2(0x2), pos=1005291812
MS Data 1005290560 1005915551 624992 [NO NAME]
FAT32, blocksize=4096, 319 MB / 305 MiB
recover_EXT2: s_block_group_nr=0/0, s_mnt_count=12/0, s_blocks_per_group=3268592533, s_inodes_per_group=117503883
recover_EXT2: s_blocks_count 1
recover_EXT2: part_size 2
Filesystem created: Thu Jan 1 09:01:09 1970
Last mount time: Mon Mar 22 09:16:25 1909
MS Data 1526588474 1526588475 2 [6íå]
ext4 blocksize=1024 Recover, 1024 B
file_pread(8,1,buffer,1565565873(97451/246/61)) lseek err Invalid argument
:( >>>>>>>> ====== (Nearly 2500 lines like these removed for readability) >>>>>> ======
file_pread(8,1,buffer,1565567921(97452/24/30)) lseek err Invalid argument
P Mac HFS 147663552 153191999 5528448
P Mac HFS 176029256 177225735 1196480
P Mac HFS 182254796 183490199 1235404
P Mac HFS 183491004 184806403 1315400
P Mac HFS 662107161 662720592 613432
P MS Data 1005290560 1005915551 624992 [NO NAME]
P MS Data 1526588474 1526588475 2 [6íå]
Support for this filesystem hasn't been implemented.
dir_partition inode=0
61 drwxr-xr-x 0 0 0 27-Jul-2012 14:14 GARAGE~2.APP
X 4 drwxr-xr-x 0 0 0 10-Mar-2012 09:56 _NTITL~1
X 56 drwxr-xr-x 0 0 0 10-Mar-2012 10:59 _P.TSH
65 drwxr-xr-x 0 0 0 27-Jul-2012 14:14 UNTITL~3
1 P Mac HFS 147663552 153191999 5528448
2 P Mac HFS 176029256 177225735 1196480
3 P Mac HFS 182254796 183490199 1235404
4 P Mac HFS 183491004 184806403 1315400
5 P Mac HFS 662107161 662720592 613432
6 P MS Data 1005290560 1005915551 624992 [NO NAME]
7 P MS Data 1526588474 1526588475 2 [6íå]
Re: 3 TB Data HD: harddisk seems too small
The partition table is ok, your partition is listed, so there is no need to try to undelete it.
Run TestDisk, Advanced, select the partition "Movie Backups", Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit and restart your computer.
DiskTest
#3 Post by DiskTest »
Thanks!
I ran TestDisk, Advanced, select the partition "Movie Backups", Boot, RebuildBS, List.
I can see your files, but there is no Write option. How do I proceed from there?
(BTW, after RebuildBS, it says the sectors are identical, if that matters).
Thanks again for your help!
PS: If I go to Analyze screen, I see duplicate partition #1.
Screenshot from 2017-05-27 10-56-55.png (56.21 KiB) Viewed 5075 times
DiskTest
#4 Post by DiskTest »
Something else is interesting: I used ddrescue to copy the complete disk to a new disk. When I see the old and the new disk in the disk details screen, I see that the data partition size in both of them is just 746GB, while in reality the partition has over 2 TB of data. (The size of the overall disk is listed correctly).
When I list the files in TestDisk, I am checking just the first top level directory listing. Is it recommended that I go through the complete hierarchy to see if any files are missing? And if I do find that some files are missing, what do I do to recover everything?
Finally, I see an option to select all files and copy to a different location. can I simply select all files, and copy everything to a new drive? Are the files copied just as they were, or are they copied in some kind of image format that requires mounting using a different tool?
Thanks.
Screenshot 2.png (76.35 KiB) Viewed 5066 times
