Micro SD Card Samsung 64GB Evo SDXC - RAW
rmmb
#1 Post by rmmb »
Android stopped recognizing this card (used in my Android phone for Images and Video mainly) and wanted a format. I tried W10 and the same happened. I used CHKDSK /F /R but after some operations the result was a RAW card.
Now I'm using TestDisk to try to recover this card. I checked the documentation and learned that there is a "Backup boot sector" that can be used to recover the "Boot Sector". In my case both are BAD. See below. Should I use Rebuild BS? Is there another option to get access to the files saved in the SD Card?
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
Disk /dev/sdb - 64 GB / 59 GiB - CHS 7785 255 63
1 * FAT32 LBA 0 32 33 7785 19 42 125065216
Bad
Bad
First sectors (boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
Thanks,
Rui
Re: Micro SD Card Samsung 64GB Evo SDXC - RAW
Try RebuildBS, List. If you can see your files, choose Write, confirm, Quit
If it doesn't work, use PhotoRec instead.
Good luck
rmmb
#3 Post by rmmb »
Hi. Thank you so much for your support... I have recovered all the files I wanted!
For the record: Rebuild BS didn't work successfully on the SD Card and I have used Qphotorec after that. I had to stop the process after 7 hours! But I could see that it worked very well. So I restarted the process, but this time I filtered to recover only the images (JPG files) et voilá all my images recovered after just 1 hour.
Now the strangest part. I tried CHKDSK /F /X /R again on the card and to my surprise CHKDSK worked and apparently repaired the SD card. But there was a problem with permissions and file access. I tried to give the right permissions and the SD card is RAW again. But that's ok! I've got my files!
:D
