user436
#1 Post by user436 »
I have an old 320 GB Transcend external hard drive that gives me the "You need to format the disk in drive..." error message when I plug it in. It seems to list the files correctly but when I try to copy them to another location I get the "Can't open filesystem. Filesystem seems damaged." error even though it lists the partition correctly the first time. What can I do? Thanks!
Log:
Sat May 27 14:55:12 2017
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=320070483968
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - Samsung SSD 840 EVO 120GB, S/N:31533544534e4642323431323136205020202020, FW:EXT0BB6Q
Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - StoreJet Transcend, S/N:152D20329000
Disk /dev/sdb - 320 GB / 298 GiB - StoreJet Transcend
Analyse Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 38913 37 36 625137664 [The Orange Box]
Re: Can't open filesystem. Filesystem seems damaged.
Run TestDisk, Advanced, Boot, RebuildBS, List. If you see your files, choose Write, confirm, Quit and restart your computer.
If it doesn't work,
- run "cmd" (right click run as administrator) and "chkdsk /f d:" (replace d: by the correct drive letter)
- you can also use PhotoRec to recover your files but unfortunately without the original filenames.
