Hello everyone, this is my first post here so forgive any rookie forum faux pas. So, I didn't drop this drive or anything -- it just failed to wake up from sleep one day and kept looping thru the post test never making it any Windows 7 splash page. It's Win 7, 500GB HDD, and when plugging it into another Windows or Linux machine shows the drive as uninitialized/unallocated. So I've run a quick scan on it using TestDisk. Before running the scan it had said Partition: Read Error, and during the scan it flagged every cylinder/sector/whatever with this Read Error. Quick scan didn't find any partitions. I ran CrystalDiskInfo and it's showing as "Good" (I can post a screenshot if needed). Scanned it with Partition Find & Mount, but it found no partitions even with it's deep scan. I also ran a scan with Minitool Partition Wizard just to see if it found anything, and it did find the partition, but I'd like to exhaust other options before buying a 1 PC license -_- ... Anyway, any help would be appreciated, thanks!
Here is the log of my TestDisk Quick Scan (I accidently started another after scan and cancelled right away, so that may be the "Search for partition aborted", I'm not sure):
Tue Jun 13 14:59:54 2017
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=465914822656
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AZLX-08K2TA0, S/N:WD-WCC6Z4PJFKK9, FW:01.01A01
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - WDC WD25 00YS-23SHB0, S/N:A2800000000000000000, FW:20.0
Disk /dev/sdb - 250 GB / 232 GiB - WDC WD25 00YS-23SHB0
Analyse Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,48(0/0/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,95(0/1/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,111(0/1/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,158(0/2/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,2080(0/33/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,51(0/0/52)) ReadFile Data error (cyclic redundancy check).
... (This went on for many lines so I'll skip to the end) ...
file_pread(5,8,buffer,488396878(30401/76/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,488396925(30401/77/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,488398847(30401/107/42)) lseek err Invalid argument
file_pread(5,1,buffer,0(0/0/1)) ReadFile Data error (cyclic redundancy check).
Store new MBR code
500gb hdd showing no partitions + partion: read error
Re: 500gb hdd showing no partitions + partion: read error
There are bad sectors, so you should to clone the disk to new empty one using ddrescue.
Read https://www.cgsecurity.org/testdisk.pdf chapters "DDRescue: data recovery from damaged disk" and "Creating a live USB".
Once it's done, remove the original disk and try to recover your data from the clone.
If nothing can be read successfully, it may be a problem of damaged head, in this case, you should contact a data recovery company.
